VGA Repair report collection
First post, by tehsiggi
Dear all, as a follow-up to Hercules Radeon 9700 Pro repair report I'd like to start a thread where others and I can share their VGA repair reports.
I hope that this will help and encourage others to repair graphics cards, mainly in the "retro" perspective from my end. (Whatever that means for everyone).
I have a couple of repairs in the pipeline and would append the reports to this thread, so that they're all in one place.
This first post will take care on a Radeon 9800 Pro 128MB with reference design:
### First Impressions ###
The card itself was sold on ebay with the status of "working, but showing artifacts". Physically the card appeared in a very good condition, which is not a surprise, as the seller had cleaned it already.
The artifacts themselves appeared right from boot, they were flickering patterns, which could even completely disappear from time to time.
Just for completeness I checked if all signals appear to be free of shorts, which they were:
### Diagnosis ###
The patterns directly appeared to me as memory related, so I booted up FreeDOS and started R3MEMID to check the memory. The visual appearance of the menus and the running first test can be seen here:
The test result:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1 ] Fill : FAIL
Error ID 0VB001
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDD0 32 33 34 35 36 37 38 39 ...
According to the result, the memory chip on memory channel D starting with bit 32 is throwing errors. This is the second memory IC on that channel and same as on the Radeon 9700 Pro is designated as U59.
The memory IC is again a K4D26323 type, which I will replace with a K4D26323RA-GC2B
### The repair ###
Using pre-heating and hot-air at 390°C. I isolated the IC surroundings using kapton-tape, to make sure to reduce thermal stress.
Here is the PCB with the chip removed:
Cleaned pads:
I made sure all excess solder is removed using solderwick and used isoprop to clean off any residue.
Then I soldered on the new memory IC and cleaned the PCB around it.
### Testing ###
I ran R3MEMID again, with success:
3DMark2001SE works well too:
I ran a multi hour burn-in test using S.T.A.L.K.E.R. which was rock-solid.
The memory ICs run around 55°C on an open desk, without any heatsinks.
So again, BGA memory failure.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 1 of 47, by tehsiggi
Today I am taking a look at a Radeon 9000 Pro in reference design.
This card was bought as working, though I had the impression from the offering that the card it pretty beat up.
The card arrived in a pityful condition. It was very dirty on pins and pads. Basically every electrolytic capacitor had scratches on it, some of them had significant dents.
It was in dire need of a cleaning and some love.
### Diagnosis ###
Though the card was offered as working, it was behaving weird. In windows, even though the driver installed fine, the UI was sluggish and there appeared to be no hardware acceleration. Furthermore running 3DMark2001SE showed that a) the card appeared to be unstable and b) the result screen had graphical errors.
So after the first test, I took a look at the card in detail.
There is one capacitor missing at the VDDC regulator. According to pictures it is 470µF/16V. The 3.3µH inductor of the VDDC regulator is also broken.
There is also a blocking capacitor missing at one memory IC.
On the back, there are 0 Ohm jumper resistors missing and broken, which are parts of the AGP signal lines.
agp-signal-lines-broken.jpg agp-signal-lines-broken2.jpg agp-singal-lines-broken3.jpg
### Repair ###
Since all electrolytic caps looked bad and some had dents, I decided to basically re-cap the card. I am by far no fan of "recapping for the sake of recapping", but this card deserved better.
The missing capacitor was replaced by scraping off some silkscreen from the PCB above the missing pad. Then I was able to solder the new capacitor to it.
I also removed the old 3.3µH inductor and replaced it with a new one.
indcutor-capacitor-repair.jpg memory-regulartor-repair.jpg card-front-repair.jpg
The broken AGP signal line jumpers have been removed, pads cleaned and new 0 Ohm jumpers have been installed.
### Testing ###
After the repair the card works just fine again. No more instability or graphical glitches. And the 2D mode was properly accellerated again and windows ran smooth.
### Parts used ###
12 x 22µF / 16V - EMZA160ADA220MD61G - Europe Chemi-Con
2 x 47µF / 6.3V - EMZA6R3ADA470MD61G - Europe Chemi-Con
4 x 1000µF / 10V - EEUFM1A102 - Panasonic
3 x 470µF / 16V - EMZA160ADA471MHA0G - Europe Chemi-Con
2 x 100µF / 16V - EEEFK1C101P - Panasonic
1 x 100nF / 50V - C0603C104K5RACAUTO - KEMET
1 x 3.3µH - PISM-3R3M-04 - Fastron
Reply 2 of 47, by nuno14272
Very nice work...
