Reply 160 of 170, by robertmo3
Alternatively you can play on a big monitor or tv without scrolling.
You don't even need 4K. 1920x1080 (HD) is enough for this game.
gameflorist wrote on 2024-03-19, 20:24:mikesk8 wrote on 2024-03-17, 14:21:Thanks a lot! I have just started testing and got stuck 😉 The Dune II via Dosbox Staging works fully ok with Roland SC55 (via Coremidi). However, in Dune Dynasty I cannot get any music from my Roland. I have checked all the settings, but always the music plays via computer speakers and not via Roland SC55 (connected to Mac via Roland Midi-USB interface).
Do you maybe know what I need to put in CFG file?
unfortunately i don't think there are any config options, that could help you here. i don't know much about MIDI on macOS, but it seems there are 2 interfaces regarding MIDI on mac: Core Audio and Core Midi. both are supported by Dosbox, but Dune Dynasty only supports Core Audio, and not Core Midi. maybe there is a way to tell Core Audio to use an external MIDI device instead of the built-in by default (e.g. by setting a default audio device)? but maybe Core Midi is required to do that, in which case i believe there is unfortunately no way to accomplish with Dynasty, what you are trying to do.
Hey. I just wanted to say - I love your sourceport, great work and thank you!
I have one question - would it possible to release a DOS port? Playing it on real period correct hardware would be amazing!
Socket3 wrote on 2025-02-14, 16:26:Hey. I just wanted to say - I love your sourceport, great work and thank you!
Thank you! 😊 David (the original Dune Dynasty dev) and the OpenDune devs deserve 99.9% of the praise though.
Socket3 wrote on 2025-02-14, 16:26:I have one question - would it possible to release a DOS port? Playing it on real period correct hardware would be amazing!
Unfortunately that's not really possible, since Allegro 5 (the library used by Dune Dynasty) does not support DOS.
gameflorist wrote on 2025-02-15, 11:15:Thank you! 😊 David (the original Dune Dynasty dev) and the OpenDune devs deserve 99.9% of the praise though. […]
What about windows 95/98? - never mind, answered my own question - allegro 5 requires windows XP.
I just wish there was some way to play this on DOS/Win9x... Hell, I'd even pay to have a copy of an OpenDune based DOS / win9x port that supports multiple unit selection and unit grouping. Alas, nobody with the required skill seems to be interested in making one...
@gerwin has made XP builds of Dune Dynasty, and a DOS protected-mode build of OpenDune here. However, I just checked, and OpenDune does not have the QoL improvements of Dune Dynasty.
Does the latter really require Allegro 5.0? Can it be back-ported to something lower? I fancy that any of the new features in the port like multiple unit selection are not dependent on a specific version of Allegro library.
MrFlibble wrote on 2025-05-27, 13:45:and a DOS protected-mode build of OpenDune here.
Well, that was just an experiment. The OpenDune sound system is unsuitable for DOS, and therefor there is no sound at all in that quick port.
Socket3 is aware of that: Need help from a programmer.... porting Open Dune/Dune Legacy/Dune Dynasty to MS-DOS thread
Backporting to Windows XP is more my thing. 😀
It would be cool if these newer versions of portable game dev libraries like Allegro 5 and SDL2 (or even SDL3!) could be ported to DOS, as well as older Windows versions.
The one challenge would be lack of support for modern 3D acceleration APIs (OpenGL and Vulkan), but many of the games that we would like to see in DOS are 2D anyway.
Same thing with the upstream DOSBox project: if I remember correctly, it's being kept at SDL1 and older C++ standards, just for the sake of being portable across legacy and retro OSes. But wouldn't it make more sense to put more effort in porting newer libraries to these OSes instead? That would make the applications (emulators and games) more maintainable in the long term, while unlocking more ports on these OSes.
I know, this would undoubtedly be much harder in practice than it might appear in theory. But apart from the lack of modern 3D acceleration APIs (and possibly multi-core CPU support), I don't see any reason why this wouldn't be feasible.
Newer OSes downstream do have a SDL1-compat layer library (with dosbox in mind), but as SDL3's a thing now, there's also a sdl2-compat.. it's a cycle
(also for every "u can just upgrade to sdl2 it's better" i wish them a very "the event system has been shut down")
long live PCem
Debian's fucked
Hey everyone,
I hope you all are well!
I've just released Dune Dynasty v1.6.4. You can get it on the GitHub release page.
Here are the release notes:
"The packages must flow."
Changes:
Additional info:
Many sound effects in Dune II were built with a DC offset. This leads to distortions when playing a lot of sounds together, such as pops and clicks. A fixed version of the affected VOC.PAK file was made by Tiddalick and can be downloaded on ModDB (see Readme for the download-link).
Have fun and let me know of any problems you encounter!
gameflorist wrote on 2025-05-31, 17:41:Have fun and let me know of any problems you encounter!
Is it possible to change Linux runner on GitHub for both x64 and ARM64 to Ubuntu 22.04? With current binaries, I'm unable to run them on (still the latest) Debian Bookworm.
Srandista wrote on 2025-06-16, 20:26:Is it possible to change Linux runner on GitHub for both x64 and ARM64 to Ubuntu 22.04? With current binaries, I'm unable to run them on (still the latest) Debian Bookworm.
Do the flatpak-versions work? I think it's best to use those, since they should get rid of all compatibility problems.
