Nine Lives CD Extra won't work in XP or DOSBox
Reply 20 of 23, by MiniMax
Rank Moderator
Moderator
It should be in same directory you were in when you gave the command.
Do the Start => Run... => CMD.EXE thing, and type dir list.txt
The output from dir should tell you the name of the directory.
You can even do a start . from the CMD prompt to start a normal Explorer window 😀
Your My Documents folder perhaps?
_________________
Reply 21 of 23, by sarahsmith99
ah ha.. found it 😀
Moderator edit: Converted the long list to a file attachment.
Reply 22 of 23, by MiniMax
Rank Moderator
Moderator
Doesn't look like a DOS game to me 🙁
Anything interesting in that E:\README.TXT file?
_________________
Reply 23 of 23, by wd
Rank DOSBox Author
DOSBox Author
As far as i understood this extra-stuff on the CD works on win95, but
not on XP (maybe that can be extracted from the readme).
If it works under win31 as well you could install win31 in dosbox (if you
got a copy+license of it).
If you have win95 (maybe win98/me would work, too) you can try some
virtualizer like virtualpc, virtualbox, vmware etc. and install win9x there,
then trying to access the extra stuff on the cdrom.
