3DBENCH CPU Benchmark Database
Reply 20 of 296, by Mau1wurf1977
aitotat wrote:
The VLB Graphics Card I used for testing has 2 (not 3) MiB RAM (386 table lines 3, 9 and 11). Only the ISA card has 3 MiB.
Can you make background color a bit darker for every other line? It would make the tables more readable.
Will fix the memory line...
Yes I could do the lines thing. Don't see why not!
Reply 21 of 296, by Tetrium
Shouldn't K6-2 be with the Pentium? It's still socket 7 (not slot 1) and I feel the architecture of super 7 is still much more similar to older socket 7 then to any slot 1
Reply 24 of 296, by leileilol
No 160MHz Am5x86 results? Shocking.
Also, setting the RAM wait states to 0 really REALLY helps Am5x86 performance at the risk of locking up on sysreset so try that too. It's amazing for the speed you can really squeeze out of these old suckers even on the bad motherfuboards
long live PCem
Reply 25 of 296, by elianda
AMD-386DX-40-1-40-ETEQ-ETEQ386-64kB-ISA-TSENG ET4000-1MB-AMI386BIOS-Elianda
Result 3DBench 1.0: 15.3
Intel-386DX-16-1-16-IBM-IBM8580-None-onboard-IBM Original VGA-256kB-IBM-Elianda
Result 3DBench 1.0: 4.0
AMD-486SX-66-2-33-Compaq-Presario CDS520-64kB-Local onboard-Cirrus Logic GD5424-512kB-Compaq-Elianda
Result 3DBench 1.0: 40.0
Reply 26 of 296, by Amigaz
The problem is that alot of PCI/VLB cards don't want to play nice with a 40mhz FSB
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 27 of 296, by keropi
I re-tested my p200mmx machine with 1.0C :
CPU: intel pentium 200 mmx
Mainboard: Spacewalker (IIRC) with VIA MVP3 chipset
Amount of RAM: 64MB , EDO
Amount of L2 Cache: 512kb
Video card: Riva 128 PCI 4MB
3dbench score: 133,8
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 28 of 296, by leileilol
well I still got the same 71.4 result with this anyway.
AMD-AM5x86-133-40-4-160-PCCHIPS-M919486VIP3.4-UMC8881-16KB-PCI-S3Trio64v+-1MB-leilei
long live PCem
Reply 30 of 296, by leileilol
Oh it's tweaked, but that only meant tweaking for 0 wait states and less IRQ usage
The cache refers to L1, as the board has no L2 cache or any cache modules "supported" by it! Funny, the lack of it isn't really a significant dent to the performance. To go further would mean getting a cool Stealth 64 like keropi has.
long live PCem
Reply 32 of 296, by Mau1wurf1977
Looking at the 486 list, we got most cpus, but I would like a figure for a DX2-50...
Anyone with a DX2-66 could get this score, simply set the FSB to 25.
DX4 machines should also allow setting the multi to 2 and FSB to 25 resulting in a DX2-50..
My YouTube channel
Reply 33 of 296, by retro games 100
That's an excellent result, considering the mobo. I also have a PC-Chips M919 mobo, and found that by tweaking its BIOS settings, you could get the system to perform well. Surprising! 😉 😀
Reply 34 of 296, by elianda
I would awergh push to recheck his utterly slow 486DX2-66 (12.1 Score). There are so many things unknown, that there isn't much information gain.
And it somehow doesn't fit the general performance curve anyway.
So at least there should be some information why especially this system is way off.
Youtube Channel
Reply 35 of 296, by leileilol
The Realtek ISA 512KB SVGA video card is a real painful thing to work with - I've used one myself and it doesn't even work in DirectX either. The only good thing about it is its compact size.
long live PCem
Reply 36 of 296, by elianda
CPU Brand-CPU Type-Bus Clock-Multiplier-CPU Clock-Mainboard Brand-Mainboard Model-Chipset-Mainboard Cache-Graphics Bus-Graphics Card-Graphics Memory-BIOS-Tester
AMD-K6-66-3.5-233-Gigabyte-GA586HX-i430HX-512kB-PCI-Voodoo3 3000-16 MB-Default-Elianda
3DBench 1.0c: 216.9
Intel-Pentium MMX-66-2.5-166-Gigabyte-GA586HX-i430HX-512kB-PCI-ELSA Victory Erazor (Riva128)-4 MB-Default-Elianda
3DBench 1.0c: 151.4
Youtube Channel
Reply 38 of 296, by elianda
Well, this might be a bit overkill but DOS boots also on this machine (anyhow the result might be questionable):
Intel-Core2 Quad-1333-8.5-2833-NVidia-unknown-nForce680SLI-12MB-PCIe-GTX260-768MB-Default-Elianda
3DBench 1.0c: 450.2
Youtube Channel
Reply 39 of 296, by 386DX40
Here is results from my 386 system.
AMD-386DX-40-1-40-Unknown-Unknown-ALI M1429-128kb-ISA-Tseng ET4000-1MB-Tweaked-386DX40
The 3dbench 1.0 score was 16.6 FPS. 😁 😁
