Great PC! But can it run Crysis?
Reply 102 of 241, by Standard Def Steve
Here's my main machine.
i7-4930K @ 4.5GHz
32GB DDR3-2133, 9-11-11-1T
GeForce GTX 970, driver 353.30
Asus Rampage IV Gene - Intel X79 chipset
Win7 x64 SP1
DX10, Very High:
Reply 103 of 241, by PhilsComputerLab
It seems that a very fast processor is required at this stage 😀
100 fps seems so close, yet so far...
YouTube, Facebook, Website
Reply 104 of 241, by sliderider
I'm surprised anyone is getting less than smooth results running Crysis on modern hardware.
d1stortion wrote:
Scali wrote:
philscomputerlab wrote:
PS: Under XP it seems you can only select High, not Very high. I will add a note to the first post.
Yes, that's because XP runs the DX9 version of the engine, which has less levels of detail (you can also run that on Vista and higher, with a commandline switch, I believe -DX9).
Mind you, the detail levels are not the same between DX9 and DX10. So if you run DX9 and DX10 both on High, they still look different. The DX10 version makes the most of DX10, using specially tuned algorithms based on the new texture formats and such, which you especially notice on the shadows, and also on the HDR colour grading.
Being able to select Very High only on DX10 was mostly a much needed publicity stunt for Microsoft and their Vista marketing. As explained by this article, it's easily possible to force Very High settings under DX9/XP, and the results are nearly identical with playing the game in DX10 Very High settings.
Well of course they would disable Very High in DX9. If they left it in then XP gamers wouldn't see much reason to upgrade to Vista. There were a lot of early DX10 games that still had a DX9 render mode where the DX9 mode was still perfectly adequate and gave higher framerates than you got playing in DX10. The bells and whistles of DX10 can be nice to look at when all is working as it should but when your framerates dip to unacceptable levels then what is the point?
It's not the first time Microsoft used a wildly popular game to force people to upgrade to their latest OS, either. I remember in 2001 when Everquest upgraded their engine timed with the Shadows of Luclin release that the spec was originally going to be vanilla DX8 but just a few weeks before it went live they suddenly changed it to DX8.1, which shut out anyone still using Windows 95. A lot of players strongly suspected that Microsoft had a hand in that forced upgrade, too.
Reply 105 of 241, by Munx
Crysis uses only up to 2 cores, so I'm guessing someone with a well OC'd G3258 could pull it off.
My builds!
The Underdog - The budget K6
Reply 106 of 241, by Scali
DX10 actually made some stuff faster than DX9, and/or better quality at the same speed.
Reply 108 of 241, by Standard Def Steve
Here's a Socket 939 Opteron machine.
Opteron 185 @ 3GHz
4GB PC3200 CL2
Asus A8N32-SLI Deluxe - nForce4 SLI x16 chipset
SB X-Fi Titanium Fatality
Win7 x64 SP1
Single GeForce 8800GTS 640MB
DX9 - Low - 800x600
84.69 fps
DX9 - Very High - 1280x1024
36.405 fps
DX10 - Very High - 1920x1080
12.265 fps
SLI GeForce 8800GTS 640MB
22.34 fps - the SLI scaling is just great here!
Reply 109 of 241, by smeezekitty
36.405 fps
That old dog is faster than I would expect of it.
This crap still goes on. It's happening with DX12.
Reply 110 of 241, by Scali
Yea, but isn't it strange that people are bothered by this? I mean, it sounds like they don't WANT to upgrade.
Especially these days, when you get the Windows 10 upgrade for free.
I personally love to get my hands on a new version of DX, and the latest GPU and just have some fun with it. Which is why I was one of the 3 people who bought Vista back in the day.
Reply 111 of 241, by smeezekitty
Scali wrote:
Yea, but isn't it strange that people are bothered by this? I mean, it sounds like they don't WANT to upgrade. Especially these […]
Can't really blame them. Windows 8 was a turd. Windows 10 is an improvement but it is hard to beat the simplicity of 7
Reply 112 of 241, by Scali
By what metric exactly?
I mean, if people bother to look beyond the start menu, they should see that Windows 8 is leaner and meaner than Windows 7. It boots faster, takes less memory, and performs slightly better than Windows 7 in most software.
As you could also see here: http://www.tomshardware.com/reviews/windows-8 … nce,3331-3.html
So I have to chuckle at people who proudly proclaim that they still game on Windows 7, getting suboptimal performance out of their hardware.
Reply 113 of 241, by alexanrs
Windows 8 was great underneath the hood, but its UI isn't sure about what it wants to be. 8.1 is better and 10 is, finally, a good execution of 8's ideas. And this is an opinion from someone that liked (and upgraded most PCs willingly) Windows 8.
Reply 114 of 241, by smeezekitty
Scali wrote:
By what metric exactly? I mean, if people bother to look beyond the start menu, they should see that Windows 8 is leaner and mea […]
I have a Windows 8.1 laptop. I still think it sucks.
I don't really care about booting faster since I normally start my machine once a day (usually hibernate)
Reply 115 of 241, by Standard Def Steve
I'd say the DX10/VHQ test at 1080p is more GPU limited than anything. I was able to break the 100 fps barrier on my main rig by lowering the resolution and keeping everything else the same. It's crazy how GPU hungry such an old game still is. A 3.33GHz Core 2 Quad with a GeForce GTX 560 can't even crack 30fps!
Reply 116 of 241, by Swampy
Alienware m17x - R1, CPU C2D X9000, 2x GF 9800M GT
Full HD Very High
SLI disabled: 9.7
SLI enabled: cca 27 (no results) (1st run 25, 2nd run 27, 3rd run 30)
    406.73 KiB
    SLI enabled
    339.92 KiB
    SLI disabled
Reply 117 of 241, by swaaye
Standard Def Steve wrote:
Here's a Socket 939 Opteron machine. […]
Opteron 185 w@ 3GHz
4GB PC3200 CL2
Win7 x64 SP1
The single 8800GTS came out slightly faster than the Opteron 180 + HD 2900 XT 1GB setup I ran a few pages back.
I wonder if your 3 GHz CPU did it or the GPU....
Reply 118 of 241, by joe6pack
I ditched my FX-8350 system a couple of days ago for an i7 4790k build. It still has the same RAM and graphics card, an R9 280x.
For being a gpu benchmark, this is an incredible improvement in FPS. From ~50 FPS to this. It makes me wonder if the FX-8350 really is that bad or if I had something configured incorrectly...
684.54 KiB
EDIT: Whoopsies, forgot this part:
38.85 KiB
Reply 119 of 241, by alexanrs
You're comparing Intel's top consumer/non-enthusiast solution (to which AMD has no Piledriver competitor) against a mid-end AMD processor. I'd say those results are pretty much normal. That i7 isn't even working at its full potential, as I have that processor and reached 90+ FPS with similar speed memory and another graphics card, so now you are not being bottlenecked by the processor anymore.
