HELP 3COM 3C905B-TX
First post, by kjt418
OS: DOS 6.22
CPU: Pentium 3 700MHz
RAM: 128MB
HDD: 2GB
NIC: 3COM 3C905B-TX
I downloaded the v4.01b drivers from @Grzyb from a post by @Joseph_Joestar. I only need the Packet Drivers as this machine will SSH into a Linux Server. I copied `3c90xpd.com` to the _C:\DOS_ directory
However, when I add this line to my autoexec.bat
loadhigh c:\dos\3c90xpd.com /I=0x60`
(I also tried 0x70 since the README said the default was 70h)
to my auto exec.bat DOS 6.22 hangs with the message
"Attempting to auto detect media..."
Things I've done:
Sort of at a loss and any help would be appreciated.
Reply 1 of 37, by DaveDDS
kjt418 wrote on 2025-02-12, 14:01:
Do you have the network/cable connected?
I don't know specifically about the 5C905 and it's drivers, but I've
got a couple network cards where the packet driver hangs if the
network is not connected to an actual network so it can figure out
the type of connection!
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 2 of 37, by kjt418
@DaveDDS Thanks for the reply! Yes I do have a cable connected to an active ethernet drop. (I tested it out by plugging the same cable into my laptop and I'm able to get a valid IP address)
My first thought was maybe I need to have some DHCP configured in some CFG file?
Reply 3 of 37, by Grzyb
Can you run 3C90XCFG.EXE and set media type to something other than "auto"?
Anyway, it's a well-known fact that packet drivers for 3Com NICs often turn out to be buggy.
It may be a good idea to try the ODI driver + ODIPKT.COM instead.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 4 of 37, by Rwolf
Did the NIC pass the diagnostics tests? (e.g. Etherdisk 3c90xcfg.exe tests described in the manual? A loopback connector/cable may be needed.)
https://docs.rs-online.com/e9e4/0900766b8002c838.pdf
https://archive.org/details/3cometherdiskxl
There could also be issues with using old busmastering chipsets on the motherboard according to some postings I saw?
(e.g. PIO fallback not available on the B and above models of the NIC). But it's unclear if that would affect initialization.
Reply 5 of 37, by kjt418
@Rwolf. Thanks for the reply, I think the diagnostic tests passed...I ran 3c90xcfg.exe and I got this...
Reply 6 of 37, by kjt418
@Grzyb I believe that solved my issue! Thank you
Reply 7 of 37, by Grzyb
BTW: is it still possible to connect to modern Linux from DOS via SSH?
What's the recommended client?
Reply 8 of 37, by kjt418
@Grzby I'm using SSH2DOS from this repo
Then, on the Linux server I need to make the following changes to the /etc/ssh/sshd_config
#add kex
KexAlgorithms diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
#add new allowed algo
HostKeyAlgorithms=ssh-rsa,ssh-rsa-cert-v01@openssh.com
# add accepted algo
PubkeyAcceptedAlgorithms=+ssh-rsa,ssh-rsa-cert-v01@openssh.com
Reply 9 of 37, by dionb
The 3C90x packet driver bugs drive me round the bend sometimes. Was recently trying to get a 3X905CX-TX-M working in a DOS system. It worked. Once. Then after reboot without changing hardware or software it stopped, still loading the 3C90XPD.COM packet driver without issues but hanging as soon as you tired to use it. Same as here, just not from that version of the CD. Tried a few different versions, got frustrated. Gave up.
So beware, even if it works now, it might not tomorrow...
Reason I spent so long on it was that it was a low profile system and it was the only NIC (theoretically) supported in DOS I had with low profile bracket. Instead I got out my wirecutters and went to work on an SMC 8416. Not pretty, but it fits and equally importantly it runs reliably. Did hit a memory conflict first, but at least its packet driver was so kind as to tell me what the problem was so I could fix it
Reply 10 of 37, by Deunan
The PCI 90x series DOS drivers are like a minefield. Older ones will work with 900 but not 905. In fact even 900 and 900B are different enough to cause problems. Newer drivers on the other hand will work with 905 series, might even be required to detect 905C, but will hang or refuse to actually send anything on the wire with older cards like 900 series. If a particular packet driver works well I'd say stick with it and don't try any "updates". It might also help to set the card manually to a particular media (TP or BNC, or AUI) but I've also found the DOS driver might ignore that and try to auto-detect anyway, get it wrong and thus make the network unreachable.
