Maj.Jackyl's Computer Lab
Reply 120 of 236, by Major Jackyl
And so it begins... I brought the case for the Micron Millenia back in, so I'll be cleaning that up in the coming hours and then, hopefully, reassemble a working computer with minimal parts costs. I also salvaged the PSU out the the AST 8066. I cleaned it earlier and have yet to test it.
The attachment 20250612_074055.jpg is no longer available
The attachment 20250612_074117.jpg is no longer available
I modified the RTC last night. Did the "quick" job, because I learned last time, the 2032 is too large to fit next to the PCI connector and I had to angle the battery. This time I bored into the side and cut the battery lines and legged my way to the new battery from there.
The attachment 20250611_204756.jpg is no longer available
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 121 of 236, by Major Jackyl
I forgot, I harvested a floppy drive from the AST, too. I totally forgot I left it in there. I was hoping to fix that one, but it was far beyond repair.
The attachment 20250612_194605.jpg is no longer available
I'm pretty much all together. I came into one bump. I forgot this case takes rails for the 5.25" bays. I was thinking about stealing them from the other one and installing a blank, but I think I will just make new ones.
The attachment 20250612_185015.jpg is no longer available
The attachment 20250612_201533.jpg is no longer available
The attachment 20250612_200236.jpg is no longer available
The attachment 20250612_213419.jpg is no longer available
Reply 122 of 236, by Major Jackyl
I have a CDROM sitting on top right now, so I can continue. I just got done formatting (a Seagate 4.3GB) and am installing Windows 95, since the case has a fancy sticker for it. I've been skipping 95 since the trauma of growing up with it. 98 was so much better. This may be my only 95 computer.
The attachment 20250612_213435.jpg is no longer available
The attachment 20250612_211003.jpg is no longer available
The attachment 20250612_213047.jpg is no longer available
The computer had an error at first when I tried installing, thinking my partition was invalid (probably was, was a used drive with freeDOS on it). I repartitioned and formatted it and then it was able to continue.
Hmmm. It just got "done" installing. It was at 100% when it had three different errors, then another one when it sent me back to the prompt. Not sure what happened there. I'll try again tomorrow, otherwise, back to 98, 🤣
Reply 123 of 236, by Major Jackyl
I had an emergency dispatch for misfire on cyl6 on a RAM 5.7L... Going to need lifters and a cam. Ouch.
I continued work on the Micron and successfully installed Windows 95! It was the drive... In the BIOS, it didn't show up as the right capacity, but it was still a drive with the proper capacity in DOS. Strange how it got that far, but wouldn't take Windows. I went with a 2.1GB Maxtor and it was all the same until I got to the end of the installer, and it actually restarted and booted.
The attachment 20250612_202914.jpg is no longer available
The attachment 20250613_184941.jpg is no longer available
Now, I need drive rails. I stole the drive out of the other Micron, because the body on this one is nicer and while it was out, copied dimensions from the OG drive rails and printed out a few of these:
The attachment 20250615_211018.jpg is no longer available
I just left a hole in front for a screw, so I can easily remove them and not break them every time. The OE ones have a plastic one-way clip on the and (squeeze to release).
The attachment 20250613_200131.jpg is no longer available
I also cleaned the final part: the HSF.
The attachment 20250613_180418.jpg is no longer available
Now I'm back and kinda forgot where I left off, so I'll power it up and see. Pretty sure I was just installing games, because it was all working.
Reply 124 of 236, by Major Jackyl
Ah yes. I was at the part with no sound in Windows. Easy solution: install drivers, 🤣 Got that taken care of and I got sound in windows. I opened duke3d for a test, but resources don't match what I had setup in DOS, so no sound. Rebooting into DOS and setting the blaster let the sound happen.
The attachment 20250612_200304.jpg is no longer available
I thought I had a video card issue, because there are persistent vertical stripes across the screen, sometimes more visible, like at the windows95 splash.
The attachment 20250612_201519.jpg is no longer available
The attachment 20250616_133521_1.jpg is no longer available
The attachment 20250616_133538_1.jpg is no longer available
I switched to a CRT and they were gone. BUT, as a bonus, when I run keen4 from Windows, there is seizure-mode enabled:
The attachment 20250616_132640_1.jpg is no longer available
This mask flashes at high frequency, seems like half of refresh rate. It doesn't do it in DOS. Maybe I need better driver for the CL? I'm using the one that came with windows. I have the driver disk that came with the card somewhere, so I'll give that a spin.
