Reply 1520 of 1525, by konc
- l33t
TheIpex wrote on 2026-01-03, 04:15:With help of the 3D printer, I've added a 40mm fan to the chipset and a small heatsink to the VRMs
Looks nice! What did you use the 3D printer for exactly?
konc wrote on 2026-01-03, 08:59:Looks nice! What did you use the 3D printer for exactly?
Thanks, the small black clips that hold the VRM heatsink in place are 3D printed (It's only a regular thermal pad beneath and I wanted it secure). There is also a mounting plate beneath the 40mm fan that clips onto the chipset heatsink. It's all pretty rudimentary but I'm happy with how it turned out.
I wish I'd taken some closer photos before I installed it all, here are the 3d renders:
TheIpex wrote on 2026-01-03, 09:15:Thanks, the small black clips that hold the VRM heatsink in place are 3D printed (It's only a regular thermal pad beneath and I wanted it secure). There is also a mounting plate beneath the 40mm fan that clips onto the chipset heatsink. It's all pretty rudimentary but I'm happy with how it turned out.
They're perfectly fine, I saw that the printed parts are what's secured to the board but I couldn't grasp how exactly they hold the heatsink. Thanks, now I get it and it's a very nice and simple idea.
Setup 2 more "lotto miners", this time using the open source NerdMiner V2 software on a couple "cheap yellow display" or "CYD" (ESP32-2432S028) dev boards. I've got 4 of these I picked up on sale over on Amazon for various projects. Two of them I dedicated to messing around with BitMaker's NerdMiner open source ecosystem. Now that I've got them flashed, running, and mining, I just need to give them a proper home. I spent a couple hours last night designing what I hope will be a cool stand for them to sit in. I'll be printing them later today to see if I messed anything up or not.
The device shown in my post a couple pages back is also a CYD dev board, but it's running the proprietary closed source NMMiner software and it's pushing just over 1000 KH/s. I wanted to go open source this time, and the best out there for that is the NerdMiner software, but it's currently limited to about 300-400 KH/s. Though apparently, the BitMaker team has said they are working on getting full use out of the ESP32 to catch up to NMMiner and get up to 1000KH/s. Not that it really matters, these are really just cool fun tech toys, at this low-end solo mining, that 500-600 KH/s difference really doesn't amount to anything. It's just cool to see it run as fast as it can!
I just picked up a USB slitter so I can power both at once off one wall wart.
Never thought I'd have so much fun playing a lottery with a virtually nonexistent chance of actually winning. 🤣
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Customized a simple case I found. Stand came out well enough. My "NerdMiners" now have a proper home to play the Bitcoin lottery. 🤣
Just need my Micro USB splitter cable that's arriving tomorrow. 😀
At that low a hash rate you can probably quintuple your odds by putting a hula hoop on your front yard and waiting for a solid palladium asteroid to fall in it.