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 3 of 47, by Ozzuneoj
Very nice work indeed! And I love that you're documenting these. This thread has great potential as a densely packed source of info for repairing various video card problems.
Just out of curiosity, are those Radeon BGA memory failures ever fixed by reflowing or removing and resoldering the same chip, due to a broken solder joint, or is it always a matter of the chip itself failing? Also, did you do anything involving shimming the GPU die since lack of contact with the heatsink is often cited as a problem with these?
Reply 4 of 47, by tehsiggi
Ozzuneoj wrote on 2025-05-02, 17:14:
I hope to keep many more cards alive for the upcoming generations. It's not only for the "retro" aspect of it, but also to preserve the past. So I hope my documentation and (hopefully) the ones from others over the time will help achieving this goal.
I did not go so far as reballing existing chips. However a stencil etc. is just underway, as I want to give it a shot. I also have donor cards which have known to be good memory ICs, so I want to re-use / re-cycle them in my repairs. I did give it a shot some times to do some "reflow" with proper heat, but it never turned out to resolve the issue so far.
I did not remove the shims of any of those GPUs (R300, R350 and R360) - I usually try to use appropriate coolers (e.g., original ones from ATI for the 9800 series) or thermal pads with proper sizing. I'd like to keep cards "as is" if possible, retaining them the way they were build (incl. their mistakes sometimes).
This is also why I don't use different types of caps, like poscaps or tantals instead of electrolytes or vice versa. There are people doing this, but I don't feel like this is my niche. Repair and use with what it has been designed with.
Again to both of you, thanks for your kind words.
More cards to come!
Reply 5 of 47, by tehsiggi
Todays card: Radeon 9700 Pro with artifacts. Always occuring.
### First impressions ###
Card is clean and tidy. No noticable damages to the PCB or parts on it.
### Diagnosis ###
Fault is not influenced by temperature or pressure. Checked all memory ICs, no change. Voltages are all fine.
A run of R3MEMID shows an error on MDC0
[1 ] Fill : FAIL
Error ID 0VB001
failing bit : MDC0 0 1 2 3 4 5 6 7 ...
This is U58 according to the schematic. It's on the top side of the GPU.
The broken memory part is - again - a K4D26323RA-GC2A.
### The repair ###
I replaced the memory IC with a K4D26323RA-GC2B, as in previous repairs.
### Testing ###
R3MEMID, 3Dmark01SE, 3DMark2003, Aquarmark3 and S.T.A.L.K.E.R all run without issues. The card is fixed up.
I've cleaned the cooler thoroughly and re-assembled the card.
Reply 6 of 47, by HBGOK
Hey, I really like your topic about repairs, I was looking for something like this and finding any information about repairing ati radeon cards is very difficult. I have collected a few radeon 9800 pro and xt (most of them bought from electronic waste) and most of them start but display small artifacts, I would really like to try to repair them, if it's not a problem I have a few questions for you. First, where can I download the R3MEMID program, I don't know why but it is very difficult to find on the internet for me, I wasted a lot of time on it without results 😒 Secondly, I have a question about identifying which memory chip is damaged based on the results displayed by the program, can you share your knowledge or a diagram of what markings mean which memory? You wrote "This is U58 according to the schematic. It's on the top side of the GPU.", can you make public the diagrams that you have? Sorry for such a long message but maybe thanks to your answer a few Radeons will come back to life, best regards 😉
Reply 7 of 47, by tehsiggi
Hey there.
Let me try to answer all questions you have.
First of all, R3MEMID. It has been uploaded here at vogons already, so I'd give credit to the original poster: Re: Hercules Radeon 9700 Pro: weird output
You can run it under Freedos, however you'll need dos4gw alongside it.
This tool returns you a list of bit errors on the corresponding memory channels. For a bit more in-depth information about that process, see: Hercules Radeon 9700 Pro repair report
The Radeon 9700 (R300) and Radeon 9800 (R350/R360) are pin-to-pin compatible. This means, a R300 GPU could run on a Radeon 9800 PCB and vice versa (and some manufacturers did that in the past). This knowledge is important because that means that basically all that applies to a Radeon 9700 applies to the 9800 as well.
If you compare both cards in their reference layouts, you will see that they share a lot! The PCB might be slightly different, but the parts used are mostly the same. I figured out that between Radeon 9800 and 9700 cards, the memory designation (UXX) is the same, so you are safe to assume that the assignment of chip per channel is the same as well.
