3DBENCH CPU Benchmark Database
First post, by Mau1wurf1977
I apologise for not looking after this project more than I did. I was pretty good initially but then life does its thing and you don't have the time anymore 😒
So I put my latest copy of the spreadsheet on Google docs. I hope I got the permissions right. Anyone with this link below should be able to edit the spreadsheet!
https://docs.google.com/spreadsheet/ccc?key=0 … QjdBV2ZqWnVzQkE
Quick Start
1. Make a DOS boot disk (Right click on a:, select format and tick "Make startup disk"
2. Unzip and copy the attached file (3dbench.zip) onto your boot disk
3. Boot from your bootdisk
4. Type 3DBENCH.BAT if you have a 486 or slower or type 3DBENCH2.BAT if you have a Pentium or higher. On Slot 1 machines enter FASTVID.BAT before you run 3DBENCH2.BAT*
5. Use blows template to post your results (Just like the example, no spaces please it will make importing the data much easier for me)
* FASTVID unlocks video performance on Slot 1 machines
Rules
This is mostly a CPU benchmark, although the choice of video card (especially the Graphics Bus) does have an impact.
CPUs are grouped into "Mainboard classes". Anything goes. If you use a upgrade chip in a 386 board, the results will go into the "386 Mainboard class".
Same goes for Slot 1 adapters.
Template for posting results:
Please no spaces, as this will make importing the data much easier for me!
CPU Brand-CPU Type-Bus Clock-Multiplier-CPU Clock-Mainboard Brand-Mainboard Model-Chipset-Mainboard Cache-Graphics Bus-Graphics Card-Graphics Memory-Tester-Score
Example:
Intel-Pentium-66-1.5-100-Aopen-AX59 Pro-VIA MVP3-1MB-AGP-Geforce MX440-64MB-Mau1wurf1977-100
        3dbench.zip
        361.85 KiB
        1385 downloads
        Includes 3DBENCH version 1.0 and 1.0c and two .BAT files for easy launching. Also includes FASTVID for unlocking video performance on Slot 1 machines. Make a DOS boot disk and unzip these files onto A:
      Reply 1 of 296, by Mau1wurf1977
      The image is cut off at the right side. It's best to right click and open it in a new tab or save it onto your computer.
      Reply 3 of 296, by retro games 100
      Awesome! 😎 Well done.
      (Please note that a score by Amigaz may be incorrectly entered in to your database table above. I think that the 3rd value is incorrect.)
      Edit: Table has been updated - new entry added. 😀
      Reply 4 of 296, by Mau1wurf1977
      Hmm I can't find it. What cpu and bus clock is it?
      My YouTube channel
      Reply 5 of 296, by retro games 100
      Sorry, I was looking at the Commodore PC-50 II values by Amigaz -
      CPU: Intel 386SX 16 mhz
      Mainboard: Commodore unknown model/chipset
      Amount of RAM: 5mb
      Amount of L2 Cache: n/a
      Video card: Tseng ET4000 1mb ISA
      3dbench score: 5.0
      Perhaps this info has not been entered in to your DB yet?
      Reply 6 of 296, by keropi
      I still wonder why my p200mmx+riva128 scored ~49,3 or something with 3Dbench 1.0 ...
      🎵 PCMIDI mpu site buy+info
      🎧 WIP Orpheus soundcard site
      Reply 7 of 296, by Mau1wurf1977
      I answered this in the other thread but it might have gotten lost...
      Short answer: Use 3Dbench 1.0c for Pentium and higher. You can get it from the files I attached on my first post in this thread!
      Long answer:
      keropi wrote:
      wow... just tried 3Dbench with my p200mmx and I get 49.2 ..???!?!?! way too low and the machine is fast in games like Blood @1024*768 ... maybe some petium conflict? the benchmark completes in ~2 secs btw...
      Sorry just now saw your post!
      This is because version 1.0 doesn't work well on Pentium and faster. Version 1.0c should be used on Pentiums and faster.
      However 1.0c has issues on really slow machines (results are way to high)...
      I am working on a nice sheet and will get a 3dbench database going! It should be good. I am currently entering all the data from this thread and then we can go nuts with benching!
      Watch the space!
      Reply 8 of 296, by Mau1wurf1977
      Maybe I am seeing things... But it's the first entry under "386 Mainboard class", right at the very top of the table.
      The results are sorted by Benchmark Score in ascending order.
      Reply 9 of 296, by Amigaz
      My GA-486TA mobo uses SiS chipset, so does the Everex and Asus 386 mobo too 😀
      Stason.org and all other hw sites are wrong at say the GA mobo has OPTI chipset
      My retro computer stuff: https://lychee.jjserver.net/#16136303902327
      Reply 11 of 296, by keropi
      ah, thanks Mau1wurf1977 , will submit my "good" pentium scores too 😁
      Reply 12 of 296, by Mau1wurf1977
      Ha that's where I got it from.
      I have updated my sheet, but won't upload it right away. I might upload the database once a day before I hit the sack.
      EDIT: I think I will add line numbers, so it will be easier to communicate 😀
      Reply 13 of 296, by Amigaz
      Mau1wurf1977 wrote:
      Ha that's where I got it from. […]
      Arighty 😀
      Going to come up with some more results from some 486 machines later...
      Reply 14 of 296, by Mau1wurf1977
      Line numbers added!
      So it's easier to fix stuff...
      My YouTube channel
      Reply 15 of 296, by keropi
      will I overcome boredom and post results from my 1.4ghz pIII/voodoo5 ? do you need this kind of results?
      Reply 16 of 296, by Mau1wurf1977
      There is fps limit of 999. Your machine will likely be too fast 😀
      My YouTube channel
      Reply 19 of 296, by aitotat
      The VLB Graphics Card I used for testing has 2 (not 3) MiB RAM (386 table lines 3, 9 and 11). Only the ISA card has 3 MiB.
      Can you make background color a bit darker for every other line? It would make the tables more readable.
