A solid 138 MHz on maxspeed indictes to me that you are indeed running at 150 MHz. This is fantastic. Maxspeed always undershoots like this at frequencies above 100 MHz.
Can you use 60 ns RAM instead of 70 ns? If you plop in a 60 ns stick (preferable FPM over EDO), you should be able to run your cache at 2-1-x (or 3-1-x) and your RAM at 1ws/0ws (read/write). 3-2-3 is awefully slow. 3ws/3ws is increadibly slow too, even for 70 ns RAM. I'd try to hone in on the lowest possible stable numbers and re-run the tests. You'll also want to set your FSB-to-PCI divisor to 1:2/3 instead of 1:1/2, that is, if the HOT-433 has a 1:2/3 setting. I don't recall off the top of my head.
I beleive that this combination of cache and RAM timings is why your benchmark scores are so slow. Is write-back L1 cache enabled for the CPU? Are you using L2 write-back cache mode as well?
Once you fine-tune the cache/RAM settings, there are a few other Cyrix enhancement features which you probably do not have enabled that will greatly effect your SpeedSys score. I'll have a report out shortly which will identify the percent boosts of each feature, but for now I can tell you that LSSER, FP_FAST, L1 WRITE-BACK, and BTB have an impact on SpeedSys.
SpeedSys
LSSER=3%
FP_FAST=14%
WRITE-BACK=6% (as opposed to write-thru)
BTB = 0%, but if used in combination with LOOP and RSTK, =4%
(note, such a setting is not very stable, and therefore not recommend)
The fact that you got this running at 4V instead of 5V is really good news.
You do not need to take a digicam shot of your monitor for Speedsys, it has a built-in report generator. The option will be presented once you've finished all the memory and harddisk tests. Press R to create the PCX image report (screenshot). It will save this file to the speedsys folder. Then just convert it to a PNG file once in Windows. You should get something like the enclosed file below.
This is of an IBM 5x86C-133 with all Cyrix enhancements turned on, including the not-so-stable BTB+LOOP+RSTK and is the fastest 486 SpeedSys score I've ever seen (76.43). My hope is that your IBM 5x86C-150 will clobber the IBM 5x86C-133. A stable score for the IBM 5x86C-133 is 75.4 and a score with enhancements off is 60.63.
So if you are getting a score of 69.00 with enhancements off, expect to increase that to about 85.00 with enhancements on. Now if you improve those cache/RAM timings, I'd hope that you'd near 90.00. Keep us posted.
