Art of CGA
Reply 100 of 106, by Benedikt
ninjapig1212 wrote on 2021-08-16, 04:29:
Data algorithm methods are beyond my capabilities as of now. I should learn them already.
There are areas that I want to show with "pattern" (ordered) dithering, they get dithered in photoshop, cut out, and pasted on top of another instance of the same image that was diffusion-dithered. After that, if I notice pixels that I don't like or if I feel more lines are needed, new pixels are painted onto the image.
AFAIK, Photoshop uses this algorithm for arbitrary palette pattern dithering: https://patents.google.com/patent/US6606166
FYI: The patent expired two years ago.
Reply 101 of 106, by mkarcher
ninjapig1212 wrote on 2021-08-16, 05:53:
Omg I was using the wrong colors this whole time. Thank you for pointing this out. […]
dr.zeissler wrote on 2021-08-16, 04:56:
The colors are not so good on a real cga-machine.
Wrong: FF0000, FFFF00, 00FF00, 000000
Correct: FF5555, FFFF55, 55FF55, 000000
Remeber that this color set is also available: AA0000, AA5500, 00AA00, 000000. This is less bright, has brown instead of "dark yellow", but has a higher saturation on red and green.
Reply 102 of 106, by Jo22
Officially, CGA had two "palettes" only (1, 0).
However, there are also two intensity levels available for them (high, low).
Unofficially, there's a third palette, also.
So in practice, there are more different colours available.
Just be aware that the unofficial stuff might be not necessarily supported by all CGA compatibles. 😉
Palettes overview:
https://lospec.com/palette-list/tag/cga
The CGA Compatibility Tester can display those palettes, if memory serves.
http://www.oldskool.org/pc/cgacomp
Reply 103 of 106, by dr.zeissler
I checked the pictures converted in GIF with compushow. with "cshow" you can watch the image in all possible ways. (1-4 CGA Pal, Mono-Hires, Plantronics) great image-viewer for low-end.
Reply 104 of 106, by Jo22
Reply 105 of 106, by dr.zeissler
Real machine 😀
    1.71 MiB
    1.52 MiB
    1.53 MiB
    1.42 MiB
    1.55 MiB
Reply 106 of 106, by reenigne
I came across these today - they definitely belong here: https://twitter.com/pinot/status/1426567442466226178 and https://twitter.com/pinot/status/1427678504053792779
