Reply 100 of 395, by Falcosoft
- l33t
Spikey wrote on 2024-04-10, 06:26:So, where are we at with this? Does it work as a standalone MIDI device, or must it be used with something else?
Does the reverb/chorus work correctly, since someone posted demos last week that sounded like it wasn't implemented?
1. Yes, it works as a standalone device. By default it opens your first Midi In port but with the latest release you can set a command line parameter ('-p:x' where x is the port number) to open the Midi In port of your choice.
2. Both reverb and chorus are implemented and overall it is 99% ready.
