HELP 3COM 3C905B-TX
Reply 20 of 37, by Grzyb
kjt418 wrote on 2025-02-13, 17:38:
DEVICEHIGH=C:\DOS\UM386.EXE RAM I=B000-BF77
That's not a part of DOS.
In general, it's a good idea to keep the setup as simple as possible, and avoid any foreign bodies.
Nie rzucim ziemi, skąd nasz root!
Reply 21 of 37, by kjt418
Grzyb wrote on 2025-02-13, 17:54:
Ah! it appears I fat fingered something when I was typing I meant to emm386.exe
Reply 22 of 37, by Grzyb
Try without EMM386.EXE - it switches the CPU into V86 mode, which may interfere with something.
Also, are you sure about that hardware?
Have you tried 98SE, or XP? Are they stable?
Reply 23 of 37, by kjt418
Grzyb wrote on 2025-02-13, 18:10:
So, I work for a company that is still using DOS 6.22. We have 2 machines. One in prod and this one that "supposedly" used to work but it's been in a closet for over 6 years
Unfortunately, upgrading isn't possible as the software only runs on DOS 6.22 (apparently windows 3.11 was tried and it failed)
Reply 24 of 37, by wierd_w
Legacy systems!
*WHAT FUN!*
Reply 25 of 37, by kjt418
BloodyCactus wrote on 2025-02-13, 16:43:
do you have it in your config.sys to initiliase the pci card when your in dos mode? if you dont, it wont work properly. […]
in mine i have
lh device=c:\3c905c\3c90xcfg.exe configure /configfile=c:\3c905c\3c905x.set
the .set file, you have to run 3c90xcfg and select your options and save them as configuration file.
then you can call 3c90xpd /i=60 in autoexec.bat
OK, in addition to the changes from @grzyb I now have DHCP working and can get an IP!!!!
YAY!!!!
Reply 26 of 37, by kjt418
wierd_w wrote on 2025-02-13, 18:57:
Legacy systems!
*WHAT FUN!*
oh, the best part is trying to figure out how to configure Ubuntu 22 to accept an SSH connection!
I'm not even the IT Guy, I'm just a contract Android Developer that they asked if I could fix this 😅
Reply 27 of 37, by kjt418
WELL....JUST KIDDING Y'ALL
SO, I rebooted, DHCP succeeded. I got an IP address. I rebooted again and now I'm getting DHCP failures. Same WATTCP.CFG with no changes
Reply 29 of 37, by wierd_w
As a stopgap, the next time you get an IP, write down the number, your netmask, and default gateway.
Then, set a static IP toward the bottom of the range.
Reply 30 of 37, by dionb
wierd_w wrote on 2025-02-13, 19:24:
If this is the same issue I had, that won't help. It's not DHCP that's the problem, the system hangs whenever anything tries to use the NIC. You just tend to notice it first with DHCP if you set it to do that at boot. Anything else will also hang.
Reply 31 of 37, by BloodyCactus
I would also say, set the nic to HALF DUPLEX instead of full duplex. I had same issue with my 3com. fullduplex would cause issues, half duplex would be fine.
Reply 32 of 37, by kjt418
dionb wrote on 2025-02-13, 19:37:
Hey DionB this is what I'm noticing. TCPINFO.EXE will work ONCE. Then everything tends to stop working. Same with PING. I can certainly try mTCP however, SSH2DOS requires Waterloo TCP
Reply 33 of 37, by kjt418
BloodyCactus wrote on 2025-02-13, 19:40:
I completely forgot to upload the .SET file that 3c90xcfg.exe created
; NIC Setup file for a 3C90X NIC.
; Created 02/13/25, 11:04:51.
@Boot PROM: enabled
@Media type: 100BASE-TX
@Network driver optimization: Network
@Link beat: enabled
@Full Duplex: disabled
Reply 34 of 37, by Grzyb
It's been ages since I last used WatTCP...
From what I recall, there were some issues, and replacing it with mTCP was a nice improvement.
Perhaps it would be a good idea to port SSH to the mTCP library?
Can't help with bad hardware/drivers, but there may be other problems as well...
Anyway, the current SSH2DOS seems to work for me - using 486DX2-66 + 3C509B-Combo.
Reply 35 of 37, by Rwolf
Does it work if you pull the cable and reinsert it again; e.g. force a re-negotiating for the link.
(I had some Tulip based NIC:s which were incorrectly designed with (internal) both 'smart' eth chip + 'smart' phy chip that failed at bootup, but could work if reconnected like this. Both chips did negotiation independently and one got half duplex while the other got full duplex = failed link.)
Reply 36 of 37, by Deunan
kjt418 wrote on 2025-02-13, 19:44:
Did you try disabling the boot ROM (unless you need it) and maybe enabling full duplex? This PC might be old but my guess would be the rest of the network was, at some point, updated to modern 100Mb/s switches (or better)?
On the other hand if the network is old and there are still 10Mb/s hubs around you might need some workaround for that. If the card can't be forced into 10Mb operation then perhaps adding another switch between that PC and the rest of the network might help. I had a case like that though not with a 3Com card.
Reply 37 of 37, by kjt418
Hey Everyone! I'm sorry I went MIA - I got pulled back onto my "REAL" job at the company (gotta admit being an android app developer isn't as fun as fixing 27 year old DOS computers 😂)
But, I wanted to thank everyone for the amazing help! The machine is actually working consistently now...with caveats
Like, I have to run MTCP\DHCP.EXE every time I want to SCP files up to the Linux server. The new SSH2DOS 2021 version doesn't work, I am having to use the SSH2DOS 2006 version
I am unable to use ID_DSA key file for passwordless authentication, this command causes the DOS Box to literally hang
scp2d386.exe -i ID_DSA -g -r C:\DATA_UP use@192.168.1.2:
