First post, by Xses
So I've got a 2005ish AMD Athlon 64 PC. It fully works with Windows 98SE, because It has PATA (IDE) drives and win98 drivers for the graphics card, the only problem is obviously the sound. While it works in win98, the sound card is Sound Blaster 128 Vibra and the motherboard is not allowing its DOS emulation software to run (the problem discussed here before many times). I was wondering about the solutions to make it have the sound in DOS.
Maybe in the US, it is possible to find ISA sound cards and motherboards in thrash, but here they are rare and pretty expensive. So I thought about Covox Speech Thing because it is very simple to build and there are emulators/drivers which allow it to work as a Sound Blaster, Adlib, or Tandy Sound System. The problem is that the emulators I could find only works with Intel 80386, so my question is: is there any software for that card, for later PCs like the one I have?
Reply 1 of 18, by Benedikt
When it comes to software stating that it "needs an Intel 80386", keep in mind that the Covox Speech Thing is a device from the late 1980s.
In that context, 80386 usually means any 32-bit-enabled x86 processor, i.e. it merely means that the software will not run on an 8088, 8086, 80186 or 80286.
TEMU, for instance, should run on machines way more modern than a simple 80386.
Reply 2 of 18, by Xses
Ok, thx. I saw a GitHub sound blaster emulator page that stated: intel 80386, so I thought that it is 386 only.
Reply 3 of 18, by Benedikt
Xses wrote on 2021-08-08, 18:39:
So I thought about Covox Speech Thing because it is very simple to build [...]
BTW.: The original uses an R-2R resistor ladder with R=100kΩ in combination with a 25.5kΩ load resistor.
If you are looking for a PCB-based solution, you can take a look at my clone designs:
Replicas of Covox Speech Thing, FTL Sound Adapter and SiliconSoft SoundJr
Reply 4 of 18, by BitWrangler
Parallel ports were disappearing rapidly in 2005, you're sure you've got one? 🤣 Just checking.
Reply 5 of 18, by Benedikt
BitWrangler wrote on 2021-08-11, 03:19:
They were disappearing from the ATX IO area, but most motherboards from that era should still at least have a parallel port pin header.
Reply 6 of 18, by Xses
Gigabyte ga-k8ns rev2 - parallel port and dual floppy
Reply 7 of 18, by Xses
Benedikt wrote on 2021-08-09, 09:56:
BTW.: The original uses an R-2R resistor ladder with R=100kΩ in combination with a 25.5kΩ load resistor. If you are looking for […]
Thx, but I want to build one with a headphone amplifier based on lm386 and buffer based on some generic opamp and I want to mount it to PCI card bracket.
Reply 8 of 18, by Jo22
Xses wrote on 2021-08-12, 11:03:
[..] I want to build one with a headphone amplifier based on lm386 and buffer based on some generic opamp and I want to mount it to PCI card bracket.
Hi, you maybe can use that internal Covox schematic for this:
Re: Covox speech thingy!!!
PS: Other interesting Covox threads:
Rainbow Arts Soundman ? Adlib Clone - can it play Digital Sound ?
Covox Sound Devices
self built covox produces static
This one is an older posting of mine (I'm sorry),
but it has a picture of the real Speech Thing and some links related to it.:
Re: DSS / Covox Speech Thing exclusive games
Reply 9 of 18, by Xses
Jo22 wrote on 2021-08-12, 11:27:
Thx. Indeed, C560/AD558 is a great solution, but even though I am in Eastern Europe those ICs are crazy rare and expensive.
Reply 10 of 18, by Xses
C560/AD558 is pretty much Covox in one IC.
Reply 11 of 18, by Benedikt
I don't think that the opamp buffer is necessary here. Using the unbuffered output of the resistor ladder as input for the LM386 should be sufficient.
For instance, the resistor ladder configuration described above will result in a line-level input signal when combined with an amplifier with 10kΩ input impedance.
Reply 12 of 18, by Jo22
What about using an EF95 (6AK5) tube in the future ? 😀
It's pretty common in the east/far east, I assume.
There's an headphone amplifier project that involves one (or two).
http://www.elexs.de/ef954.htm (English Translation)
In fact, I've built such an amp (mono) myself for a Pi running MT32-pi..
https://www.youtube.com/watch?v=Y43kYMGZhKk
Of course, it's all about having the right impedance an efficiency.
Tubes often have a high impedance ouput and nowadays devices are usually of low impedance.
An 32 ohms loudspeaker is harder to drive than a pair of headphones, also.
So in some situations an output transformer is needed, which also provides galvanic insulation and DC-free audio.
Or high impedance headphones. Like the AKG K141 Monitor (2x 600 ohm).
Classic headphones from the crystal radio era had 2K ohms, even. 😀
Anyway, if the low impedance headphones are efficient, they may also work at an adequate volume nevertheless.
Edit: For proper working, EF95 normally needs 35v or higher anode voltage, if memory serves.
For ~12v usage, the EF98 (also EF97) used to be better suited.
These were true battery tubes, meant for car radios et cetera.
Reply 14 of 18, by BitWrangler
Out of curiosity, I just cracked open a bluetooth speaker, one of those cheapy mono ones. I was wondering if they had a bluetooth chip and a DAC etc.. no the BT is one all in one SOC that handles battery charging and everything... BUT... there is an 8002 amplifier chip in there, they run off 5V.. that looks real easy to use in applications such as this, even if you just get the IC separate and don't mod a BT speaker. In this particular one, there would be room inside to put the whole DAC in there. However, should I mod it, I might just break the input to the 8002 and insert a switched 3.5mm stereo jack in. Then it would be general purpose.
Reply 15 of 18, by Xses
I thought about using Russian 1j24w (1Ж24Б) pencil tubes because they are great for such application, they are small, through-hole and they work perfectly on 12V on the anode and 1.2V heather (and I can buy them here for ~$1.5), but I've already done headphone amp using them and OPA2134, so I can just plug that as well. There is also a power version of that thing and probably would be great for OTL. But I am done with tubes.
Reply 17 of 18, by The_Retro_Jimmy_Club
Hay I read your post found hear
Covox Speech Thing/LPT Sound Card Software/Emulator for 2005ish PC with MSDOS
Do you sell them? or if not then do you know anyone that dose?
Thanks
Reply 18 of 18, by digger
For people stumbling upon this thread, you might want to take a look at the Picovox project as well.
TL;DR: The Picovox is a fairly cheap single parallel port device that emulates Covox Speech Thing, Disney Sound Source, OPL2LPT and other parallel port sound devices.
