First post, by retrogamerguy1997
After losing my Abit BH6 Pentium 2 build to magic smoke and not being happy with the performance on the hp machine I had, I decided to bring back my Prescott 2M Pentium 4 build with XP Pro on it. I then recently found myself randomly cheking the prices of a board that i used to have in 2010 and 2011, the ASUS A7M266. While the prices were mostly as inflated and aweful as you expect on ebay, there was one listing that caught my eye. The listing I found had the motherboard, a 750Mhz Athlon, a mini orb cooler with modified wiring, and 2 sticks of 128MB DDR RAM all for $30 + shipping. The seller stated that he had tested it and that it POSTed. So I decided to grab it since the specs are very similar to what I had back in the day (except for the cooler and I used to have one stick of 256MB of ram rather than the 2 128MB sticks that came with the bundle). Few days later and it arrived.
Upon opening the box I found an I/O shield that wasn't compatible with my case, and then unwrapped the motherboard with the parts intact and installed on the board. I found the cooler had two fan connection cables and later due to asking around here and on discord, I found out that it is indeed supposed to have that, but one of the cables have been modified. I took a guess and hooked up the shorter one to the CPU_FAN header then hooked up the other to the CHA_FAN header around the bottom. I installed the motherboard in the case I previously used for the P2 system and then installed a diamond media viper V550 graphics card that I previously used as well. On initial testing, the motherboard did not power on. after fiddling with the front panel connectors, the system powered on into the BIOS. I then powered down again to install the floppy drive, cd drive, hard drive, and the ide and floppy cables. I also before hand installed a new bios battery since the one that came with the board died.
I begun the process of installing Windows 98SE. Seeing as I already had a computer with XP and the hard drive in this build being only 8.4GB, it only made sense to me to run 98SE. As of right now that's the farthest I've gotten, no drivers, no games, no anything. I think I want to wait until I have things finalized. I am thinking that maybe I should get a better graphics card, and maybe possibly finding another cooler that isn't so loud. The only AGP cards I have is the Diamond media Viper V550 I have installed and a rage 128 pro. I also have a geforce MX4000 pci graphics card that is a bit picky about how it sits in the computer. The latest game I can think of running on it is Midtown Madness 2 and I haven't actually tried that game with either of the agp cards.
As of right now I consider this incomplete and I haven't taken any pictures yet until I consider it done
EDIT: Tested the Rage 128 Pro, doesn't work at all. As for my PNY MX4000 PCI card and there was no specific model number but after searching through images, it appears to be a model that is a 64-bit card and has 64MB of DDR video memory.
Reply 1 of 17, by BitWrangler
The 128 Pro was comparing favorably against TNT2, so is better than OG TNT and a DX generation higher. Then I think the TNT Ultra pwned it so they had to bring out the Rage Fury MAXXXXXXXXXX or something. Whether the MX4000 gets you anything depends on how crappy it's memory setup and PCI implementation is, hearsay I heard back in the day was to avoid MX4000 cards because they were slower than MX200s, so that might only put it level with the 128 Pro, but you get DX7. You may find this commentary on the 128 Pro useful... NVidia Riva TNT2 or ATI Rage 128?
Reply 2 of 17, by AlexZ
Definitely TNT2 over Rage 128 pro as TNT2 has better DOS compatibility which you want from a retro rig. Back in the day when I had rage 128 I didn't play DOS games anymore so I didn't care. Windows 98SE supports up to 120GB drives which is endless space for that era. You can also have single partition for DOS.
If you want your rig to last, get a spare board.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 3 of 17, by retrogamerguy1997
AlexZ wrote on 2021-08-20, 20:21:
What are the prices for a TNT2 based card right now on ebay? I don't really see myself wanting to spend more than $50 ($60 absolute limit) on additional parts and I know how the retro scene can be. If I can get a card for $20-30, what kind of storage upgrade should I try to get with the remaining budget.
EDIT: Found a "Aztech Nvidia RIVA TNT2 128-bit 32MB AGP 4X" for $20, was aztek a good brand?
Reply 4 of 17, by AlexZ
retrogamerguy1997 wrote on 2021-08-20, 20:49:
I don't usually buy anything from ebay unless it's very hard to find elsewhere. The problem of ebay is you're competing with too many people which results in higher prices. If you want to buy from ebay, be patient until something cheap comes up.
I spent like $5 on my Riva TNT2 pro. I bought graphics cards in a pack - I hand picked those I wanted. I tend to buy only the very cheap ones.
Beware, many TNT2 model 64 are being sold on ebay. Ask seller for picture showing model number/type for verification or compare it with picture you find on google.
Reply 5 of 17, by retrogamerguy1997
AlexZ wrote on 2021-08-20, 21:12:
I don't know how else to buy retro hardware. the only place I know is ebay.
