The "Driver CD" for motherboards thread
Reply 40 of 104, by SETBLASTER
vmr_ wrote on 2021-05-24, 16:30:
I think I have somewhere the original CD for Gigabyte ga-5ax, possibly Asus P5a as well. Have to dig it out from storage 😀
Not sure about AOpen ax59pro, have to check
did you find anything?
Reply 41 of 104, by xXmobiusXx1
I need the Asus M200 " TUSL2-C " Motherboard CD, Say someone in this thread has or had it but never uploaded it to the vogons drivers database.
Reply 42 of 104, by Vipersan
Hi ...
I wonder if anyone has an iso image of the original installation/driver CD for an ASUS A 7N266-VM.
on which I've got windows NT4 running ...without network or sound.
So chipset drivers for NT4 needed.
Apparently these are on the CD.
rgds
VS
Reply 43 of 104, by Horun
xXmobiusXx1 wrote on 2021-08-02, 13:31:
Perhaps Setblaster will share his copy
Also Maybe you should read this: Support disk for Asus TUSL2-C? also the picture shows a cd but is not M200 and starts with a 1 like 186/188/etc
Most of the Driver CD's are posted to Archive.org because of size (if all full CD's were on Vogons Drivers then Squallstrife could quickly run out of storage space)
Reply 44 of 104, by Horun
Vipersan wrote on 2021-08-02, 23:44:
Hi ... I wonder if anyone has an iso image of the original installation/driver CD for an ASUS A 7N266-VM. on which I've got wind […]
Hi ...
rgds
VS
Have not seen a driver CD for that motherboard but do know it came out in 2002 and Win NT4 is not on it's full support list. Win9x, Win ME, Win2k and XP are on the full list.
http://web.archive.org/web/20021014231049/htt … vm/overview.htm
http://web.archive.org/web/20021005074726/htt … ecification.htm
And if you look thru this page: http://web.archive.org/web/20021016120137/htt … =10&l3=16&mid=4
You will see the drivers from Asus old archive and not one mentions NT.
If you search Realtek you do find one: https://www.realtek.com/en/component/zoo/cate … codecs-software
Good luck !
Reply 45 of 104, by PC Hoarder Patrol
Horun wrote on 2021-08-03, 01:20:
Have not seen a driver CD for that motherboard but do know it came out in 2002 and Win NT4 is not on it's full support list. Win9x, Win ME, Win2k and XP are on the full list....
There's one on the Bay which supposedly supports this nForce baord - search for the board model + the Asus CD code which is M261
Reply 46 of 104, by Vipersan
PC Hoarder Patrol wrote on 2021-08-03, 08:01:
Yes I had seen that on ebay ....
what put me off was the cost which with shipping from the US to the UK was very high...plus not available atm 'the seller is away until 17th aug'..
What gave me hope the CD might help me with NT was this text snippet referring to the network/chipset I found on the net
"Realtek RTL8139/810x Family 10/100M Ethernet Controller User's Guide for Windows NT
1. Right-click the "Network Neighborhood" icon on the desktop window.
Select "Properties" item while menu appears.
Or you can also press the "Start" button. Move highlight bar to "Settings" and
select "Control Panel". Double click on the "Network" icon.
2. Select "Adapters" page and then click Add button.
3. Click the "Have disk..." button.
4. Type the path {CD-ROM Drive}:\Drivers\Lan\8100C\winnt\ to the driver
5. Select "Realtek RTL8139/810x Family 10/100M Ethernet" item and click OK.
6. Windows will install the driver immediately.
7. Follow the instruction to complete the installation.
8. Please restart Windows NT system when prompted.
Thanks for the reply ...it is appreciated.
Reply 47 of 104, by PC Hoarder Patrol
Vipersan wrote on 2021-08-03, 08:19:
Yes I had seen that on ebay .... what put me off was the cost which with shipping from the US to the UK was very high...plus not […]
Did you try the LAN driver off the ASUS A7N266-VM support page...it seems to include NT support
rtl8100c_451505.zip
Reply 48 of 104, by Vipersan
PC Hoarder Patrol wrote on 2021-08-03, 09:04:
rtl8100c_451505.zip
Yes I had ..
In fact ..I think the text I quoted earlier is from the Text file in that Zip
Reply 49 of 104, by vmr_
SETBLASTER wrote on 2021-06-20, 18:39:
yes, I am away and will create the ISOs towards the end of August.
