Reply 1060 of 1064, by PC@LIVE
- Oldbie
With the AZZA P4M2-MVB and P4 2400/400 motherboard, I did some benches, and the results do not seem bad at all, if compared to a DFI with Celeron D 2.66 GHz, but later we will see to make a direct comparison with the same CPU, so as to understand if it changes a lot with the simple transition from Celeron to P4, I think there is a certain difference, because in the past I had changed a P4 2000 with a Celeron 2600, and it seemed slower to me, despite the greater frequency.
I start with Phil's benches, for a couple it was not possible to see the results, one definitely due to the CPU speed, and the other instead could be the monitor (?), apart from this, here's what I got:
2) 615.3 3) 612.3 4) 127.6
5) 382.3 6) 57.3
A) 553.26 b) 139.09 c) 259.4 e) 122.8
K) 565.5 m) 505 n) 1603.17
In addition to these, I ran other DOS programs, including QTPRO obtaining:
CPU Bench Mark 518777 Dhrystones
262721K Whetstones
Compative about 48,000 MHz XBenchSpeed
And also those of NSSI 060
CPU Perf. Index: 836444 Dhrystones/s (839562, 16 bit code)
FPU Perf. Index: 212302 KWhetstones/s (212729, Real mode).
Phil's scores of the DFI NB78-BL, are these:
2) 441.5 3) 523.7 4) 90.3 5)284.8
6) 46.3 a) 461.05 b) 103.16 c) 216.7
E) 60.3 m) 463 n) 1108.15
All inferior to the AZZA, sometimes the gap is clear, as in n), but I consider the integrated video card, a disadvantage compared to the ATI 9250 AGP of the DFI, so some could be even ️ better.
It remains to replace the TC23 SACON 3300uF 6.3V, for complete recovery, then you should decide the amount of memory, and whether to use an AGP VGA instead of the integrated one.
After replacing the swollen electrolytic capacitor, I would have to upgrade the memory, and the disk to use, to load Windows XP (probably), from there then I can run other bench programs, such as CPU-Z Sandra BMX etc...
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
