CPU load reduction for Windows 3.1
First post, by valnar
I was poking around the Internet for a utility that would reduce my CPU in Windows 3.1 the same way DOSIDLE works for DOS - mainly for VPC and VMWare. I run installations of Windows 3.1 in a variety of VM's.
I came across a nice small one that was written just a year ago.
http://www.weiqigao.com/software/
It not only works well for VPC, VMWare and QEMU, but for DOSBox as well.
Robert
PS. I do not know the author or endorse the utility, other than it works for me and every Windows 3.1 install I've tried so far - real or VM.
Reply 2 of 40, by valnar
I've noticed one minor anomaly. I only notice this on my (slower) Centrino laptop, not my faster Athlon64 desktop PC.
Without the CPU idle device driver, when I click on a program within Program Manager, it follows click--> quick hour glass --> program launches.
With the driver loaded, the hour glass step is replaced with a minor pause. Everything still works though, so far.
-Robert
Reply 3 of 40, by abyss
Does that pogram have viruses in it because it would be quite useful to use.
Reply 4 of 40, by wd
Rank DOSBox Author
DOSBox Author
Do you trust people who tell you "hey xyz has no virus, just execute it,
no need for anti virus software" ?
Reply 5 of 40, by kruwi
Use Linux, forget about virus(es) (I know this does not really rhyme ... ).
Visit the end of the internet: www.groskreutz.de
Reply 6 of 40, by icemann
🤣 if its posted here you can trust it doesn`t have any viruses. The mods would be on it right away otherwise.
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 7 of 40, by MiniMax
Rank Moderator
Moderator
But how would we know if it contained a virus or not?
And what is the big deal anyway if it contain a virus or not? It will run in the emulated Win31 environment, not on your physical PC.
_________________
Reply 8 of 40, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
That concept is not always that easy to grab 😀
Anyway, a virus scanner is mandatory if you are really afraid of catching a virus
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 40, by abyss
It can still give you a virus on your xp tough as you are installing it in xp.
Reply 10 of 40, by wd
Rank DOSBox Author
DOSBox Author
Oh i knew YOU'd install virii under your xp...
Reply 11 of 40, by MiniMax
Rank Moderator
Moderator
From the Readme.txt of WQGHLT:
Installation
To install WQGHLT, copy WQGHLT.386 to C:\WINDOWS\SYSTEM, add a line to
C:\WINDOWS\SYSTEM.INI's [386Enh] section, like this:
[386Enh]
device=WQGHLT.386
and restart Windows.
Now - exactly how do you propose that a virus hidden inside the file WQGHLT.386, placed inside an emulated filesystem, run by an emulated CPU, can affect the outside WinXP ?
_________________
Reply 12 of 40, by valnar
I'm with MiniMax on this.... how did my thread become a topic of viruses? 😖
-Robert
Reply 13 of 40, by wd
Rank DOSBox Author
DOSBox Author
Just read the postings of abyss and you know.
Reply 14 of 40, by DosFreak
emulated filesystem?
As for System.INI...
NT4/2K/XP/2003/Vista come with an SYSTEM.INI for backwards compatibility with 16bit applications.
I don't know if drivers placed in the [386Enh] section work or not....
I doubt any company would support their users doing anything with viruses wether the likelyhood is minimal if they infect their computer with a virus or not, which is why when questions come up concerning viruses and DosBox I always am 120% paranoid. Last thing we need is a bunch of dumbass users running viruses in DosBox and thinking that it's safe because the "DosBox people" said it was.
Make your games work offline
Reply 15 of 40, by MiniMax
Rank Moderator
Moderator
DosFreak wrote:
emulated filesystem? […]
But which System.INI ?
This driver is for Windows 3.11, right? So it needs to go in the System.INI that Win3.11 can see. Assuming that the person installing this driver did NOT do the braindead thing of mounting the real C:\ as the emulated C:\ in DOSBox, but instead did a
mount C "C:\DOSBox-stuff\Win31-drive"
then the System.INI in question will be
C:\DOSBox-stuff\Win31-drive\WINDOWS\System.INI
Now, how can the contents of that file possible affect the host OS ?
_________________
Reply 16 of 40, by wd
Rank DOSBox Author
DOSBox Author
Ok just for clarification: you should NEVER run virii or virus-like
code inside dosbox. You are FULLY resposible yourself to check
that the programs contain no virus or similar stuff.
Reply 17 of 40, by DosFreak
Which alot of users still do.
Also I have actually seen users modify their system.ini's in NT4/2K/XP for stupid things just because they think it will make their game work. In fact I can guarantee that there will be a user out there who will modify their System.ini in their XP directory just so that their Windows 3.1 in DosBox will function correctly.
and why not? They are running Windows aren't they? So why shouldn't it work? 🙄 😀
Reply 18 of 40, by laxdragon
This is a very nice tip. Someone should add this to the Wiki so it is not lost.
Now CPU usage for me is lower in Win3.1 than just sitting at the DOS prompt. I wonder why when sitting at the dos prompt the CPU load is at 40% with nothing running (no TSRs)? In Win3.1 cpu load drops to 0%.
laxDRAGON.com | My Game Collection | My Computers | YouTube
Reply 19 of 40, by wd
Rank DOSBox Author
DOSBox Author
Becsause nothing is running is just wrong?
