Reply 17220 of 57662, by einr
- Member
wrote:Is that floppy drive a 2.88 one? The print on the eject button is too small to read 😜
Naw, just a garden variety 1.44M.
wrote:Those symptoms would be consistent with a dead Hard Drive. My guess is it was dropped while running causing a head crash. Shutting the lid too hard can do it as well (I've done that once myself).
Well... I tried switching out the harddrive for a CF-IDE adapter I had laying around and it still doesn't work. Same symptoms. '
If I run the setup program on the reference disk, it does show hard drive as "installed" but FDISK and FORMAT won't find the drive and it's impossible to boot from it.
What's more, the diagnostics on the reference disk wont find and test the hard drive, but the rest of the tests all pass except for the hard drive LED. It doesn't turn on/off like it should. This leads me to believe that maybe something is up with the ribbon cable going to the drive..? Or some kind of controller issue? The drive does get power, at least intermittently, because before I switched the mechanical drive out I could hear it seek test at boot sometimes.
Any ideas, anyone? These are obscure machines, hard to find much troubleshooting info.
