Monkey Island Ultimate Talkie Audio Conflict
First post, by DustyShinigami
Yesterday I learnt about the Ultimate Talkie edition of Monkey Island for the first time. I wanted to see if I could get General MIDI working with the CD-ROM version and I stumbled on it thanks to a thread here. Everything's been set up correctly using my Special Editions on Steam. Both games have been sorted and added to my retro PC. However, the first time I loaded SOMI up, the intro worked and so did the General MIDI. However, as soon as Guybrush talks to the lookout, the game just froze. Had to reset the PC. Further investigating on here revealed that you need to check the executable's switches and configure the Sound Blaster. Unfortunately, doing that resulted in every line of dialogue getting cut after one word is spoken. Since then I've been experimenting and getting no where. 🙁 I've tried changing the resources for the game, which has still led to the dialogue getting cut, the PC freezing, or the PC rebooting itself.
However, when I configured my Sound Blaster/SB16 Emulation, the speech worked! Albeit, very quiet. So it's my ISA Yamaha that's the problem, which is my primary sound card.
I can only surmise that there's a resource conflict somewhere...? I'm just having problems sorting it out. In Windows, my Yamaha is assigned A220, I5, D1/5. The Yamaha is initialised first in DOS through Unisound and all the correct resources are assigned - A220, I5, D1/5, P330. However, when I check the resources of the SB16, which are assigned A220, I7, D3 in Windows, the same resources are applied as the Yamaha. Before and after initialising it. I've checked through the readme and followed it to the best of my knowledge, but no matter what I set it to, it asks me to reset the PC, and the configurations are exactly the same! No change.
This is the entire readme:
/* ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ» º Resource Configuration […]
º Resource Configuration Program º
º for º
º Sound Blaster 16 Emulation º
º (Version 1.01) º
º º
º Document Revision/Date : 0.05/09 September 1998 º
ÈÍÍÍÍ Copyright 1998.(c) Creative Technology Ltd. All Rights Reserved. ÍÍÍͼ
*/ Some program usage information on SBESET.exe.
1. Objective
SBESET.exe is a dos program that can only be executed in Pure Dos Mode/
Shutdown to Dos Mode. Hereinafter, the term Dos Mode is used to indicate
Pure Dos Mode & Shutdown to Dos Mode. The purpose of this SBESET.exe
program is to enable the user to have the flexibility of resolving SBE
resource configurations conflict under Dos Mode. This simple dos program
allows user, with the help of switches mentioned in the following section,
to manually reconfigure SBE resources to the one that user knows that it is
non-conflicting.
2. Program Description and Usage
SBESET.exe is a simple dos program, that improves the flexibility of SBE on
Dos Mode. It gives the user the ability to manually reconfigure SBE resources
or disable SBE. With the help of these switches mentioned below, user will be
able to reconfigure the SBE resources,
for example, sbeset -A240 -I5 -D3.
The switch command "-A240" indicates changing the SBE base address, with
switch option "-A" indicates changing of Sound Blaster base address, with
the new resource/value "240" follows.
The switch command "-I5" indicates changing the Sound Blaster Interrupt
resources, with switch option "-I" indicates changing Interrupt and the
new resource/value "5" follows.
The switch command "-D3" indicates changing the Sound Blaster Low DMA
resources, with switch option "-D" indicates changing the Sound Blaster
Low DMA and the new resource/value "3" follows.
Usage syntax:
sbeset -[switch option][value] -[switch option][value] ...
switch command descriptions:
-A[value] : (optional)
This switch command indicates a change in SBE's base address.
The switch option "-A" indicates the base address option, with
the "value" indicating the various possible Sound Blaster base
address port, for example, 220, 240, 260, and 280 to be used.
These values are all hexidecimal.
-I[value] : (optional)
This switch command indicates a change in the SBE's Interrupt
resource. The switch option "-I" indicates the Interrupt option,
with "value" indicating the possible Sound Blaster interrupts,
for example, 5, 7, 9 and 10 to be used. These values are all in
decimal.
-D[value] : (optional)
This switch command indicates a change in the SBE's Low DMA
resource. The switch option "-D" indicates Low DMA option,
with "value" indicating the possible Sound Blaster Low DMA,
for example, 0, 1, and 3 to be used. These values are all in
decimal.
-H[value] : (optional)
This switch command indicates a change in SBE's High DMA
resource. The switch option "-H" indicates High DMA option,
with "value" indicating the possible Sound Blaster High DMA,
for example, 5, 6 and 7 or current Low DMA resource to be
used. These values are all in decimal.
