Great PC! But can it run Crysis?
First post, by PhilsComputerLab
Well, let's find out! 🤣
1. Download and install Crysis SP demo
There are lots of mirrors for the Crysis SP demo. Here are just a few:
http://www.gamershell.com/news_42876.html
http://www.4players.de/4players.php/download_ … load/46497.html
http://www.gamefront.com/files/Crysis+SP+Demo … ;/fileinfo.html
2. Download Guru3D's Crysis Benchmark Tool
Attached to this message, but can also be downloaded from here:
http://downloads.guru3d.com/downloadget.php?i … 39175fd59d50625
3. Download CPU-Z and GPU-Z
http://www.cpuid.com/softwares/cpu-z.html
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
4. Benchmark rules
There are two settings to be used:
1. Meant for XP machines, Vista+ machines with DX9 only graphics card, slower machines. Leave everything at default and make sure that:
*Needs .Net framework 3.5
Resolution = 1280 x 1024
Overall quality = High (Windows XP) or Very High (Vista+ and DX9 option)
Timedemo = benchmark_gpu
DX9
It should look like this:
2. Meant for Vista+ machines. Basically, if your machine can run Crysis in DX10 mode, use this setting. Leave everything at default and make sure that:
Resolution = 1920 x 1080
Overall quality = Very High
DX10
3. Meant for the slowest machines able to run Crysis. Low settings because of the length of time it takes to complete otherwuse. Leave everything at default and make sure that:
Resolution = 800 x 600
Overall quality = Low
DX9
5. Submission rules
Screenshot with:
- Two instances of CPU-Z, showing processor and memory
- GPU-Z
- Crysis Benchmark Tool result
- Post anything that you feel could be of interest in your message!
Notes:
- Have fun!
- Anything goes! OC, UC, whatever
- Under XP .Net framework 3.5 is required
- Leave 32 bit mode. 64 bit mode, for some reason, takes you to the introduction
- Leave screenshots at full size. You can just zoom out using CTRL + mouse wheel, or right click > Open image in new tab
- Added a third setting for really slow machines. 800 x 600, Low details and DX9. Otherwise it just take too long
- Noticed that under Windows XP, you can only select high,
- System requirements stolen from Steam:
YouTube, Facebook, Website
Reply 1 of 241, by PhilsComputerLab
I'll go first with my main desktop:
Reply 3 of 241, by Skyscraper
I will definitely join this compet... ehm Crysis benchmarking assessment for everyone's benefit.
My test bench is full or Slot-1 CPUs at the moment so I will let others show their cards first 😉
Reply 4 of 241, by PhilsComputerLab
Hehe awesome 😀
I will quickly put it on one of my XP machines.
Reply 5 of 241, by Sutekh94
Seems like an interesting benchmark. I'll definitely post results from a couple of my rigs here!
My YouTube | My DeviantArt
Reply 6 of 241, by PhilsComputerLab
Cool 😀
Done a run on a XP machine. I had no idea the benchmark would take that long to complete 😵
Reply 8 of 241, by PhilsComputerLab
Very similar! Same ram speed and GPU 😀
Hoping for someone to bring out some big GPU guns for this game... And finding the slowest system than can run it 🤣
Reply 9 of 241, by maverick85
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 11 of 241, by Scali
Fun... I just bought a GTX970 last week (this is a Gigabyte Mini-ITX card btw), to finally get some of that 4k action.
I have the retail version of Crysis btw, and that one works fine in 64-bit in the benchmark, it seems:
Edit: the 32-bit version does seem to yield slightly higher framerates though:
Lookung at the other results, I guess my i7 860 is limiting the performance somewhat.
Reply 12 of 241, by Munx
Running on my main machine. Its been 8 years and still not able to max it @1080p and AA with 60 fps 😵
Running the full patched retail version, seems to crash whenever I try 32-bit mode.
1.69 MiB
My builds!
The Underdog - The budget K6
Reply 13 of 241, by maverick85
^@ scali: you're bottlenecking your gpu... by a large margin
@munx you have AA enabled
ASRock 98
Win98SE Desktop
ASRock
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 14 of 241, by Munx
That I am. Not much of an improvement though.
Seems like my CPU is a bit of a bottleneck here.
1.76 MiB
Also planning on completing a radeon 9800 pro/Athlon xp machine this month which just barely matches the minimum requirements. Gonna see how this runs 🤣
My builds!
Reply 15 of 241, by blank001
I'll definitely join. I would like to compete in the XP-32bit and W8.1 segment of the competition.
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 16 of 241, by seob
Just ran the bench in windows7 64-bit, 1920x1080 all high, But i get a strange overall average of 1929,5 fps while low is at 15,61 and high at 22,23.
565.36 KiB
Reply 19 of 241, by Scali
An AMD GPU, what a surprise 😀
I think slowest possible may be my old Core2 Duo laptop with Intel X3100 GPU. It runs Crysis, even in DX10 mode, but at about 4 fps in 1280x800.
