Reply 20 of 27, by Chkcpu
- Oldbie
amadeus777999 wrote on 2026-11-04, 11:04:Dos 7.1 as in W9x. If I get the board at the end of the month I'll post an update and run the legacy exe of your info utility on […]
red-ray wrote on 2026-11-04, 09:36:amadeus777999 wrote on 2026-11-04, 08:55:The link concerning the board is https://www.kleinanzeigen.de/s-anzeige/asus-p … 628356-225-6330
I think the little tag reads "OR"...?Good luck, a save from a SiS 496 OR would be good, AFAIK I don't have one. Which OSes do you plan to install? I have W2K + NT4 + 98SE my Intel DX4-WT (P24C) 120MHz @ SK096 (I have a selection of CPUs)
Dos 7.1 as in W9x.
If I get the board at the end of the month I'll post an update and run the legacy exe of your info utility on it.
I have a book by Hans-PeterMessmer describing pc hardware... maybe there's some hints regarding a "PCI configuration dump".
You guys are making me feel old! 😉
Don’t you have the PCI bus sniffer in your DOS tools collection?
After this tool has scanned the PCI bus, you hit the F2-key to write a full configuration space dump of all PCI devices to disk.
Enjoy, Jan
