Reply 20 of 43, by Takedasun
Unreal 1152x864
Reply 21 of 43, by Takedasun
Unreal Tournament 99
Demo with a single bot
Reply 22 of 43, by Joseph_Joestar
Interesting. I wonder why the TNT2 PRO goes from 23 FPS at 32-bit color with 2.08 drivers to just 9 FPS with 3.68 drivers. That's a huge difference!
Reply 23 of 43, by Takedasun
Nvidia driver bugs
Reply 24 of 43, by Nemo1985
Or nvidia dirty tricks that have been disabled in the newer driver?
Reply 25 of 43, by Takedasun
Half-Life ver. 1.0.1.6
Direct3D
OpenGL
Reply 26 of 43, by Eep386
What's interesting is how well the supposedly vastly inferior S3 Savage4 Xtreme manages to hang in there, on this game. Sure it's noticeably slower under 32 bit color, but 16 bit color it's only a little bit slower than the better cards. Perhaps the S3 drivers are sensitive to the CPU and chipset combination used?
Reply 27 of 43, by BitWrangler
Well until you swap the CPU out for a K6-3+ 550 and it gets slow again.
Reply 28 of 43, by Caluser2000
I should imagine one that works would be go.....
Reply 29 of 43, by Eep386
BitWrangler wrote on 2021-08-05, 03:31:
Ought to be just fine for my Pentium MMX 233MHz system. (PCI version anyhow.)
Much as I love 3dfx cards, the prices are absoludicrous anymore.
Reply 30 of 43, by Takedasun
Need for Speed III: Hot Pursuit (Modern Patch for Need for Speed III) 1998.
Direct3D 5
Direct3D 6
Reply 31 of 43, by swaaye
NFS3 has Glide support and that is probably the fastest/smoothest option with a K6.
Reply 32 of 43, by Takedasun
Need For Speed 4: High Stakes
Reply 34 of 43, by BitWrangler
Kinda surprised how well the Rage 128 are doing, I don't feel so dumb for owning *cough* several now.
Reply 35 of 43, by Takedasun
Sphere478 wrote on 2023-07-24, 22:00:
Add a radeon 9800 pro to the tests if you are able to get one to run stable.
There is no way to test the Radeon 9800 right now.
Taking into account the weakness of the platform, most likely the performance will be equal to Radeon 9250 (Catalyst 4.7)
Reply 36 of 43, by Takedasun
Need For Speed 4: High Stakes. (1024x768x16)
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.10.33)
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.20.38)
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, Creative Driver)
Riva TNT2 (driver v2.08)
Voodoo3
Reply 37 of 43, by Takedasun
Need For Speed 4: High Stakes (1024x768x32)
Ati Rage128
Matrox G400
S3 Savage4
Nvidia TNT2
Nvidia Geforce 3
Reply 38 of 43, by appiah4
There is a lot of inconsistency wrt the clouds being rendered between those cards as well as between driver versions for the S3 Savage 4.
Reply 39 of 43, by Takedasun
Millennium Soldier: Expendable (DirectX 6) 1999.
