Reply 19760 of 27685, by BitWrangler
- l33t++
wiretap wrote on 2021-08-20, 23:40:Just replaced the batteries in my iPAQ 3765 and the PCMCIA+battery backpack. Yay, no more bloating battery that distorts the scr […]
Just replaced the batteries in my iPAQ 3765 and the PCMCIA+battery backpack. Yay, no more bloating battery that distorts the screen by pressing on it when its plugged in. P1 is negative, P3 is positive, just in case anyone else wants to do the same thing. I had to plug in the iPAQ when it was disassembled and use a multimeter to find the positive voltage. Old batteries were 1500mAh or so.. new ones are 2200mAh. Should give a nice boost in run time.
Good stuff, where did you get the battery? I have similar model, not quite sure it's the 3765, but rounded bottom, PCMCIA in back. It's acting dead though, even with external power hooked up, hopeful for battery replacement or do you think it will need more?
