Reply 100 of 100, by Xardion
Xardion
Offline
There we go, it built successfully and ran under qemu, and after disabling the check_smb() call so I could run it with the -c option, I was able to get the config and verify it against the W211B datasheet, which looks good. I've attached the output from that command (I converted the tabs to spaces with expand on Linux).
