Reply 120 of 169, by Kahenraz
Hi. I'm interested in using this card with my HP thin client, but in worried about compatibility. I've had a lot of trouble getting any of my Yamaha PCI cards to behave with this system.
My YMF724 breaks the keyboard, both USB and PS/2. It just stops working, and there is a screeching sound that comes from the onboard audio when the system is powered on. The YMF744 doesn't break the keyboard and doesn't have the screeching sound, but the BIOS doesn't assign it an IRQ and so it can't work in either DOS or Windows.
I'm not sure what the issue is with these cards and this particular platform. I've had mixed luck with some other cards but most of them work, such as the ESS Solo-1.
Are you familiar at all with these problems or why they might be occuring?
174.71 KiB
283.54 KiB
231.63 KiB
Reply 121 of 169, by hard1k
Kahenraz wrote on 2022-05-28, 06:17:
Hi! Not really. But thinking that our sound controllers will be behind another PCI-PCI bridge, so the actual behavior may be different from the one you've experienced.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 122 of 169, by hard1k
Hello everyone!
We have great news: both parts of Fortex function just as planned, and their digital interconnection (S/PDIF Out from AU8830 going into S/PDIF In of YMF744) works great too!
However now we have an urgent need for a good coding guy who would be willing to help us out. The matter is that YMF744's S/PDIF Out is functional in Windows, and also in the MS-DOS Mode (when you "exit" from Windows into MS-DOS without actually rebooting the PC). But when you reboot, it gets disabled, and there is no way to activate it except starting Windows. This problem was already mentioned before (Re: Yamaha XG with S/PDIF out ?), and no solution has been found if I'm not mistaken. So, we need someone who could find the needed YMF744 register, identify its needed value, and write a DOS utility to restore it after reboot. A patched version of SETUPDS would also be just fine, but a separate utility seems a bit more elegant to me. Maybe Linux drivers could be useful, I know that Linux driver for YMF744 exists as a part of the ALSA, and also the OSS (Open Sound System):
http://opensound.hg.sourceforge.net:8000/hgro … /drv/oss_ymf7xx
If we find a kind person to help us, it will define the further development of the hardware design - then we'll be able to make the "upper" expansion board based on S/PDIF DAC, with superior quality (if compared to the AC97 codec). And if we don't, we'll have to revert to the basic simple approach, taking the Line-Out from the STAC9707T.
AWE64 Legacy
Reply 123 of 169, by Bancho
Rayer on this board is probably someone you want to speak too. I thought he wrote a tool for pure Dos SPDIF for the YMF cards. I think I remember reading the registers were found in a thread on here.
Reply 125 of 169, by hard1k
Guys, you two are absolutely awesome, thank you so much! If you ever decide to buy a Fortex once it is released, both of you are entitled to a 10% discount off retail price, for your valuable contribution. Just please don't hesitate to remind!
AWE64 Legacy
Reply 126 of 169, by Shreddoc
You're very welcome, and thank you! 😀 (tbh, Bancho's tip made it easy for me to find - but am very happy to have helped in any way)
Progress is great! Continuing best wishes for this awesome project.
Reply 127 of 169, by biohazardx9
Wow what a project. Really liking this.
Well done hard1k for getting this far. I am very keen to learn more.
To remake a card is one thing but to fuse two together is another...
Reply 128 of 169, by Sphere478
Very nice. Following.
Sphere's PCB projects.
Reply 129 of 169, by Warlord
was getting a little impatient, so I tried the real thing. SQ2500 + Labway 744
I did digital out on vortex to digital in on XG
Initial impressions are IRQ and resource nightmare, but its doable on Asus p4p800se reserving IRQ 5 and 7 in the BIOS helped. I assign SB emulation for the vortex on IRQ5 and Sb emulation for the XG on IRQ 7.
Only thing I tested so far was Tyrian 2000. I used Vortex for SB emulation and XG for midi and the game tested good and ran fine like that. No crash. This game does not run of XG without SB link and either crashes or doesn't work with either driver set, however the MIDI works with VXDs.
Reply 130 of 169, by hard1k
Hello everyone,
I guess you thought that Fortex was on hold but not yet!
We've been sorting out some minor bugs, and just ordered a new prototype:
155.57 KiB
189.56 KiB
139.99 KiB
So far we are stuck with only one major issue - when we choose YMF744's external MIDI in the Win9x multimedia applet and try playing anything (i.e. sending any MIDI command), the player stops responding. We need this function for the wavetable header, and haven't come even close to understand the cause of this behaviour, it just hangs no matter if daughterboard is there or not, or if the AU8830 part is enabled or disabled:
174.66 KiB
Video: https://drive.google.com/file/d/1tp_u_SCRDVZ0 … iew?usp=sharing
We've tested the same thing on a regular YMF744 card, no issues at all, working as intended.
So far our two hypotheses are:
1. We've got somewhat faulty YMF744 chips - will be tested on the next prototype by soldering a tested chip from a working donor card.
2. YMF744 MIDI controller/driver does not like sitting behind a PCI-PCI bridge - we need some help from the community to test a regular YMF744 board on any period correct server/workstation motherboard that has a secondary PCI bus derived from an Intel/TI/DEC PCI-PCI bridge chip. For example, an Intel L440GX+ will do perfectly. Anyone willing to help out there?
AWE64 Legacy
Reply 131 of 169, by ExplodingLemur
hard1k wrote on 2023-04-23, 14:52:
I just bought an L440GX+ off eBay and I've got a YMF744 sound card to test with. I'll give it a try when the motherboard arrives.
Reply 132 of 169, by hard1k
Great, thank you very much!
AWE64 Legacy
Reply 134 of 169, by hard1k
I don't believe that's the case actually, but what we're trying to achieve is to discard any malfunction of YMF744 behind a PCI-PCI bridge. So the chipset doesn't really matter.
AWE64 Legacy
Reply 136 of 169, by hard1k
Exactly.
AWE64 Legacy
Reply 138 of 169, by hard1k
We'll find that out soon, I guess!
AWE64 Legacy
