Reply 15280 of 27783, by Peter Swinkels
Okay. Thanks.
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 15281 of 27783, by digistorm
derSammler wrote on 2020-05-13, 15:00:
50% water, 40% vinegar, and 10% rust converter. The rust converter was just to speed up the process and is not needed.
What kind of product is this rust converter? Could you name a brand or the chemical in it?
Reply 15282 of 27783, by derSammler
Zekol, a brand of ALDI. Nothing special, really.
Reply 15283 of 27783, by chrismeyer6
That looks alot better. How long did that process take?
Reply 15284 of 27783, by derSammler
Less than 4 hours. 😀
Reply 15285 of 27783, by chrismeyer6
Wow that's nice and fast
Reply 15286 of 27783, by Bruninho
computerguy08 wrote on 2020-05-13, 07:00:
Bruninho wrote on 2020-05-12, 22:20:
But XP in VMware does not get more than 128mb video ram, rendering it practically useless for the games I wanted to play.
You can set the machine as Win 7 x86 but have Win XP installed on the virtual hdd, this way you'll get around the 128MB limitation.
For real? I'm gonna try it
EDIT: does not work. the installer crashes (BSOD) while starting the install.
JOBS, Steve.
Reply 15287 of 27783, by bjwil1991
Swapped the CD-RW drive with an Apple 32x CD-ROM drive (Matshita CR-589-B) on my 486 build as the CD-RW drive doesn't work with 486 systems when connected to the secondary channel. Tested my theory with a CR-585-B CD-ROM drive that my Packard Bell has installed externally with the 486 build and that worked. I kept thinking that it was a bad IDE cable, but it wasn't and not only does the system run better than before, it's basically complete and 1 thing to do is wait for the 512KB L2 cache to arrive (stuck in another state), the 5x86-P75 to arrive (for my Packard Bell to test my 3.3V CPU support mod), and swap CPUs around as the Kingston TC-5x86/133 is between the DX4-100 and Pentium 75 speed using NSSI to do benchmarks. Probably because it's WT cache or the slower version of the 5x86-P75, which is a possibility, but I digress.
Reply 15288 of 27783, by ragefury32
Wasted almost 3 hours trying to get my router-of-doom to work with my Turtle Beach Santa Cruz PCI - not sure which system resource is making it choke, or is it due to the drivers not playing ball with the Via ESP5000 - the VxD drivers does not load on start and the sound card does not work. The WDM drivers just gives Win98 protection errors. Pure DOS mode with TBCDOS does dit squat. Doesn't look like a hardware issue - the card works just fine with DSLinux. So right now the choice is the YMF744 (doesn't work due to BUS noise, or it could be a card issue), keep beating on the Santa Cruz until it works (or try it with XPe), or get another card...
Reply 15289 of 27783, by Caluser2000
Been playing around with another Acorn RiscPC. This one has 3.6 roms and was booting to the * prompt because of a directory error. After a bit of mucking around, finding a newer !SparkPlug app I got !UniBoot loaded on it. Only one more boot error to eliminate now. I'm quite pleased with progress and getting a better idea how RiscOS works. Basically a collection of toolboxes really.
Reply 15290 of 27783, by HannibalAnthrope
Caluser2000 wrote on 2020-05-12, 20:23:
Maybe a thread on customizing Win7 in the Marvin Software section would be a good idea?
Good idea, I've started the thread and I'm working on the guide and will post it within the hour.
It will feel good to be able to share what I've learned about Win7 because the whole ordeal happened because of Win10 and that was a very frustrating experience and there's a cloud of anger & profanity still hanging in the sky above me from it! 🤣 If I can pass on what I learned to help out someone else then the negative becomes positive.
Feedback/suggestions/criticisms will be welcome of course. And questions too which I will try to answer promptly but promise to answer all of them.
Reply 15291 of 27783, by Caluser2000
HannibalAnthrope wrote on 2020-05-14, 04:58:
Good idea, I've started the thread and I'm working on the guide and will post it within the hour. It will feel good to be able t […]
Looking forward to it.
Reply 15292 of 27783, by Bruninho
Me too!
JOBS, Steve.
Reply 15293 of 27783, by HannibalAnthrope
Ok my first attempt at a guide is posted! I hope I didn't mess anything up. If I did let me know!
I didn't get too detailed figuring I'll wait until someone asks for more detail first then I can do step-by-step instructions. My worry is that something that worked for me will leave someone with a non-booting machine. But I will definitely add specifics when asked.
Reply 15294 of 27783, by CMB75
Upgraded my XT with an SIXPAKPLUS card from AST, replaced the battery and patched the software to be Y2K compliant… welcome another XT to the 21st century 😀
Reply 15295 of 27783, by Shagittarius
Bruninho wrote on 2020-05-13, 23:44:
Don't forget to set the RAM to 512MB or less too...Ooops sorry I thought this was about Windows 98, my mistake ignore this comment.
Reply 15296 of 27783, by computerguy08
Make sure that both HDD and CD-ROM are set in IDE mode. Otherwise XP will crash with 0x00007B at setup. VMWare automatically sets the CD-ROM in SATA mode if you choose Win 7
Reply 15297 of 27783, by Bruninho
computerguy08 wrote on 2020-05-14, 08:07:
Ahhhh, damnnnn... that was exactly what happened. I will try again later. Thank you.
JOBS, Steve.
Reply 15298 of 27783, by Bruninho
BTW, which hardware version should I use? 10, 11, or 12?
JOBS, Steve.
Reply 15299 of 27783, by computerguy08
Bruninho wrote on 2020-05-14, 15:31:
I used VMWare Workstation 12 with the newest hardware version (which is 12).
