Voodoo4 M4800
Reply 100 of 123, by sdz
Spitz wrote on 2025-05-31, 10:03:
@sdz M-M-M-MONSTER great job! Is there anything I can support You with?
Thank you! At the moment, the limiting factor is free time. This project is pretty much on hold since my last post, and will probably be for the next few months.
Besides a few remaining BIOS related issues (that I'm sure can be fixed with some effort), the major issue is the lack of sound. I tested a Yamaha YMF724 card, via an expresscard to M2 adapter -> M2 to PCIe x16 -> PCIe to PCI bridge. It works fine under XP, but not under 98.
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
The attachment 3.jpg is no longer available
adamnfs26 wrote on 2025-05-17, 18:21:
so why not open source this, id love to take on my voodoo 4s and make one my own , or sell a kit with just the fpga needed to make one.. or sell em for a resonalbe price ?
otehr wise ill just build a normal retro 3Dfx pc and all this work was for nothing
Maybe check the previous posts?
Reply 101 of 123, by kurkosdr
Out of curiosity, why are you even messing with the BIOS? Even if you get it to work, you will only make it work for this one particular laptop, which you had already done before by routing the LVDS cable directly to the card. It won't be some generic solution that would make your Voodoo MXM card work on every laptop with an MXM slot. Why not start testing the two-VSAs card which is something that offers a much bigger benefit?
Reply 102 of 123, by sdz
I'm messing with the BIOS because this allows the card to be used as a primary card, which means Windows98 support (and DOS). Also, I'm doing this for fun.
I already got it pretty much working. Yes, it will work only for this particular laptop, and that is fine with me.
To make the card universal and have it work in any (any ignoring whitelists) laptop with MXM3.0/3.1 slot, it would need to have an MXM compatible VBIOS. At the moment I haven't looked into this, I have no clue if it's possible or not. The LVDS can easily be routed to the MXM conenctor.
The two VSA card is already tested and works just fine.
Reply 103 of 123, by kurkosdr
sdz wrote on 2025-06-02, 19:05:
Which brings a question: Is it possible to use a laptop with an MXM slot but without an iGPU? That way, the BIOS will select the GPU in the MXM slot to be the primary one by default, right?
For example, my old HP Compaq nx9420 has an MXM slot but doesn't have an iGPU (since the CPU it has is the Core Duo T2500 which doesn't have an iGPU). Why not use such a laptop?
Reply 104 of 123, by sdz
If the laptop doesn't like the VSA non MXM compliant VBIOS, it makes no difference if it has an iGPU or not.
Reply 105 of 123, by sdz
A few more soundcards arrived, but none of them worked. In fact, besides the video card and the SATA controller in legacy IDE mode, no other PCIe/PCI device would work (tried even some network and USB cards).
Even tried with the Voodoo4 in the expresscard slot, and the network card shoved into the MXM slot (videocard worked, network card didn't).
In device manager, all PCI/PCI bridges would be detected, if a new hardware was added, it would be detected, but as soon as a driver was installed, it would just throw an error 10, like this:
The attachment 1A.jpg is no longer available
Under XP/Linux, everything was fine. Spent quite a while investigating this, looking at BARs, MMIO windows, IRQs etc, and trying various things. Couldn't find anything wrong.
This was with 98 installed in APM mode, so I went the ACPI route (which I already knew was partially broken).
In ACPI mode, it would do this:
The attachment 1B.jpg is no longer available
and say that :
"This device is not working properly because the BIOS in your computer is reporting the resource for the device incorrectly (Code 9)".
