Phil's Ultimate VGA Benchmark Database Project
Reply 20 of 495, by badmojo
Mau1wurf1977 wrote:
Geoman wrote:
9956 realtics cannot be...
Yes that's the output of whatever was saved last in RESULT.TXT.
I would delete the entire BENCH folder and unzip it again.
I had this problem too, and it was caused by RESULTS.TXT being write protected - I'd copied your folder over to DOS from a CD.
My suggestion is that you remove any output files like this from your zip file and re-upload it.
Reply 23 of 495, by ReeseRiverson
Oh cool, I ought to try this out on my systems! 😁
Reply 24 of 495, by badmojo
Mau1wurf1977 wrote:
I see, so this is the zip doing this?
Why does it work for other.
Ok I'll look into it!
No it's not the ZIP, it's simply the way I copied them over. I burnt them on to a CD, then copied the files from the CD to my DOS machine using XTree Gold. This process leaves the files with read-only permissions, so when your DOOM.BAT is called it fails because it can't open RESULTS.TXT for writing.
I won't be the only one using this method, so simply remove 'RESULTS.TXT' from your DOOMS folder in the zip and it's all sorted, it'll save people having to mess around with permissions.
Reply 25 of 495, by badmojo
GL1zdA wrote:
What about adding Quake?
Quake won't run without a maths coprocessor, so do I just leave the quake score blank in the spreadsheet, or do you not want systems that can't run quake?
Reply 26 of 495, by Mau1wurf1977
Of course, go ahead! In the 386 examples of mine I just wrote "No maths processor" or something like that 😀
ZIP file on MediaFire has been updated and fixes the issue of Doom not running on some machines. Thanks for the hint Badmojo 😊
New version has a date in the menu to keep track of versions 😀
My YouTube channel
Reply 27 of 495, by Mau1wurf1977
Well I believe we have quickly hit the ceiling with 3dbench2 😀
It could need 4 digits. I have the theory that after 999 it starts at 0 again. But hard to say. Must say that PCPBENCH scales really nice.
My YouTube channel
Reply 28 of 495, by vetz
From my testing with my Tualatin 1400mhz my theory is that it goes beyond 999, but just don't show the first digit. From what I recall I got a score of ~500 without FASTVID and ~400 with FASTVID, which is a strange result by itself, but not when the benchmark was visually running alot faster on my screen. Thus making the ~400 score ~1400
Reply 29 of 495, by Mau1wurf1977
Yea I also believe that's what is happening. But that's why there are other benchmarks in the database 😀
Doom seems to hit some sort of wall, whereas Quake just keeps getting faster. I did a run on a PIII-S 1.4 GHz system and it chews it out. 222.2 fps 😈
I'm just uploading a video because it's fun to watch.
My YouTube channel
Reply 31 of 495, by elianda
I have a weird problem with quake on one system:
If I run it normally everything is fine and it works, but as soon as I run it in timedemo mode it crashes after a few frames of necropolis.
If I run it with +timedemo demo1 then it shows in the line before "Playing shareware version."
Findfile: can't find gfx/pop.lmp
I don't know if this is related or it is some other issue. It doesn't seem to be a computer config problem as it even happens with BIOS safe defaults.
Youtube Channel
Reply 32 of 495, by Mau1wurf1977
Hmm. Maybe a corrupt download?
You can always get the shareware version yourself and put it in the right folder. Just set the screen size to maximum once. The nosound and nocdaudio is taken care through the batch files.
My YouTube channel
Reply 33 of 495, by Geoman
Mau1wurf1977 wrote:
My bad. The command to output a text file is to type:
type result.txt
timed 2134 gametics in 815 realtics
And MY BAD: Last night I burnt the benchmark on CD and forgot to take away the write protection after copying it to the aptiva...
IBM Aptiva 2168-931
Reply 34 of 495, by Mau1wurf1977
Badmojo helped me fix this. The ZIP file has been updated and fully works now. But yes, removing the read-only flag of result.txt in the old version will also fix it 😀
My YouTube channel
Reply 35 of 495, by Skyscraper
Everything works great.
If you use a clean bootdisk without an autoexec.bat file you will probably get the message "OMPT=: cannot open" when you are trying to run the quake benchmark.
Make an autoexec.bat with the line "PATH=C:\" and the problem goes away.
Reply 36 of 495, by keropi
I am currently benching Quake on my IBM PS/1pro machine, it is a cacheless 386sx/20 wonder that is upgraded with a 486slc2/40mhz , i387 fpu and 16MB IBM ram...
Quake runs but I estimade 0.3fps 🤣 🤣 🤣 🤣
edit: it bugs me why they did not include any cache at all 😢 , wtf IBM , "pro" model....
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 37 of 495, by Skyscraper
I just tested a 4mb Ati Rage Pro Turbo card in a system with a P3 850 CPU
It scores 3726 FPS in 3dbench2 but it does only get 154.8 FPS in PCPBench
The Riva 128 ZX got 1009 FPS in 3DBench2 and 244.6 fps in PCPBench with the same settings
Very strange!
edit
Not that strange, there was a dot in the score that wasnt visible on my LCD screen.
I updated the results with the correct scores.
/edit
Reply 38 of 495, by Geoman
It was the same shame with the aptivas - the cache-slots were empty by default and it's hard to find these exotic modules for a reasonable price.
IBM Aptiva 2168-931
