Reply 1000 of 1788, by ajacocks
- Member
As far as I can tell, neither of those games has a command-line switch to force SB recognition.
- Alex
- Alex
I'm having issues trying to get SBEmu working on my Dell Latitude 2100.
It just hangs when I run it. I tried to run a sound card check using sbemu and it hung on that, too.
Thinkpad T42p and no sound so far. Tried demoscene: Verses and Drift, both don't detect sb pro and crash if forced. Next I'll try games.
Don't have DOS/Win98 yet on this so booting from floppy.
dj_pirtu wrote on 2023-10-14, 12:49:Thinkpad T42p and no sound so far. Tried demoscene: Verses and Drift, both don't detect sb pro and crash if forced. Next I'll try games.
Have you checked if there is sound at headphones connector?
georgel wrote on 2023-10-14, 13:08:dj_pirtu wrote on 2023-10-14, 12:49:Thinkpad T42p and no sound so far. Tried demoscene: Verses and Drift, both don't detect sb pro and crash if forced. Next I'll try games.
From Gods -game I got sound, too low volume at first but sbemu /vol9 helped alot.
Now I'm installing Windows 98SE and after that I can test more. Had only WinXP and tried sbemu by booting from USB-floppy drive.
Ok, got Windows installed (and got DOS-mode).
So, what works is Doom and Duke Nukem 3D, not bad. But what's not working is Death Rally 🙁
That's a dealbreaker 😁
Edit: without jemmex it's working, epic
dj_pirtu wrote on 2023-10-14, 16:19:Ok, got Windows installed (and got DOS-mode). […]
That's good news, I've gotta try out SBEMU on my T42 / R42 laptop at some point. What memory manager did you use instead?
Thermalwrong wrote on 2023-10-14, 18:03:dj_pirtu wrote on 2023-10-14, 16:19:Ok, got Windows installed (and got DOS-mode). […]
himemx.sys, so i can limit amount of memory to 256MB.
Compatibility:
- Lemmings1 (works)
- Lemmings2 (Jemmex error)
- RiskyWoods works at start, but sound disappears and never comes back (reboot before next game)
- LostVikings (no sound at all)
What other memory managers have folks used, rather than jemmex? Do we have a way to report success or failure, i.e. a pinned post?
- Alex
The only other one that can work is QEMM.
JEMMEX is able to have loadable modules, and that is where qpiemu.dll comes in. It's an emulation module for quarterdeck's private api.
You dont need this emulator, if the memory manager has it natively. QEMM is a quarterdeck product, and specifically, the one where this private api is used.
SBEmu uses this api to trap realmode interrupts with a protected mode handler. That's why it's a requirement.
QEMM is/was buyware and was never gifted for free to the community, so jemmex+qpiemu.dll is the freely distributable means of having this api available to use.
If you happen to have, or can obtain, a license for qemm, it's the only other option.
No, I compiled a JEMM386 version from Japheth's source code that also works, although, I posted it in the original thread and nobody cared, but it behaves a bit differently. It can be combined with other memory managers, like UMBPCI and XMGR, and it works well with Japheth's VSBHDA fork, as it can be loaded from the command line for a virtual SB session and then unloaded together with VSBHDA and the hole stuff. So you don't have to change your setup entirely.
May the DOS be with you!
New do this sbemu, want to get some dos sound out of Dell Dimension 8300 (Intel 875p and ICH5) integrated sound if that possible? All the windows drivers are working for Windows 98 SE, even the integrated sound ad1980 works with W9x AC97 WDM 5.12.0.3665 drivers, no question marks left in device manager.
Tested with IRQ5 and IRQ7 in autoexec and used sbemu beta3, no dos sound in pure dos or win9x, slow pc if testing sound out with duke3d sound setup. Is it possible to get dos sound out of this SoundMax inside Win9x or pure dos somehow? Thank you!
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
AD1980 ? you get no error but no sound? that is exactly what I am facing...but there is hope if this is the case.
dr.zeissler wrote on 2023-10-19, 05:10:AD1980 ? you get no error but no sound? that is exactly what I am facing...but there is hope if this is the case.
Dell Dimension 8300 has Analog Devices AD1980 AC97 Codec.
https://www.analog.com/media/en/technical-doc … eets/ad1980.pdf
https://dl.dell.com/manuals/all-products/esup … anual_en-us.pdf
sbemu does not give any error, it founds ac97, thats correct, but no sound output at the moment with dos or dos inside win9x.
marxveix wrote on 2023-10-19, 06:18:dr.zeissler wrote on 2023-10-19, 05:10:AD1980 ? you get no error but no sound? that is exactly what I am facing...but there is hope if this is the case.
try this sbemu build Re: SBEMU: Sound Blaster emulation on AC97
https://github.com/raszpl/440BX Reference Design adapted to Kicad
rasz_pl wrote on 2023-10-19, 06:40:marxveix wrote on 2023-10-19, 06:18:dr.zeissler wrote on 2023-10-19, 05:10:AD1980 ? you get no error but no sound? that is exactly what I am facing...but there is hope if this is the case.
Same for me, no sound, i did use this package, just changed sbemu for this smaller one.
download/file.php?id=175764
marxveix wrote on 2023-10-19, 15:26:rasz_pl wrote on 2023-10-19, 06:40:marxveix wrote on 2023-10-19, 06:18:Dell Dimension 8300 has Analog Devices AD1980 AC97 Codec.
So what about this build then? Re: SBEMU: Sound Blaster emulation on AC97
thp wrote on 2023-10-19, 15:36:marxveix wrote on 2023-10-19, 15:26:rasz_pl wrote on 2023-10-19, 06:40:try this sbemu build Re: SBEMU: Sound Blaster emulation on AC97
download/file.php?id=175764So what about this build then? Re: SBEMU: Sound Blaster emulation on AC97
I have good news, Dell Dimension 8300 and sbemu works with front panel audio output, my backplate motherboard output works with Win9x AC97 driver, so it is not broken. I test two of the other sbemu again with front audio output, but this sbemu size was exactly the same as previous one. Others without sbemu sound output can also check front panel audio if the dos drivers load correctly and no sound.
Can i use sbemu also inside Win9x, right now i did boot it directly do dos. I can make 2 bootable options, one for dos and other for win9x, just settings needed for Win9x if possbile to use sbemu also inside Win9x or we use sbemu only for dos?
Thank you, sbemu works, no need to use extra soundcard, so cool! 😀
Hello @THP, i saw that you made a fork of SBEMU, and I was curious to know if you have already taken a look at VSBHDA, and if you happen to have a current version compiled with the latest changes?
What drew my attention to VSBHDA is the fact that it is compatible with HX extender and by extension, also with DOSBOX-X.
Unfortunately the latest release (Apr 12) of VSBHDA does not produce any sound on my devices. But I saw that since then the code has been changed a few times, and possibly the problem has been fixed.
I think it should be very interesting to see how DOSBOX-X runs with an emulated SoundBlaster, especially in games that use redbook audio. Anyway, if you have the latest compiled commit of VSBHDA, it would be greatly appreciated. Sorry for my bad English.
