First post, by ChaosFish
- Member
This isn't such an important question as I have the original disc, and it also works with Daemon Tools, but when I try to make an image of my Rayman CD (bin/cue) I can't mount it properly with DOSBox.
Mounting the CD works when I set "-t cdrom -label RAYMAN -ioctl", but when I try to imgmount it with DOSBox (afaik you don't need to supply additional tags like label and ioctl while doing this, although I also tried that) and launch the game it just says something like "Please insert original Rayman CD".
Any ideas?
Again, I'm only posting this because I think it might be a bug in DOSBox.
