Reply 20 of 56, by nemesis
wrote:I was using an IBM 5x86C-100HF on my crappy HOT-433 rev 1-3 boards. Where did you find a rev 4 HOT-433? To confirm, the Rev. 4 has only single bank cache (4 cache sockets + 1 TAG), and this is what you have? If so, I'd say this is the board to be testing overclocked CPUs on. I've always had shoty luck with my rev 1-3 boards.
Could you let me know if the PS/2 mouse feature of the rev 4 actually works? it never worked on the rev 1-3 boards, as far as I could tell. Thanks.
That's the same CPU I've been using. I got the HOT-433 from a friendly Canadian. And yes, it's the Rev. 4 board with only 1 bank of cache (soldered onto the board, it's in my cache chips post). Also, to confirm, it says that it's a revision 4 HOT-433 on the corner of the board, which is visible in one of the pictures in said post.
As for the PS/2, I'm still hunting for the adapter to test it with.
