DS12887 drop-in replacement
Reply 160 of 175, by olebakk
I have assembled a few more of these and to my surprise they do not work (the first two I made seem to work fine still)! I have checked all pins - but I suspect that the chips I use (cheap ebay stuff) is not working properly (same batch as the first two though). Most mainboards just refuse to boot them, but I got an old bord to boot one of them - and noticed that the seconds actually counted to 100! (showing a time of 04:03:89 and so on).
Anyone know of a reliable (but cheap) source of chips?
Reply 161 of 175, by Maeslin
Shadow Lord wrote:
Hello All,
I have purchased a few of these from Maeslin and they are great! However, I now have a system that uses a DS1497 (basically a DS1495 w/ built in battery). Does anyone know if these would work as a replacement for the DS1497? TIA!
Unfortunately it looks like the logic and adressing on the DS1495/1497 is pretty different from the DS12887. I could make up a similar board using a DS1495 SOIC, 32khz crystal and battery holder but I would have no way to test it.
gottspeed wrote:
Can these still be purchased from Maeslin?
I have a good number of them, unfortunately for single modules the shipping ends up being more expensive than the module itself. If it's a bigger order I might be able to arrange something.
Counting seconds to 100 is definitely new. Might point to a poorly-done fake.
I think I got a batch of them off aliexpress initially. I'll have to dig through old email and get back to you.
Reply 162 of 175, by Shadow Lord
O.k. No worries and thanks for the reply. I believe a member on VCF is already looking into producing a board that can make uses of the DS1495. TIA!
Reply 163 of 175, by feltel
I probably could need one or two of those Alt12887 replacements as I prefer a clean solution over hacking and glueing an old Dallas module. The Alt12887 should be drop-in compatible with old DS1287 modules used in IBM PS/2s. Unfortunately there seems only sources for this project in the United States as it seems. Is there anyone aware of sources for build modules within Europe? Due to high shipping costs from US to EU and customs a single module would cost nearly fifty Euros, which is a steep price.
Reply 164 of 175, by Tiido
I actually have a small handful of the PCBs in my hands, in green. I can mail one or two for shipping cost within EU, parts you need to gather yourself though.
Reply 165 of 175, by feltel
It would be very kind if you could send me one or two of those PCBs. I actually never tried SMD soldering before but I'm willing to learn on the go. Unfortunately I could not PM you, probably due to my low posting count. Maybe it is working the other way around?
Reply 166 of 175, by Maeslin
I went with one of the largest (if not the largest) surface mount footprints specifically to make the job easier. It's doable with just a cheap iron and half-decent solder (just not plumbing solder. don't ask, I've seen it tried) but if you can find a little bottle of liquid flux and some wicking strip (looks like a flat woven copper 'strap') it helps a great deal. I recommend tinning and cleaning the pads before putting the chip on.
To add, if you need to source more PCBs, you can get the whole package of gerber files from the oshpark link and have them made by any fab house of your choice.
Reply 167 of 175, by Tiido
You can send an e-mail to me, which can be found in the first link in my signature.
Solering the boards shouldn't be a problem, just have plenty of flux handly and it will go smoothly.
Reply 168 of 175, by matze79
Works very good!
Thanks for making this Project!
Reply 169 of 175, by Maeslin
matze79 wrote:
Works very good!
Glad you like it!
Word of advice, secure the 32khz crystal to the pcb with a drop of superglue under the case. It doesn't take much to tear it off the pads by accident if they're the only things holding it on.
Reply 170 of 175, by Maeslin
As a small update, there's now a DS1497 drop-in replacement counterpart to the Alt12887.
I have no way to test the unit since I don't have any systems that use those, but it's a completely passive adapter so issues should only be with assembly.
Reply 172 of 175, by matze79
Hi,
does anyone use ALT RTC inside IBM PS/2 55SX ?
on each reboot i get Error 163.
CMOS Settings and also Date is saved, but clock starts always again at 12:00:00
it does not save Time.
The ALT12887 works fine in other Systems.
Any suggestions how to fix this ?
Reply 173 of 175, by matze79
It works, one just have to set time with IBM PS/2 reference disc for first time.
if only set from DOS it does not save it.
Reply 174 of 175, by laseractive
Dear all,
I know this is an old posting, but I wonder if there are still people around
that have preassembled drop-in replacements for the Dallas DS1287
that would work in a Philips P3204 PC AT Computer?
If you have one for sale, then please let me know by a private message.
Many thanks for your help.
Kind regards from Belgium,
Christian
Reply 175 of 175, by mockingbird
laseractive wrote on 2022-09-09, 16:06:
Dear all, I know this is an old posting, but I wonder if there are still people around that have preassembled drop-in replacemen […]
Dear all,
I can make one for you, I still have parts for several, but there are several people already selling them on eBay.
(Decommissioned:)
