Writing DOS device drivers in C
First post, by Oerg866
Hello,
I've been collecting some resources for a small project of mine, I wish to write an installable DOS device driver - i.e. something you load from within CONFIG.SYS. Coming from the ARM / m68k world I absolutely despise x86 assembly, moreso after all the reverse engineering projects I did, and I'd rather not deal with that.
I've found a few resources (that are ancient) to write installable device drivers in C, but most of these resources seem to be long gone. The most modern thing I could find were documents referencing Microsoft C 4.0 and Turbo C 1.5 (so late 80s stuff, very early 90s at best). I have no problem using either of them but I don't feel confident enough that they will work on, say, DOS 7.xx.
Any pointers would be appreciated
Best regards,
Eric
Reply 1 of 54, by maxtherabbit
Oh man this is a tough hill to climb these days, finding documentation is nearly impossible. I have some resources saved from my work on the dosfdrv that I'll try to dig up and post for you
Reply 2 of 54, by cyclone3d
One book you can get is:
Writing DOS Device Drivers in C
Phillip M. Adams / Clovis L. Tondo
ISBN 0-13-970864-2
As far as DOS versions, I don't see why older stuff wouldn't work on newer version of DOS. I've never seen an old DOS driver that wouldn't work on a much later version of DOS.
Edit:
What would be extremely nice to find would be the edition of that book which was released in 1999 and updated for DOS 6.x
ISBN-10: 0-13-108622-7 / 0131086227
ISBN-13: 978-0-13-108622-7 / 9780131086227
I have not been able to locate a copy anywhere.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 54, by Oerg866
Thanks for the infos, I will try to find these books 😀
Looking forward to what you have @maxtherabbit!
EDIT: The German national library in my city (well, I live 20 miles north now) has an edition of this book, I will go there sometime next week and try to get it.
Best,
Eric
Reply 4 of 54, by BloodyCactus
I think the difficult part would be the two entry points, doing that in C. You'd probably have to shim that with assembler, and do it in small memory model so no relocations.
I've written some in a86 + ported them to Nasm later on, and its pretty simple stuff, but in C that might be difficult.
Reply 5 of 54, by AlexZ
16bit real mode x86 assembly wasn't difficult at all, it was taught at university and we did small projects using it. It gets translated into machine code so it's not like you're writing the machine code directly. It's more convenient than writing in something like hiew editor as you can organize code in asm files.
If that book is that rare and it's good it may make sense for you to have the whole book copied.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 6 of 54, by cyclone3d
The 1990 edition of the book is all over the place. I saw mention of a 1991 edition but didn't look into it.
If the library has the 1999 edition.. or any edition after the 1990 edition, copying / scanning it would be helpful.
YMF7x4 Guide
Reply 7 of 54, by carlostex
I've learned real mode x86 assembly and i'm not very bright. I did it, anyone can do it
Reply 8 of 54, by Oerg866
Yes, I am intellectually capable of doing it, but I could think of many many different ways I'd rather spend my time 😜
Reply 9 of 54, by kjliew
That is perfectly possible with 16-bit MSVC 1.52 and MASM 6.11, but you still need basic x86 ASM knowledge to establish the ASM framework that interfaces with DOS while most of work will be done in C functions. You can also search in simtel/garbo ms-dos archives if libraries provide such framework already existed before writing your own. This is the nature of low-level programming in the early days, including Win9x VxD. The VtoolsD (a commercial MS DDK supplement) provides exactly the missing link from Win9x DDK, that is the x86 ASM framework that interfaces with Win9x kernel, for developers to focus on driver's functions in C.
Reply 10 of 54, by BitWrangler
Don't know if this gives you any clues in terms of what has to happen when http://archive.retro.co.za/archive/computers/ … NFO/DEVDRIV.ZIP
Dig up that tree though, other low level hardware stuff in that dir, then back to computers there's more tech ref directories.
On the uncreative labs site in the text directories, there's source code of a SCSI driver I think.
Reply 11 of 54, by Caluser2000
BitWrangler wrote on 2021-08-16, 02:26:
Crikey that's a name I haven't heard that name in a wee while. Was one of my favorite haunts.
Reply 12 of 54, by Predator99
If you are from germany I recommend "PC Intern 2.0" by Michael Tischer. Its very well explained there together with examples. Dont remember if its only assembly or also C.
It depends on what are you planning to to but in many cases a COM TSR can do the same as a SYS device driver. A COM is much easier to program and you can load it at any time.
Reply 14 of 54, by amadeus777999
Found a snippet I downloaded a while ago.
Reply 15 of 54, by BloodyCactus
amadeus777999 wrote on 2021-08-16, 19:27:
The second edition of that book is good, Advanced MSDOS Programming 2nd Edition. I remember using it.
Reply 16 of 54, by pan069
Oerg866 wrote on 2021-08-15, 19:32:
Thanks for the infos, I will try to find these books :) […]
Best,
Eric
In the 90's there was a very popular book going around in Europe called "PC Intern". It was originally by a German author called Michael Tischer and was translated into various languages (I still have a Dutch translation sitting here on my bookshelf). It might be worth hunting down a copy of this, it has an incredible amount of information in it, including DOS device drivers. Looking through the ToC, it doesn't seem to have a DOS driver in C examples (only assembler), which is probably more suitable for this kind of thing.
In any case, maybe something to look into.
Reply 18 of 54, by the3dfxdude
amadeus777999 wrote on 2021-08-17, 06:17:
BloodyCactus wrote on 2021-08-16, 21:27:
Good to know, I'll see if I can find a used version online.
I have the book. It's a deep reference so you can develop anything for DOS, and assumes you know C & ASM. But it doesn't really explain writing device drivers in C, only covers in ASM. It would be a good reference if you want to know how DOS works. I wouldn't fault it if that it isn't really what you are looking for, but I think that some stuff really can only get done in ASM anyway, so you might want to get a reference anyway, and be ready to learn some ASM.
Reply 19 of 54, by hyoenmadan
Really anyone did serious DOS drivers in C, besides some well know brand Antivirus TSRs? Even up to Win98 timeline there were still VxDs from some well known brands fully written in assembler, and these being Display Drivers on top of that. Is hard to imagine DOS device drivers written in anything high language, even if that language is C.
Just curious.
