Varta's out. Now what?
First post, by Badscrew
So what is the consensus on the replacement of the rechargeable 3.6V Vartas?
I miss the times when my BIOS could remember things 😁
Reply 1 of 24, by Ydee
I dont know, what is consensus - for me is solution CR2032 holder on external battery pins and desoldering leaked 3,6V Varta...
Reply 2 of 24, by Badscrew
CR2032 is lower voltage and isn't a rechargeable - isn't there a risk damaging the battery?
Reply 3 of 24, by Kotu Koylu
Badscrew wrote on 2021-08-22, 12:52:
External battery pins does not charge CR2032.but u r right some mobos doesnt like cr2032 so forget cmos settings.
You need 3.7 rechargeable lion batterry
Reply 4 of 24, by Badscrew
How about using a pack of three low capacity Ni-MH AAA rechargeables? Will this work as an easy drop-in?
My MB doesn't have any dedicated "external battery" pins, only the ones where the Varta was soldered on.
Reply 5 of 24, by zapbuzz
there re varta style batteries around at 3.6v rechargeable varta is one of several brands but its the battery type you need search for.
Reply 6 of 24, by paradigital
LIR2032 is a drop in rechargeable replacement for a CR2032. So I’d go with one of those plus a holder.
Reply 7 of 24, by Badscrew
LIR2032 is a drop in rechargeable replacement for a CR2032 but not for the 3.6V Varta ? 😁
Reply 8 of 24, by Badscrew
Oh wait these LIR 2032 are 3.6 or 3.7 V, not 3.2 as I was thinking.
Worth a look then, interesting
Reply 9 of 24, by Ydee
You can still buy some NiMH 3,6V rechargeable battery, compatible with old NiCd 3,6V, if You don´t have external abttery pins on Your mobo https://uk.farnell.com/c/batteries-chargers/b … ry-voltage=3.6v
Of course, You can use pack of 3x1,2V in serial connection.
Reply 10 of 24, by paradigital
Badscrew wrote on 2021-08-22, 14:17:
Sorry, yes I meant a physical size replacement for a CR2032. So a CR2032 holder plus an LIR2032 would be a good varta replacement.
Reply 12 of 24, by Ydee
Li-(Ion, Pol) batteries have different charging characteristics, so they can't simply be plugged into an existing circuit. NiMHs aren't the exact replacement for NiCd batteries either, but from rechargeable ones the closest.
Can also be used non-rechargeable, but with a protective diode, blocking recharging from the mobo. The 3V voltage of CR2032 is not a problem for most plates, the BIOS settings reliably hold.
Reply 13 of 24, by britain4
I was warned against using NiMH rechargeables when I last looked this up in the following thread:
jaqie wrote on 2012-02-19, 15:16:
NiMH would be very dangerous to do that with - they are tempermental on how they are charged. not nearly as bad as lithium types though! NiCD would be perfect but remember they can leak like the originals, too.
Barrel style CMOS battery question
I ended up using the 3x alkalines with a 1N4002 diode in series suggestion - works a treat if a bit bulky with the 3 AAA holder.
This was for a direct replacement of the leaky Varta - if you have an external battery header you’ve got more options. Another idea I liked was to disable the charging circuit directly on the board (by removing resistors etc) and just fitting a CR2032 battery holder but obviously you have to know what you’re doing there.
- 486DX2-66, SoundBlaster 16, Crystal VLB graphics
- P-MMX 200MHZ, PCChips M598LMR, Voodoo 1, AD1816
- PIII 933MHz, MSI MS6119, Voodoo3 3000, SB Live!
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500, SB Audigy
Reply 14 of 24, by Badscrew
Leaning towards 3 AAA in a holder and a diode myself. Cheap and effective, easy maintenance.
Reply 15 of 24, by Caluser2000
Badscrew wrote on 2021-08-22, 18:46:
Use rechargeable AAAs instead. No diode required then.....
Reply 16 of 24, by Badscrew
Regulars are cheaper 😁
Reply 17 of 24, by maxtherabbit
I support this
Are you sure you don't have an external battery header to plug it into though? Can dispense with the diode if you do
Reply 18 of 24, by Badscrew
It doesn't seam to - and it's also a weird off-brand 486 MB I can't find the docs to.
I have like dozens of diodes anyway, so not a big deal 😀
Also, using a diode with 3 alkalines will drop the voltage from 4.5 to about 3.8- 3.9V that will be closer to 3.6. Not that BIOS should care anyways but at least better on paper.
Reply 19 of 24, by maxtherabbit
Badscrew wrote on 2021-08-23, 14:36:
The RTC chips have a very wide range of acceptable standby voltage input, anything from 3-5V should be perfectly fine