-P[value] : (optional)
This switch commmand indicates a change in the SBE's MPU base
port address. The switch option "-P" indicates the MPU base
option, with "value" indicating the possible Sound Blaster
MPU base port address, for example, 300 and 330 to be used.
These values are all in hexidecimal.
-J[value] : (optional)
This switch command indicates a change in the SBE's Joy base
port address. The switch option "-J" indicates the Joy base
option, with "value" indicating possible Joy base addresses,
for example, 200, 208, 210, 218, ..., 800, ... . These values
-j[value] : (optional)
This switch command indicates disabling or re-enabling of SBE
Joy Port. When value is "1" will be re-enabled. When value
"0", SBE will be disabled. Any other values are invalid.
-d[value] : (optional)
This switch command indicates disabling or re-enabling of SBE.
When value is "1", SBE will be disabled. When value is "0",
SBE will be re-enabled. Any other values are invalid.
-w[value] : (optional)
This switch command indicates enabling the use of window
assigned resource configurations or user assigned resource
configurations. When value is "1", SBE willuse back intial
window assigned resource configurations. When value is
"0", SBE will use user assigned resource configurations.
-c : (optional)
This switch command display the current SBE resource
configurations.
-? : (optional)
This switch command indicates launching of help option
listing.
Note :
(i) All switch options are case sensitive.
(ii) Omitted switch options will adopt the previously assigned
values either by windows or user itself.
(iii) A reboot process is required for the new configurations to
take effect.
(iv) All switch commands are optional but when a switch option is
selected, a valid value is expected to follow next. If this
is not so, an invalid message will be prompted.
(v) Spacing is not allowed between a switch option and its value.
An invalid message will be prompt if this is not comply.
(vi) Spacing is essential between two switch commands.
3. Related Programs Notes
Note that SBESET.exe program will only work with the undermentioned
release of SBE Dos Drivers or later. Any attempt to run SBESET.exe
with the earlier release of the SBE Dos Drivers will result in unexpected
results.
SBE
Related Dos Drivers File Size Date
SBECFG.EXE v1.01 27,802 31 August 1998
SBEINIT.COM v2.60 4,427 31 August 1998
4. FAQ
a. After changing the resource configuration using SBESET.exe can I type
"Exit" at Dos Mode to go back to windows and than shutdown to Dos Mode
again for the changed resources to take effect ?
Ans: No, for changes to take effect, a cold reboot is currently necessary.
b. After changing the resource configurations using SBESET.exe, I realised
that the SB Emulation resources under Device Manager does not reflect
changes ?
Ans: Yes, that is correct. The resource configurations for Dos Mode is
independent of the resource configurations mentioned in SB Emulation
under Windows Device Manager. SBESET.exe will maintain its own set
of resource configurations separate from that of Windows.
c. Where did SBESET.exe get its other resource configurations(e.g.
Interrupt, Low DMA, ... etc.) when I only first changed the Sound
Blaster base address ?
Ans: When SBESET.exe is run for the first time, it will duplicate a set of
the Windows resources currently assigned for SB Emulation as it
default values. Any further changes using SBESET.exe will be based on
the initial set of resources.
d. How do I use back my windows assigned resource configurations in Dos
Mode ?
Ans: With SBESET.exe, there is a switch option "-w". By executing SBESET.exe
with the command option "-w1" will reconfigure SB Emulation in Dos
Mode to use back windows assigned resources on the next reboot.
So unless I've overlooked something, to my understanding, I'm supposed to put something like: SBESET -A220 -I7 -D3 -H5 -P330...? And needs to be in capitals. But as I say, nothing changes. I've even checked SBEGO.EXE and the manager still lists the same resources assigned as the Yamaha.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 65, by NeoG_
Monkey island DOS only works with DMA1, and if you use an IRQ other than 7 it needs to be specified at runtime on the command line. The Yamaha card will work if you run "monkey.exe r1 s220/5/8"
Reply 2 of 65, by DustyShinigami
NeoG_ wrote on 2026-01-14, 01:36:
Yeah, I read it needs to be DMA 1. That last part confuses me, which the switches list as 'k buf size'...? Is that supposed to be set to 8 then? Thanks.
EDIT: Sadly, setting it to 8 didn't work. Before the speech gets chance to play, the game crashes with a black screen and a hyphen.
OS: Windows 98 SE
Reply 3 of 65, by NeoG_
DustyShinigami wrote on 2026-01-14, 01:40:
Audio buffer size in kilobytes, 8 is the standard value
can you show the output of unisound
Reply 4 of 65, by DustyShinigami
NeoG_ wrote on 2026-01-14, 01:52:
Audio buffer size in kilobytes, 8 is the standard value […]
Ahh, I see. Does that apply to any resource? So 1, 3, 5 etc?
The attachment IMG_5228[1].JPG is no longer available
OS: Windows 98 SE
Reply 5 of 65, by NeoG_
DustyShinigami wrote on 2026-01-14, 02:22:
Yes it's independent of any other value
Can you do a SET BLASTER=A220 I7 D1 P330 T4 just before unisound is executed in the batch file and see what happens
edit: sorry and also change the monkey line to "monkey.exe r1 s220/7/8"
Reply 6 of 65, by DustyShinigami
NeoG_ wrote on 2026-01-14, 02:45:
Yes it's independent of any other value […]
Done. I mean, my autoexec.bat automatically has the BLASTER variable set wrong, which I can't seem to stop. I don't suppose there is a full-proof way of preventing Windows from putting it in there? Even if I manually change it and set it to read-only, it keeps changing it back after booting into Windows and restarting. It's set it to A220, I7, D3 and skips P330 altogether for some reason.
But sadly, even putting it into the custom BAT as you've suggested, the game crashes whenever I look at Elaine Marley's poster. I've tried it with A220, I7, D1, P330, T4 and with A220, I5, D1, P330, T4. And with monkey.exe using the switches m r a220/7/8 and m r a220/5/8. In my case it's r for General MIDI as I don't have an MT-32. Yet. 😀
OS: Windows 98 SE
Reply 7 of 65, by DustyShinigami
Decided to take my SB out, made a slight adjustment to the resources in Windows for my Yamaha (basically made sure DMA was set to 1 and 3), and when I checked in autoexec.bat, the configuration was correct! A220 I5 D1 P330 etc. Unfortunately, the game still crashes. Even with the Yamaha being the only card installed and configured and the resources set correctly. 🙁
OS: Windows 98 SE
Reply 8 of 65, by DustyShinigami
Hmm. I've noticed some have reported the mouse drivers are a cause of crashing similar to mine. Doesn't make a lot of sense though as the speech was working when I set up the SB card. And that was with CuteMouse. I'll give a suggested driver a try later and see what happens.
OS: Windows 98 SE
Reply 9 of 65, by DustyShinigami
Nope. Even with CuteMouse 2.04a, it freezes. I even went so far as to remove the SB card, uninstall all its drivers so only the Yamaha is present and set up, but no. Still crashes. 🙁
OS: Windows 98 SE
Reply 10 of 65, by keropi
maybe some file is corrupted?
here is a shot of my game, maybe some CRC32 is different?
The attachment mi1se.png is no longer available
Reply 11 of 65, by DustyShinigami
keropi wrote on 2026-01-14, 17:35:
How do you get/find the CRC32 codes to show? I can't see it in the list of columns. Also, many of the filesizes are somewhat different compared to mine. Not sure if I'm using a version of the builder that reduces/optimises the files...?
The attachment explorer_97x00jklE8.png is no longer available
Also, it still doesn't explain why I was getting speech without issue when I enabled my SB card. Just makes no sense why they don't with the Yamaha.
OS: Windows 98 SE
Reply 12 of 65, by DustyShinigami
Just tried the first game under 86Box. Same files. Same setup. Works perfectly.
OS: Windows 98 SE
Reply 13 of 65, by keropi
My shot was from winrar, opening the zip archive of the game
It was just a thought to check crc just in case
Reply 14 of 65, by DustyShinigami
keropi wrote on 2026-01-14, 19:04:
Okay. I'll have to try WinRAR with it and see. Thanks.
Just tried the second game with 86Box and it starts off well, but then can randomly freeze up either during dialogue or the opening credits.
OS: Windows 98 SE
Reply 15 of 65, by DustyShinigami
Yeah, it looks about the same from what I can see.
The attachment WinRAR_uHZm8OHSzm.png is no longer available
OS: Windows 98 SE
Reply 16 of 65, by DustyShinigami
Also tried CuteMouse 1.9. Same issue.
OS: Windows 98 SE
Reply 17 of 65, by NeoG_
DustyShinigami wrote on 2026-01-14, 11:38:
Is this a typo? it's supposed to be s220/5/8 not a220/5/8
Reply 18 of 65, by DustyShinigami
NeoG_ wrote on 2026-01-14, 22:18:
It's a typo, yeah. Sorry. >_<
OS: Windows 98 SE
Reply 19 of 65, by NeoG_
Well I suppose you can force the sb16 emulation to the right settings... You will need to edit ctsyn.ini but windows will overwrite the file on every boot with the settings used in windows. What I would do is create a copy of ctsyn.ini in the game directory with the updated settings and to do a SET CTSYN=D:\DOS\MONKEY1 in the game batch file before running the SB live initializer so it uses that file instead
