Gigabyte GA-5AX AGP Voltage Mod
Reply 20 of 23, by TELVM
shevalier wrote on Today, 11:24:
Near the RAM slots, there is an unpopulated footprint for an electrolytic capacitor. If it's on the +3.3V rail, I would try runn […]
If it's on the +3.3V rail, I would try running a jumper wire to it.
That way the run will be much shorter, and you can use a thinner wire.
Plus, it will look much cleaner.
But again, I don't have this board.
I don't know where this pad goes.
This needs to be checked with a multimeter.
Shevalier if you mean this one:
file.php?mode=view&id=247049
^ It's a CPU VRM output spot that they just left unpopulated (like the one to its extreme left in this pic, that I've circled in blue). They both are in parallel with the six that came OEM populared.
file.php?mode=view&id=247050
Let the air flow!
Reply 21 of 23, by TELVM
zami555 wrote on Today, 11:32:
TELVM wrote on 2026-08-01, 08:44:
^ I bet that "brilliant" idea came from the same "genius" that made the "exquisite" selection of capacitors. 👎
I bet the decision was made by management and financial departments of Gigabyte. Engineers usually try to do their best with designing something... And then others come in and decide. It's just a few words from me to support the engineer who worked on this design 😉
^ You're completely right, the penny-pinching is always imposed by the bean-counters at the top.
I'm sure back in the day Gigabyte engineers could, and wanted to, do miles better.
BTW, if anything I'm a Gigabyte fan 😀 . I'm writing this from a X570 Aorus Master, and also own several other Gigabyte boards and GPUs. 👍
Let the air flow!
Reply 22 of 23, by shevalier
TELVM wrote on Today, 11:47:
Shevalier if you mean this one: […]
And the next two near the chipset?
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 23 of 23, by TELVM
shevalier wrote on Today, 12:21:
They're in parallel with each other and connect to pins in all three memory slots. They both are also in parallel with the two caps right north from the LX8383 (which I believe feeds ~3.3V juice to all of them):
file.php?mode=view&id=247054
Let the air flow!