No other PCIe/PCI device would be detected. Tried various things again, and ended up looking at how the PCI resources are exposed to the OS via ACPI. Tweaked that.. until I got 98 detecting PCI devices, but broke XP and Linux:
[ 0.141099] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability LTR DPC]
[ 0.141212] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.171713] pci 0000:02:00.0: can't claim BAR 0 [mem 0xe0000000-0xe7ffffff]: no compatible bridge window
[ 0.171827] pci 0000:02:00.0: can't claim BAR 2 [io 0xf000-0xf0ff]: no compatible bridge window
[ 0.171947] pci 0000:00:19.0: can't claim BAR 2 [io 0xefe0-0xefff]: no compatible bridge window
[ 0.172048] pci 0000:00:1f.2: can't claim BAR 0 [io 0xefb8-0xefbf]: no compatible bridge window
[ 0.172163] pci 0000:00:1f.2: can't claim BAR 1 [io 0xefac-0xefaf]: no compatible bridge window
[ 0.172277] pci 0000:00:1f.2: can't claim BAR 2 [io 0xefb0-0xefb7]: no compatible bridge window
[ 0.172389] pci 0000:00:1f.2: can't claim BAR 3 [io 0xefa8-0xefab]: no compatible bridge window
[ 0.172498] pci 0000:00:1f.2: can't claim BAR 4 [io 0xefd0-0xefdf]: no compatible bridge window
[ 0.172609] pci 0000:00:1f.2: can't claim BAR 5 [io 0xefc0-0xefcf]: no compatible bridge window
[ 0.172720] pci 0000:00:1f.3: can't claim BAR 4 [io 0x0400-0x041f]: no compatible bridge window
[ 0.187668] pci 0000:00:01.0: BAR 13: no space for [io size 0x1000]
[ 0.187762] pci 0000:00:01.0: BAR 13: failed to assign [io size 0x1000]
[ 0.187854] pci 0000:00:19.0: BAR 2: no space for [io size 0x0020]
[ 0.187949] pci 0000:00:19.0: BAR 2: trying firmware assignment [io 0xefe0-0xefff]
[ 0.188064] pci 0000:00:19.0: BAR 2: assigned [io 0xefe0-0xefff]
[ 0.188161] pci 0000:00:1f.3: BAR 4: no space for [io size 0x0020]
[ 0.188255] pci 0000:00:1f.3: BAR 4: trying firmware assignment [io 0x0400-0x041f]
etc.
Then fixed it for other OS-es as well. TL;DR version:
-re-implemented the root-bridge resource set (MCRS) and made _CRS a method that simply returns it instead of doing run-time calculations (seems to work just fine with any OS/DRAM size).
-split the ISA/PCI I/O aperture into two WordIO descriptors
-dedicated IO (Decode16, 0x0CF8, 0x0CF8, 0x01, 0x08) descriptor
-replaced several regions with one 256 MB block at E000 0000h so large (>128 MB) BARs can be mapped cleanly under Linux
-kept a separate 128 MB prefetchable window at D800 0000h.
There was also the issue that SeaBIOS would load the VGA ROM right into one of those regions. That's also fixed now.
acpi PNP0A08:00: ignoring host bridge window [mem 0x000c8000-0x000cbfff window] (conflicts with Video ROM [mem 0x000c0000-0x000c9fff])
Now PCIe/PCI works under 98/XP/Linux with ACPI.
I had the SATA controller initialized in IDE Legacy mode (IRQ 14 and 15). This now caused an issue under 98 with ACPI (resource conflict for IRQ 15), and would not detect the ODD anymore. I changed the controller initialization from IDE Legacy to IDE Native mode. 98 would fail to boot, but using R. Loew's PTCHSATA fixed this. Currently, the 98 installation is pretty vanilla, only using PTCHSATA and PATCHMEM.
The USB controllers (the southbridge ones) now work under 98. Shutdown also works now from 98 (and it actually powers off the machine), but it needs a bit more work as after switching to IDE native and installing PTCHSATA, it throws an error at shutdown: "The volume that was removed had open files on it. Next time please check first to see if the volume can really be removed. Press any key to continue".
Also completely disabled from the BIOS the on board audio.
The attachment S1.png is no longer available
The attachment S2.png is no longer available
Reply 106 of 123, by sdz
Now, can I get audio working? Of course not...
YMF724/744 cards now install just fine:
The attachment S3.jpg is no longer available
Playing anything or even touching the volume slider kinda freezes the system (cursor is still moving but mmtask stops responding).
AU8810 card installs ok, and I can hear actual sound playing through it, until I restart the system. After that, 98 fails to boot (until the card is removed or driver uninstalled from safe mode).
Under XP, YMF724/744 and AU8810 sound cards work just fine.
Reply 107 of 123, by sdz
The shutdown issue with the SATA controller in IDE native mode and R.Loew's PTCHSATA ("The volume that was removed had open files on it. Next time please check first to see if the volume can really be removed. Press any key to continue") is fixed with the 239887UP.EXE 98SE Shutdown Supplement patch.
Besides the lack of audio, windows98 seems to run really well on this system.
I tested the sound cards with the OEM BIOS.
AU8810 behaves the same, and prevents windows from starting.
YMF7x4 works a little better. Media playback works (but the whole system freezes after a couple of minutes). MIDI playback works but goes wonky after 2-3 seconds. Also, when the card is connected, the USB controllers don't work anymore.
Reply 108 of 123, by sdz
I could also enable DMA for the SSD, and it went from around 2.5MB/s to :
The attachment S4.jpg is no longer available
Pretty decent performance.
Reply 109 of 123, by tehsiggi
I'm always lurking this thread.
Great work and I love that you're down to the fiddling. Even is some might not understand "why" you do what you do, I completely get it.
Keep it up and keep up the fun of it!
Love seeing more!
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 110 of 123, by onethirdxcubed
If you've got a working USB controller now you might be able to get a USB Audio class 1.0 sound card to work. The cheap $2 ones from eBay work like this, and the Behringer UCA-202 and clones , and I have also had good luck with Logitech Z-150 usb powered speakers. You won't get AdLib in DOS but basic sound should at least work. No drivers are needed.
Reply 111 of 123, by kagura1050
Hello! I always enjoy seeing the progress of your project.
I'm sorry this is off topic, but I'm more interested in the PCIe x1 to MXM carrier than the MXM board itself.
Are you planning to open source the design data for the carrier board?
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
Timezone : UTC+9
Reply 112 of 123, by sdz
@tehsiggi Thanks! It is pretty fun, I have never messed with coreboot/SeaBIOS and this low level x86 stuff before. And if all goes well, the end result will be a pretty sweet (at least for me) W98/XP laptop (and maybe DOS, though I doubt it).
@onethirdxcubed I tried an UAC1.0 sound card, and it did seem to work just fine. Still, I would like to get a proper sound card working, and have functional MPU-401, for reasons 😀
@kagura1050 I don't mind the off-topic! What kind of PCIe x1 to MXM adapter do you need? VGA, DP, HDMI, LVDS, external power or just from the x1 slot (max. 25W as per PCIe spec).
Reply 113 of 123, by onethirdxcubed
A CMI8738 to Mini PCIe or M.2 sound card (with MIDI serial port and speaker amplifiers) would be a great hardware project to pair with an overpowered laptop like this.
Alternatively, you should be able to run the Yamaha XG soft synth and not even notice the performance hit.
I have done some research into writing a WDM HD Audio driver for Windows 98 and it should be technically possible, though not all the features like jack retasking or EAX can be implemented. No one has made it happen though. R. Loew tried to backport the Win2k HDA Bus drivers with no success. The 16 bit windows 3.1 driver sort-of works in 9x but breaks power management and gets very unstable when the swap file is used.
Reply 114 of 123, by mbandalauk
This is great! Once the design files are released, would it be straightforward to build a simple PCI form factor clone? Would that be more affordable than buying an original PCI Voodoo card? Alternatively, could an MXM-to-PCI adapter be used instead?
