Reply 20 of 33, by Ozzuneoj
- l33t
The Serpent Rider wrote on Yesterday, 18:47:RDNA2 was premiered in October 2020. Marketing refreshes with zero changes to the silicon don't really count. That's how it alwa […]
Ozzuneoj wrote on Yesterday, 18:29:Compare that to RDNA 2... […]
Radeon RX 6950 XT = May 10, 2022 for $1,099 USD
Radeon RX 6750 XT = May 10, 2022 for $549 USD
Radeon RX 6750 GRE = Oct 18, 2023 for $269 - $289 USD
Radeon RX 6650 XT = May 10, 2022 for $399 USDRDNA2 was premiered in October 2020. Marketing refreshes with zero changes to the silicon don't really count. That's how it always was for both Nvidia and AMD.
GCN 1-3 were supported for 8-11 years, and GCN 4 was getting normal driver support until 2023
GCN 1.0 through 3.0 support is peculiar, because they were made on the same lithography (28nm) and had a lot of minor architecture tweaks. One of the reasons why GCN 1.0 was held alive for so long and why they all were dropped simultaneously. As for immortal Polaris, it held for so long due to the mining GPU craze.
I don't think that really changes anything I said... and believe it or not, one person's opinion on a forum doesn't determine what "counts" for all of AMD's customers. Go look at what their former\potential customers and the tech media are saying about this. Also, check the steam hardware survey:
https://store.steampowered.com/hwsurvey/Steam … elcome-to-Steam
Before the announcement, how many AMD GPUs out of the roughly 100 listed here were getting full driver support? Only 18 (out of 29 total from AMD... mostly older IGPs) ... And how many will be getting full driver support now? Err... 5. And one of those is an IGP. And none of them are RX 9000 series. Basically, everyone in the hardware survey is using an AMD GPU based on an architecture from 2022 (if that's what we should be going by) or older. AMD is telling all of these people that their days of getting performance improvements are numbered, despite the "AMD fine wine" meme that has helped them stay relevant for the past 15 years.
Even if we assume that people are okay with their 2020 GPUs being put on the back burner, for AMD to stop providing full driver support for a $400 GPU from May of 2022, let alone ones for $550 and $1100, is a ludicrously bad move for a company in their position. They are barely a blip on the radar in the professional\business areas where Nvidia is dominating, so giving home users more reasons to avoid them for their next upgrade is beyond bone-headed.
EDIT: I should add... if they really needed to focus on the current generation (which they should), they should simply do that without making some huge announcement about not wanting to continue improving the GPUs that most of their customers are still using. It sounds like in the follow up posted earlier they have "re-worded" things a bit and are suggesting they might roll out performance improvements as the market requires. Right. 🤣. Okay, well, if they'd worded it that way from the beginning and actually intend to do that, then absolutely no one would care. These companies just do really dumb things sometimes.