Reply 125 of 236, by Major Jackyl
I tried the driver disc, nothing changed. No DOS apps in windows on this one, then. This one will be known as Hi-10, so I don't confuse them. The other one is now Hi-9.
I'll call it good, since it doesn't crash and everything works fine is DOS mode. I just put windows on because of the sticker, this is totally a fast DOS computer. I'll probably sculpt a boot menu/config/autoexec later.
I pulled the Hi-9 back out (again agian) to put a proper CDROM back in. I left it empty when I stole the drive for the Hi-10. I grabbed a few that might look the part, but decided on this 12X, because the yellowing almost matches perfectly AND it's almost as old as the computer.
The attachment 20250616_142528.jpg is no longer available
Big issue I noticed only AFTER I had it mounted: The eject button was broken... and you know what else? This drive does NOT have an eject, BUT the tray DOES just pull out.
The attachment 20250616_143533.jpg is no longer available
Not acceptable. I checked functionality and it was good (although, my CDROM driver takes a long time to load), so it's time to replace that button:
The attachment 20250616_143314.jpg is no longer available
The attachment 20250616_145016.jpg is no longer available
The attachment 20250616_150034.jpg is no longer available
I had to open it all the way manually before it started operating normally again and now it works great! I'm just left wondering why my CDROM driver takes so much longer to load. I'll try other drivers, to see if maybe the driver is not liking the drive. Not too often I see that, but it happens sometimes with the TEAC_CDI driver I normally use.
Reply 126 of 236, by Major Jackyl
Here's those two together:
The attachment 20250616_152227.jpg is no longer available
The attachment 20250616_152302.jpg is no longer available
The attachment 20250616_152313.jpg is no longer available
Reply 127 of 236, by Major Jackyl
With the Microns out of the way, I picked up this again to look at where I left off:
The attachment 20250619_201440.jpg is no longer available
I needed cabling and a PSU. I have a few that I can choose from, but they're pretty damn dirty.
The attachment 20250619_201726.jpg is no longer available
I will clean them all and inspect the goods before choosing. I'll be un-p4ifying whichever one I choose as well.
Reply 128 of 236, by Major Jackyl
Got a lot to report today.
I've been working a big job, a hundred miles away. Here's the failure, if anyone is interested:
The attachment 20250621_183254.jpg is no longer available
Now to computer related business:
First off, I only cleaned one power supply and got distracted testing it. Then I installed it into the MSI-6712.
The attachment 20250624_165456.jpg is no longer available
The attachment 20250624_174225.jpg is no longer available
Nothing unusual at all. Fired right up and was able to install windowsXP and played around with it for a while.
The attachment 3DMark_2001_Result.PNG is no longer available
I set it aside last night to try to install Linux Mint on a computer, as I want to check it out. The motherboard (Gigabyte Z390 GamingX) will NOT boot from a SATA drive and Mint decided to install there, because it thought the leftover boot record on the spinner (I should have removed the partitions) was the live windows 10. It still boots 10 from nvme and can't even be given the option to boot from the drive with the boot-loader. Lame.
The attachment 20250625_170519.jpg is no longer available
I'll reformat it and try again... BUT that will be later... I have to review the computer(s) I got from my brother this morning. Absolute barn-finds! Two mystery machines, one is revealed (and clean, untested), one yet to be. I'm in such suspense!
Reply 129 of 236, by Major Jackyl
Here's the first unit I cleaned, since I knew I was going to be pretty easy.
The attachment 20250625_113526.jpg is no longer available
It is a PowerSpec with ASUS P5G41C-M with a Core2Duo E7500 and a single 2GB stick of DDR2-800. Also inside were a WD500 GB HDD and a DVD multi drive.
The attachment 20250625_114612.jpg is no longer available
The attachment 20250625_120034.jpg is no longer available
The attachment 20250625_132856.jpg is no longer available
It has a lot of corrosion from sitting in the barn, but it came pretty clean.
The attachment 20250625_132841.jpg is no longer available
The thing is bone-stock as they come. Fire-starter PSU. Green stick. Onboard VGA. It's got it all. Absolutely nothing exciting. This next one, though... Oh boy. I've seen enough so far to know I'm excited.
