Reply 540 of 2224, by feipoa
- l33t++
I tested new IDT 12 ns DIP SRAM on the UUD board, but it offered no timing advantage compared to 15 ns when run at 66 MHz. The "fake" Chinese 10 ns Winbond DIP SRAMs also offer no advantage at 66 MHz compared to 15 ns.
EDIT: I also tried the IDT 12 ns SRAM modules with an AMD "DX2" (really an Am5x86-133 with 2x multiplier) at 60 MHz x2, but I cannot use anything faster than 3-2-2-2. Your ability to run 60x3 with an Am5x86 at 2-1-1-1 is astounding. Is it just that one particular set of SRAM modules you have which allow for this? And if not the response time, what makes those modules so special?
EDIT2: I tried the 12 ns IDT modules at 50 MHz x 3 and they couldn't cope with 2-1-1-1. I put my old Winbond 15 ns, and later Alliance 15 ns, modules from 1995 back in and they can cope with 2-1-1-1 at 3x50 MHz. So what's up with the brand new 12 ns modules? They weren't cheap.
