Reply 20 of 65, by DustyShinigami
- l33t
NeoG_ wrote on 2026-01-14, 22:44:Well I suppose you can force the sb16 emulation to the right settings... You will need to edit ctsyn.ini but windows will overwrite the file on every boot with the settings used in windows. What I would do is create a copy of ctsyn.ini in the game directory with the updated settings and to do a SET CTSYN=D:\DOS\MONKEY1 in the game batch file before running the SB live initializer so it uses that file instead
Okay, thanks. I'll give that a try and see. I've also read about changing the mouse from my serial/USB to my old serial mouse. And setting CuteMouse with the 3 and W switches.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
