First post, by JayAlien
Hi All,
My DOS pc has an ASUS SPAX motherboard and the bios settings seem rather limited. I was hoping to disable some caches on the Pentium CPU to slow things down a bit, but there doesn't seem to be any options for that in BIOS.
I was wondering if this BIOS had a hidden or advanced section that could be enabled with some key presses, does anyone know?
Thanks,
J
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700 A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 1, by IcySon55
Hey there Jay,
I also have this board. You can actually replace the BIOS with the one for the ASUS SP97-XV and get all of the missing functionality back.
A customized version of the BIOS is available that improves HDD (max capacity) support as well as AMD K6+ CPU support, here: http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
The SP97-XV custom BIOS: http://home.hccnet.nl/j.steunebrink/0109xvj2.zip
The original motherboard uses a 128KB BIOS while the SPAX has a 256KB BIOS. To use the customized BIOS on the SPAX, you need to increase the filesize of the custom BIOS to 256KB.
You can simply double up the file having two copies of the BIOS or add 128KB of null bytes.
I would recommend UniFlash to flash this custom BIOS. It will open up all the options you would like to control and also doesn't disable any functionality of the board (like the onboard Crystal audio chip still works).
Cheers~