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 50 of 104, by PARKE
There is still a copy available via Dropbox. If you send your email address via PM I can hook you up for sharing.
Reply 51 of 104, by Horun
Hmmm the ASUS A7N266-VM manual says Realtek 8201L PHY so the website driver will work but you need proper nForce 220-D drivers for NT first other wise the network driver will not work (is tied to Southbridge).
and this review says: Realtek ALC650 audio: http://www.mikeshardware.com/reviews/review_a … -vm_review.html
so the above audio driver I pointed too should also work but you need the NT 4 chipset drivers working first (generic NT 4 drivers will not help with the LAN or audio AFAIK) and have searched but cannot find any yet.....
Am not buying a driver CD if I cannot see what is actually on it. Am going to ask the seller to email me the FILELIST.TXT from M261 will see what happens....
Reply 52 of 104, by Horun
PARKE wrote on 2021-08-03, 12:32:
Thanks Parke ! Uploaded Asus M200 to Archive org per our PM so others can have easier access: https://archive.org/details/asus-m-200-i-815-tusl-2
Hope you do not mind the way I did it. Thanks again !
Also going to be adding a few others that have been sitting on when have time.
Reply 53 of 104, by Vipersan
Horun wrote on 2021-08-04, 23:46:
Hmmm the ASUS A7N266-VM manual says Realtek 8201L PHY so the website driver will work but you need proper nForce 220-D drivers […]
Thanks for helping out with this...I really do appreciate it.
I am using a pull out ide hard drive caddy system..
So far I have Win95 with cpu patch running ..(sort of)
Win 98se with ram restricted in the system ini.....and ME
& Win 2K
Thus I can leave 1gb in situe to run XP...
Obviously win 3.1 is not suitable ...and NT4 is the only OS I cannot get to reasonably function.
So ..NT4 for a full house ...
I remain hopeful
I was tempted to buy that driver cd listed on ebay ,,,,until I saw what the cost of postage from the US to the UK was ...3x the cost of the cd itself ....farrr toooo expensive for me.
..and of course no guarantees the chipset drivers for NT4 would be on it anyway.
Reply 54 of 104, by Horun
No word yet on that CD but my guess is not good for NT4. The nVidia website has drivers for nForce 1 and 2 chipsets (the 220 and 420 are nForce 1) and no NT drivers...just Windows ME, Windows 98, Windows 95, Windows XP, Windows 2000.
Also no Vista, Server 2003 or 64bit OS drivers...
Reply 55 of 104, by BLockOUT
i like this topic, sometimes the original cd is just lost, and its all about the experience of building a retro computer, and insert the driver cd with the menu, like a jump in time. its about the experience. I'm glad many here still kept and share the CDs
Reply 56 of 104, by Horun
I added the ECS driver CD v6.2S that came with my ECS K7S5A. It has drivers for these ECS boards:
K7AMA; K7s5a; K7s5a2; K7SEM; P5SS-ML; P6s5a2T; P6s5aT; P6s5mT; P6SEP-Me; P6SET-ML; P6SSM; P6SSM2; P6STB; P6STM; P6STP-FL; P6STP-Fn; P6STP-ML
https://archive.org/details/ecs-k-7-s-5-a-cd-6-2-s-driver-cd
Reply 57 of 104, by Vipersan
Added yet another WinOS build to my retro build with the Asus A7N266-VM motherboard ..
This time WinME.
Fully functional and stable.
So that leaves 95 and NT4 which both function ok without Sound or Networking.
Lack of suitable chipset drivers...and may never work fully,
Lack of PCI slots make adding PCI cards to rectify this a constraint.
I do have an ASUS 7700 video card installed in the AGP slot so a decent higher res vga output for all the OS's
On a related yet different issue ..I have a driver CD for a nforce2 ASUS chipset coming & arriving soon
NVIDIA nForce2 Series Rev 44.03 PC Motherboard Software | CD-ROM | PN:M286 |
When it arrives I'll image this and pop it in my dropbox if anyone wants it ?
rgds
Reply 59 of 104, by Vipersan
I was amazed to see a meassage in my indox this morning...in relation to the M261 CD in the USA
I was offered a 10% discount on account I'd shown an interest in the item on fleabay.
needless to say I wont be taking up the offer.
Not that I dont want the disc ..but the postage and possible import duties far exceed the cost of the CD
I'll attatch a screengrab so you can see just how ridiculous the offer is in this case.
I may be a bit daft ...but I'm not crazy
Ironically shipping internally in the US is free..I believe
