16mb disk space issue with 64gb SD-card
Reply 20 of 23, by wierd_w
I've also used DDOs with the sintechi adapters.
what they dont do well, (or at all...) is 48bit LBA.
Reply 21 of 23, by douglar
wierd_w wrote on 2024-06-05, 12:41:
I found some additional info about that. This guy looked at the supported ata feature list using HD Tune Pro 5.5:
https://goughlui.com/2019/02/03/tested-generi … dapter-sd35vc0/
Testing with the 32GB Toshiba Exceria card installed reveals that the drive advertises only the SMART feature with no other capabilities. Note the lack of 48-bit address capability which could be a problem with cards larger than 128GB. As I don’t have any of these cards on hand, I couldn’t confirm if 48-bit LBA is supported. TRIM is also not supported, although as far as I’m aware, only some eMMC devices are able to utilise this. The converter advertises UDMA5 (100MB/s) capability and indeed has linked at the promised rate via an 80-conductor IDE cable. It does claim an 8KB buffer … very small, perhaps implemented in internal RAM?
Reply 22 of 23, by kixs
Ribbicipp wrote on 2024-06-03, 17:25:
Ribbicipp wrote on 2024-06-03, 16:55:
dominusprog wrote on 2024-06-03, 16:36:
64GiB is too large, use a 32GiB card instead.
why is 64gb an issue vs 32gb?
just tried with a 32gb card and it's the exact same issue.
Remember when Pentium was still current the hard drive sizes were up to 8-10GB. Any larger weren't supported. I'd recommend some other EIDE controler like Promise Ultra PCI series.
