Reply 100 of 315, by RaVeN-05
Previous Build acts same as latest.
All builds hardlock before any 3d scene race popups .
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 101 of 315, by sharangad
Credits should be under options.
New build no logging:
https://1drv.ms/u/s!As-dKk-N73dSl0AMo-Zu9Ad0nTvO
MD5: 09466c57251ac306f1b8748c47aa4663
I'll get you the old build without logging as well.
https://www.youtube.com/@sharangadayananda
Reply 102 of 315, by sharangad
I'll also try to get this wrapper to work with RReady. Might help me debug it.
Reply 103 of 315, by sharangad
Having problems with getting it to work with RReady.
Could you run a test. Start it up and leave it alone so the demo starts up (or locks up). Wait 15 s and then kill it.
Try it with both versions with logging enabled,
Reply 104 of 315, by RaVeN-05
Something really odd start happening on my PC.
the game often can't startup it crashes right before main menu.
but when it rarely startups , credits works ok menu navigation ok.
and now every build works fast without slowdowns =0 wtf.
the log which is successful is when i left game as is, and after 16 seconds demo starts, nothing new music and black screen.
i keep it for 3 minutes maybe and still nothing.
    V2k.RReady.Redline.txt
    83.27 KiB
    11 downloads
    20240211.001 crashes at main menu
    211.88 KiB
    main menu crash
    426.87 KiB
    11 downloads
Reply 106 of 315, by sharangad
Or is the log file locked? Alternatively the installation might've become corrupted. Or the dlls might be mixed up.
Reply 107 of 315, by sharangad
I actually uploaded two (2) different versions without logging. This could be what you're running.
Reply 108 of 315, by sharangad
I can't check logs out right now, but will first thing tomorrow.
Thanks for the shoutout in your livestream.
Reply 109 of 315, by sharangad
This should run reliably and in slo-mo:
https://1drv.ms/u/s!As-dKk-N73dSl0QMo-Zu9Ad0nTvO
MD5: 7686e587fa0c35057e8573a425adcb37
I really need to get this going with RReady.
[EDIT] RReady need to be modified to work with v2k.RReady. There're dependencies between RReady's redline.dll and verite.dll that the original drivers don't have.
Windows DLL loading paths mean RReady's verite.dll is looks for these in v2k.RReady's redline.dll and doesn't find them.
Reply 110 of 315, by sharangad
This is a much more interesting test:
https://1drv.ms/u/s!As-dKk-N73dSl0UMo-Zu9Ad0nTvO
MD5 : 500d9feba3a7ff87d66f6b992a2d209a
It directly passes the F1's RRedline callback function to the native drivers. RReady can't handle this directly because the parameter passing convention is different between an RRedline 2.0 app and 1.0. You could try this to see if it works. I don't think it will. I think it'll crash even more spectacularly than before. But at this point it's worth a shot.
Reply 111 of 315, by RaVeN-05
ones with direct pass is hangs same as previous builds, the major difference its draw menu once and do not update it, i heard of tics that decreases time to start demoplay but i can\t see it.
the demo should start but nothing happens black screen without music.
the others build acts the same, black screen and music.
Reply 112 of 315, by sharangad
Thanks Raven. Does 001 run reliably?
I'm putting this on hold for now. Need to spend more time on Speedy 3d.
Reply 114 of 315, by sharangad
Try this:
https://1drv.ms/u/s!As-dKk-N73dSl0cMo-Zu9Ad0nTvO
MD5: 1d4774b09caaaf359cb6b2a670fcc2e4
This I think should work very slowly, but it should work better than before.
V_AddToCmdList_ . V2k.RReady moves implements this by calling V_AddToCmdList (in the driver). This is where it gets hairy. With full fat RReady, this works because the base V_AddToCmdList detects forumula 1 is running and when the list is full calls the callback correctly. With v2k.RReady, the base V_AddToCmdList doesn't know about handling the spillover differently and I think this is what causes the problem.
This build flushes every V_AddToCmdList_ using the callback before calling the base V_AddToCmdList. It'll be very slow, the 3D parts. The list is used to batch commands. WIth this every single command gets flushed killing the asynchronouse (parallel) operation of the Verité.
Reply 115 of 315, by RaVeN-05
This do not produce any logs.
Credits very slow.
Menu and demo counts almost exact to real world time (seconds tics).
Demo still show nothing( black screen).
And no music after fade screen to black.
Reply 116 of 315, by sharangad
Do you hear any sound from the cars in the demo? The commentary for instance? I'll get you a new version soon. I'll need timing stats for the demos again.
Reply 117 of 315, by sharangad
Thanks dude for all the testing.
https://1drv.ms/u/s!As-dKk-N73dSl0kMo-Zu9Ad0nTvO
MD5: 7a1bcce9ced80850aeb56a313513368c
Could you time this and see if it's the same?
Reply 118 of 315, by RaVeN-05
While demo tries to play, only music I hear and black screen.
When I try to start quick race I hear announcer only once before entire screen goes black.
This version works faster than any before.
Reply 119 of 315, by sharangad
One more for grinding. If this runs, the 3D sections will have weird textures.
I actually had a crash while adding F1 support during demo/race/quick race sections right around where you're having crashes now. This was caused by paletted textures being loaded and selected. In F1 the dimensions of the textures are handled differently and with paletted ones there's yet another correction. Oddly enough the menus render just fine with an actual Verité board without the correction. WIth RReady the menus don't render correctly without the non-paletted adjustment. The menus aren't paletted. In any case I can't reproduce it with regular RReady anymore by breaking things, probably because I can't remember the exact cause.
But I do remember it was caused by paletted textures. So what I've done here is, in redline.dll is skipped loading paletted textures . The command is ignored. The 3D sections use a lot of paletted textures. VL_InstallTextureMap_ will do nothing if the texture's paletted (hopefully). If this works you'll have a funky coloured 3D section and the game should run.
https://1drv.ms/u/s!As-dKk-N73dSl00Mo-Zu9Ad0nTvO
MD5: c4861fb2fadec9bc33c4f57e12dff7fc
