Reply 20 of 22, by mockingbird
Gmlb256 wrote on 2025-01-01, 04:18:As for general DOS slowdown options, there is an obscure one that can be achieved with CM utility to set the CPU cache control to write-through. The disadvantage is that it only works in real mode or if JEMM is used in situations where EMS is needed.
or get a Nehemiah like you... What are you doing to get yours to run at 1.46ghz? Don't tell me you're running the FSB in the 160s on your P2-99, or are you playing with the multipliers in autoexec.bat on boot? I'm just finishing up my Nehemiah build and plan to underclock it to 900mhz (9 x 100) which is about the same as a PII 400.