(edit: ope, 🤣 duh, it's an ASUS)
Reply 130 of 236, by Major Jackyl
I haven't gotten into the next one yet, but here's a sneak-peek (same peek I've taken)
The attachment 20250625_133519.jpg is no longer available
It's a Gateway SELECT with a... K7?! So hyped for this one!
The attachment 20250625_142204.jpg is no longer available
The attachment 20250625_142154.jpg is no longer available
Gaah. I can't work on it now, but I'll get to it soon. I want to try to get Mint running on Jen so I can put her away and test the PowerSpec, so I can put THAT away.
Reply 131 of 236, by chrismeyer6
Man that is one seriously wiped out cam lobe. How much metal is in that motor?
Reply 132 of 236, by Major Jackyl
chrismeyer6 wrote on 2025-06-26, 00:08:
Not much. I've seen this engine do this plenty of times and it usually means "replace engine" once it's apart and the extent of the damage is observed. The roller on the lifter was still intact, although the bearings were gone.
I opened the Gateway, but a little late, so I can't really clean anything. Looks all stock except for that HP CD writer and maybe the SCSI.
The attachment 20250625_223312.jpg is no longer available
The attachment 20250625_224144.jpg is no longer available
The attachment 20250625_224910.jpg is no longer available
The attachment 20250625_230326_1.jpg is no longer available
The attachment 20250625_224938.jpg is no longer available
Reply 133 of 236, by luckybob
OH - OH - OH - O'REILLY...
Auto parts!
lord, thats deeply programmed...
Reply 134 of 236, by Major Jackyl
I cleaned all the parts from the Gateway.
The attachment 20250626_175602.jpg is no longer available
The attachment 20250626_175837.jpg is no longer available
I've identified the motherboard: Gateway 4000594 and the GPU:A Voodoo3 1000.
The attachment 20250626_180024.jpg is no longer available
The Sound card is a CT5803
It also has a nice Adaptec AHA-2906. I like having these around.
Lets not talk about the modem.
The attachment 20250626_180017.jpg is no longer available
The CPU is the original 600Mhz that came with the system and had a pretty heavy-duty cooler on it. The screws for the heatsink were T8 and came out very easy. The whole thing popped open pretty easily, too. Under the heat spreader was a 650 labeled CPU.
The attachment 20250626_175858.jpg is no longer available
I'm working on cleaning the PSU next and then the case. Hopefully, I can have this booted and running in a few hours. What mystery is within the drive? Will it boot 98? XP? Nothing? (that'd be lame) I absolutely love exploring old drives!
Reply 135 of 236, by chrismeyer6
They kinda look like small heatsinks but they don't actually touch the mosfets. Unless they sink the heat out of the motherboard PCB itself
Reply 136 of 236, by H3nrik V!
chrismeyer6 wrote on 2025-06-27, 00:40:
Would definitely fit the bill, especially since they are slotted probably for larger surface area ..
Reply 137 of 236, by chrismeyer6
That's what I'm thinking
Reply 138 of 236, by Major Jackyl
I asked my brother, too, he also thinks they are heatsinks. I've never seen them like that before. Neat!
I got most of the case cleaned up. I will do the PSU later, as I might not use it. 200W is a little weak. I'll see what's inside though, judge it better then.
I got the motherboard set-up with a known good PSU and the same memory it came with. I only added a known good AGP (SiS 6326) It powered on immediately when I flipped the switch and POSTed until it wanted CMOS/TIME etc. I set the time and restarted to reach a "no boot media" situation. I plugged in a few things. A known good floppy, the OE drive from the Gateway, and a CDROM I wanted to test.
The attachment 20250626_204650.jpg is no longer available
I powered it on to a violent outburst of head clatter and irregular whining. Ope. Found the problem. Damn. The drive is bork'd.
The attachment 20250626_204617.jpg is no longer available
I unplugged and replaced it with a similar sized drive (10GB) and started the format/win98 process. It's almost done formatting.
Reply 139 of 236, by luckybob
100% heatsinks.
its SUPER DUPER common to use just the huge ground plane of a motherboard as a giant heatsink. BUTT... That only goes so far. And since the mosfets are SMT not thru-hole, your options are limited. If you've ever wondered why its so hard to re-cap a modern (ish) motherboard without a 150W soldering iron? its because the ground plane is working as intended. ^.^
