First post, by Martijn1974
I'm playing around with an old P2 - 266Mhz system.
The idea is to have a few swappable HDD's, each with a different OS on it, like this;
HDD-1 WD Caviar 40GB : MS-DOS 6.22 and WIN 3.11
HDD-2 WD Protege 40GB: WIN95
HDD-3 (yet to be bought) : Win98
Well at the moment HDD-1 is installed and operating fine.
Now I want to get HDD-2 working...and that's not going at all.
Because I can't get any boot-disk to work I've installed DOS 6.22 on HDD-2 without a problem. But after power up and initialising the BIOS the system stops. Only to have a blinking _ in the bottom left corner (no drive letter). It doesn't continu to load DOS, no matter what I type or do.
When I swap HDD-2 for HDD-1 it loads fine, so I dont think its the Mainboard/IDE/cable.
Both HDD's are jumper "Master", and IDE detection is auto.
I find this very strange because The mainboard (ASUS P2B) finds and identifies the HDD-2.
I can install MS-DOS on it without a glitch.
I can even work on that HDD-2 via a dockingstation on my i7 ASUS ROG Strix running WIN10.
Both HDD-1 and HDD-2 are partitioned and formatted by the MS-DOS installation so they should be the same and the DOS version works on HDD-1.
If I place HDD-2 in the PC as a "Slave" to HDD-1 I can use the Win 3.11 FileManager to read and write to the HDD-2 no problem. So the disk does work in the P2B system (basically everywhere)...it just refuses to boot.
This is driving me nuts... who could help me with some advice or tips??? please!!
regards,
Martijn.
Main PC : ASUS ROG Strix G15CK.
Rebuild : P2-266Mhz 1998.
(Sorry for the typo's and grammar, English is not my first language)
