Reply 20 of 24, by Paddan1000
- Member
esher wrote on 2025-03-25, 07:15:I've totally recapped my MT-32 too two years ago, and i must say all of the capacitors excepts two 1000uF in the power filter ne […]
I've totally recapped my MT-32 too two years ago, and i must say all of the capacitors excepts two 1000uF in the power filter near 7805 were good. These two was about 60-70% of capacitance.
But, anyway, i've changed them all.Check for shorts after DAC and demuxer, analog audio circuit is not that big.
EDIT: ah, the problem was solved already. Good.
I've tested the four 1000 uF 16V caps that I desoldered from my board and they all were within spec at 969-978 uF and ESR 0,21-0,28.