Reply 6 of 17, by Brawndo
The AMD socket A platform has a special place in my heart, as I rocked a custom built one throughout the first half of my 20s, and spent many a night gaming on it. I remember it well, and as a matter of fact I plan to more or less recreate the same system I had as closely as possible. I already have the same case (Thermaltake Xaser V) and I need to get a MSI K7T266 Pro2 motherboard and AMD 1.2 Ghz Tbird CPU. I had a SB Live! and I don't remember which video card, but I did have a Radeon 9800 Pro for awhile. It's a solid platform which will take you well into the XP era.
Like you I buy stuff on ebay often, because I'm very particular about what I want and it's borderline impossible to find such specific hardware locally. I won't buy the ridiculously priced stuff though.
Reply 7 of 17, by retrogamerguy1997
Brawndo wrote on 2021-08-21, 05:16:
Yeah I almost want to max out the system and buy the highest end CPU and RAM but that would be too much probably
Yeah I live in a small town surrounded by farm land, I doubt that there is anything sold locally even if I knew how to shop locally for retro parts. ebay is the only place I know where to get retro parts period. I'm still wondering if it would be worth buying a TNT2 card, or if my MX4000 PCI card is better and i should just stick with that.
Reply 8 of 17, by retrogamerguy1997
Decided to remove the Viper v550 and install my geforce mx4000 and also got the Aopen YMF744 card in as well. Got the drivers installed and after doing the canyon.mid test things appear to be working just fine so far. Haven't tested any dos games, but the control panel that comes with the drivers shows an IRQ of 5 so that should be fine. Still trying to decide on what storage upgrade to make.
Reply 9 of 17, by retrogamerguy1997
I installed Midtown Madness 2 which installed DirectX 7.0a. After that Windows 98SE wasn't shutting itself down properly. So after seeing the Windows is shutting down splash screen for a good couple minutes I held down the power button. Booted Windows back up and MM2 is glitching out like crazy. NFS3 has two mouse cursors now, one that is the normal windows cursor that won't go away or move. Even after reinstalling directX from the MM2 CD, same issues persist. And again Windows wouldn't shut itself down fully. Rebooting is fine, just not shutting down. I tries Installing DirecX 9.0c Dec 2006, same issues persist.
Reply 10 of 17, by Tetrium
retrogamerguy1997 wrote on 2021-08-22, 17:21:
Got any pics? 😜
Anyway, a bit on the late side but an MX4000 is a big upgrade from a Diamond Viper 550 (TNT1 16MB). I found the TNT1 even slow for my Pentium 2 350MHz especially when trying to ... 'play' a game using 32 bit graphics 😜
My retro rigs (old topic)
Report spammers here!
Reply 11 of 17, by retrogamerguy1997
Tetrium wrote on 2021-08-31, 17:18:
Got any pics? 😜
Yeah, I actually did post some pics elsewhere like a week or two ago. I'm still a bit pissed off though I can't play Midtown Madness 2 and that literally nobody has offered any help for that issue and issues with NFS3 I've mentioned here and well other places I've brought up the issues. And I also get a headache playing HL OpForce because the windows cursor keeps flashing in and out of existence. These issues have discouraged me from even turning on the system.
https://imgur.com/a/z6vtI4f
Reply 12 of 17, by chinny22
This post has lots of good info
Good value Win98 Graphic Card
but in short you can't really go wrong with a GeForce 2 MX400 or above.
TNT2 is fine if gaming at 800x600 but will struggle if you want to game at higher resolutions.
Don't play MM2 but the NFS3 cursor issue sounds familiar, have you tired different graphic card driver version? Are you using any unofficial patches?
Reply 13 of 17, by retrogamerguy1997
chinny22 wrote on 2021-09-01, 09:21:
Well the cursor issue in NFS3 didn't occur until after installing directx 7.0a and continued after DX 9.0c was installed. I haven't tried other driver versions and I'm only using the official patch made by EA.
Reply 14 of 17, by chinny22
You can try the final drivers that supported TNT
http://download.nvidia.com/Windows/71.84/71.8 … n9x_english.exe
I know most people like drivers closer to the games age and the thinking is valid but I haven't had much trouble with later drivers myself.
Reply 15 of 17, by retrogamerguy1997
chinny22 wrote on 2021-09-01, 16:30:
I'm using the MX4000 card in my pc, nvidia driver version 81.98.
Reply 16 of 17, by chinny22
That's the same driver I'm using with a Ti4600, I'm also using Dx9. Well I was until last post.
I accidently installed those TNT drivers on my rig and Windows DID NOT like that! simple reinstall of 81.98 isn't working.
maybe old drivers are conflicting and try a clean install? That's what I'll be doing now as well.
Did you install any chipset drivers? I know AMD side of things aren't as well supported as Intel out of the box.
My Slot A rig with a Banshee misbehaves in Windows GUI when typing it wont remove characters if renaming folder, typing in text documents, etc. Bit annoying but plays games fine so haven't spent much time troubleshooting.
Reply 17 of 17, by retrogamerguy1997
chinny22 wrote on 2021-09-03, 10:46:
That's the same driver I'm using with a Ti4600, I'm also using Dx9. Well I was until last post. I accidently installed those TNT […]
I only installed the one version of the nvidia drivers. Outside of that I don't have any chipset drivers installed or where to find them.