Reply 115 of 123, by sdz
onethirdxcubed wrote on 2025-06-11, 20:08:
My plan is shove an YMF744 or AU8830 in there (maybe even both), SPDIF output, line/HP out, line in, MIDI out (for hooking up a Roland SC-55 for example), amplifier for the internal speakers, plus a quad core ARM Cortex A53@1.8GHz, 4GB LPDDR4, eMMC etc for MT32/SC55 etc internal emulation. There is a small ish board that plugs into the MB, that has two USB ports and the audio jacks. My plan is to make a drop in replacement for that board with all the stuff mentioned earlier. For now I tried a bunch of cards (YMF724, YMF744, AU8810, AU8820, AU8830), and no luck under Windows 98. Most likely due to shared IRQs. Will require some more BIOS hacking, but I don't know when I'll have time to work on this again.
A WDM HD Audio driver for Windows 98 sure would be awesome!
mbandalauk wrote on 2025-07-15, 08:48:
Yes, it should be pretty straightforward. Just remove the PCIe to PCI bridge, and route the PCI signals to the card edge connector. An MXM to PCI adapter wouldn't make much sense, as it will need to have another PCIe to PCI bridge on it (the MXM card needs PCIe not PCI). If you meant MXM to PCIe, then yes, such an adapter can be used. I'll upload the files for one when I release the design files.
As for affordability... it depends. The current design, due to space constraints and all the extra stuff that is needed for making it work in a laptop, is 12 layers, 0.15mm vias with 0.05mm annular ring size and via in pad (plugged + capped).
Making just the bare board , 10pcs, is around 300-500$ plus shipping and taxes. Ordering just one PCB instead of 10 will cost about the same. If the plan is to make just one board, it's probably way cheaper to buy an original V4 card.
Alternatively, for making a regular PCI V4 card, the card can be redesigned for 6 layers, without via in pad, and larger via drill size/annular ring. Even so, if making just one board, considering the cost of the PCB and components (and assembly, if you can't do it yourself), will probably cost more than an existing card.
I started assembling 5 more MXM cards, I don't have much free time to work on this, but maybe in a week or two I'll finish assembly. After that, I'll properly test all of them, fix bugs if anything pops up (FPGA related, if any, the card is rock solid. I finished quite a few games on such a laptop, and had no issues). If all is good, I'll prepare the files/documentation/etc.
Reply 116 of 123, by mbandalauk
sdz wrote on 2025-07-17, 20:38:
Understood. I see your primary focus is on MXM hardware and its application in MXM laptops. I hope your design files might inspire someone to create a standard PCI—or even AGP—version of the V4. Your work clearly demonstrates that this is neither easy nor inexpensive, but it proves that it’s possible. Perhaps someone could produce a small batch—say, 20 units—of V4 PCI or AGP clones and offer them at a lower price than the average cost of an original V4. It wouldn’t be easy, but it might just be achievable.
Reply 117 of 123, by Shreddoc
mbandalauk wrote on 2025-08-08, 17:36:
It's a nice notion to think that the retro market might find a way to offer high end Voodoo cards at cheaper prices, but to be realistic, this would only be possible if somebody (or bodies) were willing to do a huge amount of highly specialist work for free, with the goal of giving already-wealthy people (anybody buying or collecting Voodoo4 cards is comfortably wealthy, in context) a cheap bargain. It's a very tough ask - not impossible, but close enough that it would take a very special and generous person(s) to make it happen.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 118 of 123, by K4sum1
While the card is unfinished, it would be cool to see the legacy Coreboot setup released. I'd like to run something like that even though my M4800 has a M2200 in it.
Reply 119 of 123, by Deksor
Shreddoc wrote on 2025-08-08, 20:58:
Even then, the leftover stock of VSA100 chips is probably not big enough to justify the expenses or sustain the demand, most likely it'd be more justifiable to go FPGA for that (allowing you to use readily available components, some cheap DDR3 chip(s ?) for VRAM, etc)
