S3 Savage 2000
Reply 100 of 110, by 386SX
This card was made by Diamond. I've used a Viper 550 (TNT) for years and a friend of mine used a Viper 770 (TNT2) for years also […]
This card was made by Diamond. I've used a Viper 550 (TNT) for years and a friend of mine used a Viper 770 (TNT2) for years also. Both were passively cooled and seemed to at least not have too much serious thermal issues.
But about your worry about frying your Viper 2: If you rig a fan to the heatsink like in the link I provided (you could also opt to use better case ventilation if you prefer that over rigging active cooling on your old graphics cards) then you should be home free, so to say 😜
And the way Brostenen rigged his Voodoo 3 is actually quite popular here on Vogons, for several for good reasons:
-It's cheap
-It doesn't damage the card (no damaging the original heatsink...if you care about that 😜 but lots of people prefer to not ruin the original heatsink, including me)
-It's very fast and very easy to do, only need some wires and at least some common sense
-Most important is...it works! 😁 I modded my GF6800 (Vanilla Edition) the same way, only had to remove it's original fan assembly
So I can highly recommend it 😉 Only thing that could go wrong I think is if you have some accident while rigging the fan, like ESD damage for instance.
Running this Athlon Tbird 1000 with Viper II Z200 right now and posting with latest S3 drivers. It doesn't have the controls of the original brand drivers but seems to be lighter and simpler to install.
Running with the jumpers opened until I understand if actually all of them must be closed for AGP 4X. I got ~2200 in 3dmark2000, is it right?
Reply 101 of 110, by 386SX
Edit: result next post
Reply 102 of 110, by 386SX
Edit: next post
Reply 103 of 110, by 386SX
Interesting, with the branded older drivers on 3dmark2000 I get higher values:
Athlon option: ~ 3400
D3D software T&L: ~3300
D3D hardware t&L: ~2100
It seems that the T&L option in the driver is in facts using the internal seems slower hw unit, but with Opengl t&l things are different:
Treemark t&l off: 15 fps
Treemark t&l on: 25 fps
Edit: I reinstalled the original S3 latest drivers and testing.
Reply 104 of 110, by swaaye
Do you get flashing geometry in Quake 3 with the T&L enabled?
Reply 105 of 110, by leileilol
^ In addition to that, /r_primitives 1, 2 and 3 should all be separately tested (default is 0; and 2 is usually fastest)
long live PCem
Debian's fucked
Reply 106 of 110, by vasya segment
Hello, folks. I've recently read somewhere that viper2 is very sensitive to the AGP frequency, it's 66MHz or nothing. Is that correct ?
Reply 107 of 110, by Fenyo
Hello, im lookig for Inno3d Savage 2000 64 mb version bios image, if anyone had, could you send me or upload here?
Thanks
Reply 108 of 110, by DNET_roma
Hello,
I have a Savage 2000 Viper II Z200 videocard and I tried to run unreal engine games using S3Metal. My system configuration is: Windows 98SE, Via Apollo Pro 133, PIII 900, 128 Mb RAM, ESS Solo-1, 32 GB Sandisk CF card instead of an HDD.
The only game that works on that system is Unreal Tournament 99. Even the Unreal Gold doesn't work with S3 Metal on Savage 2000. When I choose S3Metal it renders in Software mode regardless of the version of metal.dll. Other games, like Citizen Kabuto, Clive Barker's Undying don't allow to choose s3metal renderer in options. But the performance of Savage 2000 UT99 is pretty descent, around 50 FPS at 1024x768X16. It is even better, than that of GF6800GT 256Mb in Unreal Tournament in Direct 3D on another system with P4 (poor optimzation of the Unreal Engine for Direct 3D). It's a pity that Savage 2000 and S3metal work only in one game.
Has anyone managed to launch other than UT99 Unreal Engine titles using S3Metal Api on Savage 2000?
Reply 109 of 110, by cyreex
Fenyo wrote on 2021-04-26, 09:32:
Thanks
Hi! Did you find this bios? I added 4 vram chips to my Savage 2000 32mb and now I want to try to see 64mb.
Reply 110 of 110, by cyreex
FYI. We can extend memory for Inno3d Savage 2000 32mb to 64mb without any changes. In my case, I had a problem with lost contact for a few chip's legs. After fixing this, my Savage 2000 saw all 64mb of memory.
