The Universal Spacerocket
Reply 20 of 24, by archsan
PcBytes wrote:
Okay,here are 2 pics of the rig.The system doesn't have one panel because I bought the case that way. Here they are: http://www. […]
Here they are:
file.php?mode=view&id=15058&sid=b8acd3f23564181e501fe262fbcf44df
I had that "Nokia" case for my old Athlon T-bird build! It's called that way because... well this: 🤣
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 21 of 24, by PcBytes
Cool!
I think I had a Nokia 8850 at a point,but never knew that there is a PC case designed like that.
Also,the brand of the case is "Human",but I couldn't find anything about it on Google images.
Reply 22 of 24, by RacoonRider
Is that North Bridge cooler hanging from the videocard? :DD
Reply 23 of 24, by PcBytes
No,it's not the NB cooler 🤣 It's a old EPoX heatsink I had that I attached with some glue.
If you look closely in the middle of the picture,there is the NB heatsink.
Going on,with another update:
Installed Flash,and tested it using a 1937 cartoon (Porky's Railroad).144 and 240p work fine.
360p and 480p also work fine,but as long as I don't move the mouse.
I also found a CD with some games on it,along with Chicken Invaders 2.Does anyone remember Chicken Invaders 2?
I used to know that instead making a tune of their own,InterAction just took the OS/2 Warp 4 startup sound and put as their theme.
Reply 24 of 24, by PcBytes
Back with good and bad news:
Bad news
Tried flashing my Radeon 7000VE's BIOS and now it won't POST with it.I'll try saving some money for a 9250 128MB.
Good news
Got another BIOS to flash,the latest BIOS for AOpen AX4SG Max II.Other than the inability to boot from a USB pendrive,it can boot from everything else and has pretty good BIOS options.
Also,here's a fullscreen BIOS logo that I intend using on the system:
