Mounting Rayman CD image with DOSBox
Reply 20 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
I suggested the -c option as all your options were added to the commandline of dosbox
(the -c mount and the rayman.bat)
Water flows down the stream
Reply 21 of 23, by RaymanForever2007
Ah, I got you;
dosbox c:\Rayman1\Rayman.bat -exit -fullscreen -c "CYCLES=9000" -c "MOUNT D Q:\ -t cdrom -usecd 0 -ioctl
Thanks again, but I wonder that you missed "=" mark in the command you recommended. Please post your idea specifically.
Reply 22 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
because the = is optionally ?
Reply 23 of 23, by RaymanForever2007
Yes, you are correct.
"=" mark in optional in the command line.
Ok, it worked !! Thanks for your kindness.
All my issues on Rayman are now solved.