Curiously I've never had any issues (so far anyway) with 3Com ISA cards. Or when using Win9x. Linux too but obviously it's no longer their code in there. Didn't really do much testing on Win3.x and PCI systems to get a good idea how that works.
Reply 11 of 37, by Grzyb
kjt418 wrote on 2025-02-12, 17:49:
Ah, so it's possible, but requires non-standard configuration on the server side.
Well, we all know that modern encryption may be too hard for old computers...
Reply 12 of 37, by wierd_w
Grzyb wrote on 2025-02-13, 02:08:
Not really. The Linux Foundation and pals removed default support for RSA encryption methods after the whole "RSA purposefully recommended a weakened set of parameters, so that they could penetrate it themselves" fiasco about 6 years ago.
Similar with discontinuation of default support for Diffie-Helman and pals, which are just technologically weak (and can be broken with modest effort, and are thus no longer considered secure)
the DOS SSH client is ... Old...
As such, it wants to use OLD cyphers. You just have to turn those cypher sets back on, because they have been turned off by default, because INSECURE. 😜
"nonstandard" is loaded. Those WERE standard cypher types. They are just OBSOLETE standard cypher sets.
Reply 13 of 37, by Grzyb
OK, thanks for the explanation.
But aren't the current cypher sets more CPU-demanding than the obsolete ones?
I was convinced that there's certain minimum CPU power required to use modern cryptography - because below that minimum, the handshake takes so long, that it triggers a timeout somewhere.
Reply 14 of 37, by kjt418
dionb wrote on 2025-02-12, 19:16:
Well, it's tomorrow and guess what...IT NOT WORKING :-p
What the actual heck is going on?!
Reply 15 of 37, by kjt418
@wierd_w the DOS SSH client I'm using is from 2021 - it was updated to support "newer" standards
diffie-hellman-group1-sha1 -> diffie-hellman-group14-sha256
aes128-cbc -> aes128-ctr
hmac-sha1 -> hmac-sha2-256
Reply 16 of 37, by BloodyCactus
do you have it in your config.sys to initiliase the pci card when your in dos mode? if you dont, it wont work properly.
in mine i have
lh device=c:\3c905c\3c90xcfg.exe configure /configfile=c:\3c905c\3c905x.set
the .set file, you have to run 3c90xcfg and select your options and save them as configuration file.
then you can call 3c90xpd /i=60 in autoexec.bat
Reply 17 of 37, by Grzyb
If all PD versions are so capricious, it may be a good idea to try something completely different: ODI driver + ODIPKT.COM, or NDIS driver + the appropriate shim.
Reply 18 of 37, by kjt418
OK, well, I added that to the config and still nothing... I'll post my files here to see if I've just done something stupid...
:: AUTOEXEC.BAT DOS 6.22
SET WATTCP.CFG=C:\APPS
C:DOS\3C90XPD.COM /I=60
::CONFIG.SYS DOS 6.22
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICEHIGH=C:\DOS\UM386.EXE RAM I=B000-BF77
DOS=HIGH,UMB
LOADHIGH DEVICE=C:\3COM\3C90XCFG.EXE CONFIGURE /CONFIGFILE=C:\3COM\3C90X.SET
# WATTCP.CFG
hostname = "backup"
my_ip = dhcp
Microsoft Network Client 3.0 for MS-DOS
I tried installing this, pointing the install to the drivers (C:\3COM\NDIS2\DOS and
  • Setting Basic Directory
  • Changed the Network Configuration to TCP/IP and removed IPX
However, on reboot the system got hung on "NetBind v2.1"
Reply 19 of 37, by kjt418
Grzyb wrote on 2025-02-13, 17:30:
I just tried the NDIS2 drivers - but, the system got in a hung state executing "netbind.com" command