I attached a schematic of a Radeon 9700 Pro, as for myself, I don't have a schematic of a reference 9800Pro/XT (I got some from MSI cards though). That might clarify some things as well.
I order to have a quick lookup, I created the following graphic which tells you which IC belongs to which bits of the memory channels on reference Radeon 9500 (256bit). 9700 (nonPro & Pro) and 9800 (nonPro & Pro) cards.
Reply 8 of 47, by HBGOK
Ha ha, I'm analyzing the information from you with a radeon 9800pro in my hand and now everything has become clear, the small markings near the RAM chips match the diagram, I also checked how it looks on a radeon 9800pro 256bit and a radeon 9800 XXXL from Medion, the descriptions are in slightly different places but all the markings are the same. You have no idea how happy I am to understand this, thank you very much for the explanation 😄 Now all I have to do is make a proper machine for testing and practice my memory soldering skills on some cheap office card, and I can start having fun repairing these radeons 😉
Reply 9 of 47, by tehsiggi
Don't take memory errors directly as a fault of the memory chip itself. I've had cards with parts/traces missing / broken around the affected memory chip. So it's good to take it as a first indicator and then rule out possible culprits one by one.
Reply 10 of 47, by tehsiggi
I finally got the time to fix one of the cards that stef80 sent to me a while ago. Again many thanks for that!
Today’s patient: A Sapphire Radeon X800XT AGP VIVO
The card has some usual dust residue on it. Furthermore, as stef80 reported to me, one memory IC had a crack that was barely visible.
### Diagnosis ###
I checked the suspected memory IC, as the card was showing artifacts when running that look similar to the ones of other cards with memory faults.
I tested it for pressure and temperature reactivity, no changes.
The memory used by this card is from Samsung with the part number: K4J55323QF-GC16
It’s a 600MHz GDDR3 IC in BGA format, so nothing too fancy.
### The repair ###
You can clearly tell that from the 9x00 series to the X series ATI had upped their PCB quality and complexity. The PCB of this card sinks away heat pretty pretty well, meaning that with pure hot air itself you’ll have a bad time. You can barely get enough thermal energy into the board to heat up enough.
So pre-heating the PCB is a must.
With that in place, it was easy to remove the old memory IC, clean the pads and solder a replacement memory IC with the same part number.
### Testing ###
I tested the card thoroughly for my AGP power metrics using 3DMark01SE, 3DMark03, Aquamark3, S.T.A.L.K.E.R. Call of Prypjat and Anno 1401, as well as with ATI tool to scan for artefacts.
Nothing was found and the card works just fine on my system.
Glad to have it fixed.
The only concern is the FAN, its bearing is basically dead.
Reply 11 of 47, by Ozzuneoj
Nice job on the repair! I have no experience with BGA repairs, but I think I'm getting close to having what I need to attempt them. I still need is a board pre-heater, but when I look at them I can see my injury-prone-self getting burned... 🤣
Can you show or post a link to what you use for pre-heating a card like this?
Reply 12 of 47, by tehsiggi
I use a Yihua 853A + thermocouple from my multimeter to track the board temperature . Works decently well for what it is.
Reply 13 of 47, by shevalier
tehsiggi wrote on 2025-07-10, 18:52:
This is standard bearing No. 693ZZ.
From NSK or SKF - very good.
From AliExpress - well, it says ABEK9 precision class. But what's the point if they start to crunch after a month. 😀
PS.
That is, these 693 bearings are not some kind of "magic IT thing", but a regular part for drones, power tools and hobbyists in general. In a big city, you can find them in a off-line store when you go to get a beer.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 14 of 47, by sdz
Nice repairs, thanks for documenting and posting these!
Reply 15 of 47, by PcBytes
I'll have to keep R3MEMID in mind. I have a 9800SE AIW here that will likely find it helpful.
As for Yihua... I have a 862BD+, will that do?
Reply 16 of 47, by tehsiggi
sdz wrote on 2025-07-17, 20:48:
Thank you, much appreciated!
PcBytes wrote on 2025-07-17, 21:30:
Hot air wise, yes.
For preheating, you'll have to use something separate.
Reply 17 of 47, by tehsiggi
Today's candidate is a Radeon 9700 non Pro.
It's using Infineon Memory and has the reference layout. The cooler of it is basically non-existent, so I just mounted a temporary one to it.
The card looked a bit roughed up. After a first cleaning, I've seen that the power connector was bent and at least one cap was missing (probably for VTT)
### Diagnosis ###
Putting the card into a system reveals severe graphical artifacts. They look like typical memory artifacts, which gives a hint to what to look at. Even though VTT is vital for the memory speed and data integrity, I would not suspect one missing cap to have that big of an influence.
Running R3MEMID revealed that the Memory Channel D was completely faulty (U58 and U59). Odd. Two BGA memories dying on the same channel is not the usual thing. Furthermore, the 270MHz memories haven't failed so often in my experience.
So I went looking for scratches and damages around these memory chips.
An look what we've got.
Some exposed traces, I measured them and they all have continuity, so a red herring.
But near U59 there's something missing..
Looks like we got an issue!
### The repair ###
So what is the part that is missing here?
The Gigabyte Schematic of the Radeon 9700 references this as U92 - a SSOP5 packaged single AND gate. It has two inputs and one output. If we look at the schematic, it's between the GPU and the memory ICs of each corresponding channel. So we got four of them, since we have 4 memory channels on the R300.
It's in the CKE (Clock Enable) signal of the memory, which tells the memory ICs to work with the clock signal or ignore it (usually setting them into power saving / inactive mode).
So with that IC missing, the two memory chips U58 and U59 basically never join the memory party and don't work at all. That's pretty bad.
The AND gate links the forwarding of the signal to the AGP reset, probably for startup sequencing.
I have seen layouts where this IC is omitted and instead a direct connection without invoking the AGP reset is used and the schematic supports that as well, so if you can't get a replacement part, this might be worth trying.
If you're interested where the alternative resistor (0Ohms) would live in this case, see this picture:
In my case now, I took the missing part from a dead dead dead donor 9800 Pro and soldered it in place:
That being done, I also replaced the missing VTT ceramic cap, which is a 22µF one.
### Testing ###
R3MEMID shows no errors anymore and 3Dmark01, 03 etc run without any issues.
Reply 18 of 47, by tehsiggi
Quick update on the 9700 and its dead cooler.
I've tried those 10€ aftermarket coolers you can find cheap on aliexpress for example. They work just a treat. They're not silent, like Zalman or an Arctic Freezer, but they appear to do their job well.
The airflow is good and it also cools memory on the front of the card very well. I am pleasantly surprised.
The whole card is not getting very hot after 1 hour of Half-Life 2 and S.T.A.L.K.E.R. - Memory modules are at max 41°C.
Reply 19 of 47, by tehsiggi
Todays is a good example of how you sometimes don’t need new parts, but where a re-ball is good enough.
It’s another Radeon 9800 Pro with Samsung Memory, declared “not working” by the seller. Whatever that means.
The card has a big fat “R.I.P.” written over it on the front and back. I get why people mark their stuff if it’s nor working anymore, but that sounds like a very hasty diagnosis to me.
The card appears relatively clean, however the thermal compound on the GPU appears to be pretty old (brittle stuff).
### Diagnosis ###
Putting the card to work shows that there is an inconsistent error behaviour. Sometimes the card works fine, next moment it does not. The image is affected in the left half of the screen, at least in windows.
Putting movement / pressure onto the upper part of the PCB directly influences the problem. This leads me to memory as the culprit
I ran a quick round of R3MEMID to see, which shows MDC bits 32 onwards. That is U57 on the back of the card.
Putting enough pressure on the chip fixes the issue temporarily, so this leads me to think the chip itself is fine, which is great news!
### The repair ###
I desoldered the Memory IC (U57) and afterwards cleaned the pads on the PCB for the repair.
Once the PCB was done, I took care of the memory IC.
After cleaning it completely, I recalled it using 0.45mm balls.
After that I reinstalled that memory IC into the card, same procedure as always.
### Testing ###
R3MEMID is happy again.
[1 ] Fill : PASS
[2 ] Data line toggle (GUI) : PASS
[3 ] RW page (GUI) : PASS
[4 ] RW channel (GUI) : PASS
[5 ] Data mask : PASS
[6 ] Macro + Micro8x2 tiling read : PASS
[7 ] Byte swap macro+micro8x2 read : PASS
[8 ] HOST_DATA/<f,b>/M2L : PASS
[9 ] Line slopes/dir/P/solid : PASS
TEST RESULT SUMMARY:
R350 (0x4e48) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : PASS
No failures detected.
Also games + benchmarks work just fine and the whole graphical glitching is gone.
