Dune II HD port at last!
First post, by Iris030380
Decided to fire up Dune II on DOSBOX and was thoroughly enjoying myself until I started to get beat back by waves or ordos on Mission 5, and a sandworm ate both my harvesters while I was trying to individually select each unit of my army to move them up the map.
Amazing game with some slight flaws, like you can only select one unit at a time. Back in 1993 it didn't matter. It was original and to be honest, one of the best games I have ever played. But I was thinking, it's 2012... people have remade all kinds of games over the past 10 years. I wonder if they got round to Dune II yet...
And I found this port which seems relatively new. It keeps the game vanilla, baring some optional 'improvements' such as a better AI and harder (insatiable!) sandworms (NO THANKS!). It's easy to set up. Just unzip the program, add the original .pak files from a Dune II installation into the DATA folder and off you go. You can change/edit the games features by removing the 'sample' extension of the config file. It supports HD and .... You CAN select multiple units at once!
Anyways, download is here...
http://dunedynasty.sourceforge.net/
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 1 of 170, by leileilol
It's amusing that there's so many Dune II reproduction projects out there all of a sudden when there's been nothing for any Westwood RTS for so long.
long live PCem
Reply 2 of 170, by F2bnp
That's cool and all, but is there any reason to play Dune II other than pure nostalgia? The game's mechanics have long been surpassed my later games by Blizzard and Westwood themselves. It happened in a matter of just a few years.
Maybe it's just me, I could never get into it after having played the later games. The fact that you can't control units with your mouse and have to press buttons to command is also kind of a killer for me (can't play Warcraft 1 for the same reason).
Reply 3 of 170, by Joey_sw
as for RTS I prefer the sidebar interface like in classic C&C & Red Alert (C&C: Generals not included of course),
I like it better than warcraft style 'unit/building commands' interface,
but that just me as most people I know prefer the otherwise.
-fffuuu
Reply 4 of 170, by Iris030380
And this HD update fixes both of those very issues. You use your mouse to select and command units, there is a new sidebar interface for building, and you can play in any resolution you chose.
Reply 5 of 170, by VileR
Looks nice, thanks for the heads-up.
Anyone try this with one of those music packs? I like the OPL soundtrack well enough, just curious what else is worth trying.
Reply 6 of 170, by gerwin
Finally!
I haven't tried it yet, but OpenDune with Hi-Res and improved controls is the ideal combination.
There have always been remakes around.
But none of them ever replaced the original Dune 2 on my system. Dune II The Maker last demo was from 2006 and keeps teasing with news, but no new release. Now it doesn't matter.
Reply 7 of 170, by Iris030380
Glad to spread to love <3
Reply 8 of 170, by Leolo
I'm using this SC-55 pack:
http://dune2themaker.fundynamic.com/?page_id=102
And to me it sounds much better than the AdLib music.
I haven't tried the MT-32 version yet, but I think it's inferior.
Take a look (or maybe "take a heard") at the differences:
http://www.youtube.com/watch?v=TqCDj0IRSTk
http://www.youtube.com/watch?v=TK5TwFaKA2M
I very much prefer the SC-55 version.
Reply 9 of 170, by Iris030380
OK I downloaded the music packs but how do I get it to work with Dune Dynasty? ^^
Reply 10 of 170, by gerwin
This is as good as I hoped. Very enjoyable.
I did encounter a problem on level 5 of the harkonnen. The carryalls airlift any heavily damaged vehicles to the repair facility as intended, but return them to the field unrepaired?, and then the carryalls repeat this process.
@Iris030380
dunedynasty.cfg holds the configuration for the music and such.
Reply 11 of 170, by Leolo
I had to convert them to FLAC using foobar2000 and the FLAC encoder.
Take the instructions here:
http://www.howtogeek.com/howto/15577/how-to-r … ith-foobar2000/
But ignore the part about Audio CDs. Just load the mp3 files and select them, right click and then "convert".
PS: By the way, I've downloaded the MT-32 pack and many tracks are exactly the same as in the SC-55 pack!
The intro, for example, is identical. And it seems it was recorded from an MT-32 🙁
Reply 12 of 170, by VileR
That SC-55 pack is weird - the genuine MIDI tracks sound great, but as Leolo says, they're identical to the MT-32 ones. And the tunes you hear throughout most of the game are clearly just OPL versions (attack*.mp3, peace*.mp3, mentat*.mp3).
At least the MT-32 pack lives up to its name - still, an actual SC-55 soundtrack would be nice to have.
Reply 13 of 170, by Leolo
Yes, it would be great to have the SC-55 soundtrack.
Could somebody with access to such a Roland unit play the MIDI files and record them to FLAC, please??
By the way, there's another MT-32 pack here:
http://dune2k.com/Downloads/26
Click on the third link, the one called "Dune II Music mp3" from Jun 10, 2005, and then dump the OGG or FLAC files into the "fed2k_mt32" music folder of Dune Dynasty.
Guys, how do you manage to play this game in full screen with widescreen monitors?
Windowed mode respects the aspect ratio, but going full screen destroys it and squashes the image! 🙁
Reply 14 of 170, by VileR
That's strange. I'm using 5:4 monitors - not widescreen, but not 4:3 either; still there's no distortion in fullscreen (I get square pixels, same as in windowed mode).
Did you set screen_width and screen_height correctly in the .cfg? they should match your monitor's native resolution. If things still get stretched, it's probably some setting in your video card's control panel.
Note that having square pixels isn't very true to the original aspect ratio either... it's already kind of squashed compared to 320x200 on a 4:3 CRT, but that's as good as we're gonna get.
Reply 15 of 170, by GL1zdA
"Multiple unit selection with control groups" - it's like selecting an "easy difficulty" 😉
getquake.gif | InfoWorld/PC Magazine Indices
Reply 16 of 170, by gerwin
The difficulty change indeed asks for some compensation, fortunately there are options for insatiable sandworms and harder AI.
V1.3 is out. Hmm,The repair-bay issue is not listed in the changelist.
Reply 17 of 170, by WolverineDK
I am waiting for a Linux Mint deb file or an easy way from the software manager part of Linux Mint. Cause there is no way in hell I want to go into compiling mode again (I burned my fingers once there, so no thank you).
Reply 18 of 170, by VileR
Hey, v1.3 has support for custom campaigns and modding. Wonder how far this could go -- would be nice to have campaigns based on Children of Dune, or (better yet) Heretics of Dune!
Reply 19 of 170, by Leolo
Hey, don't be so pessimistic! 😜 The problem of non-square pixels can be solved (dosbox and scummvm can do the aspect correction in software, for example)
Let's keep the hope alive for aspect ratio correction in Dune Dynasty also! 😉
