The Universal Spacerocket
First post, by PcBytes
Well,I'm back with a new system!
First off,specs for everyone:
ASUS P4P800-VM - this board first came with AMI BIOS,but after hard researching,I've got it to run 4 different BIOSes (all Award,see list below the specs)
1GB RAM DDR400
Intel Celeron D 2.66GHz (I ran a 1.7GHz Willamette and a 2.4 Celeron D before this one)
WDC WD800JD-55MSA1 80GB,SATA 150
ATI Radeon 7000 32MB AGP
Samsung SDG-605 DVD-ROM (taken from an Xbox)
400W DeluX PSU (still holds strong!)
Well those are the specs.Now,here's the list of the BIOSes I can choose (and those BIOSes actually work)
1.Supermicro P4SPA+ - PMC 49FL004T
2.Albatron ABOX 865 - SST 49LF004A
3.DFI 848P-AP - SST 49LF004
4.AOpen AX4SG-UL - PMC 49FL004T
Sadly I can't do any pics of the system,as my tab is broken and my webcam's quality is just horrible.
Reply 1 of 24, by PcBytes
Also,forgot to mention,the system doesn't have a case.
I chose it to be this way because it cools the system a bit more.
Reply 2 of 24, by Tetrium
Wouldn't a case with a single exhaust fan be adequate anyway?
My retro rigs (old topic)
Report spammers here!
Reply 3 of 24, by PcBytes
My old case was so worn I couldn't use it anymore,so I left the system without a case.
When I can,I'll buy another DeluX case so I can install the system in.
Until then,I'll use the system like that.
One thing I can't rely on is the temperature monitor for the CPU on the Supermicro BIOS (I use a Supermicro BIOS on this ASUS board,no joke or anything like that)as it reports that the CPU temps are around 39-43*C when actually the real temps are 90-100*C.
Reply 4 of 24, by BSA Starfire
90-100c sounds incredibly hot. I'd say that the reported 39-43c is likely correct, prescotts can be hot, but not that hot!
Reply 5 of 24, by PcBytes
Actually it REALLY was that hot.
I tried an Albatron BIOS just for that,and it showed that the CPU temperature was 90-93*C.
Maybe it's the toothpaste that got crusty? (I use toothpaste as CPU paste until I can afford myself a normal CPU paste)
Reply 6 of 24, by RacoonRider
PcBytes wrote:
Actually it REALLY was that hot. I tried an Albatron BIOS just for that,and it showed that the CPU temperature was 90-93*C. Mayb […]
Are you crazy?
The most approved thermal paste in Russia is КПТ-8. $1-2 for a 20g tube in any radio store. One must be living on the street to not be able to afford such a simple thing.
Reply 7 of 24, by PcBytes
Are you crazy?
Even crazier is that with toothpaste,using a EPoX EP-4PLA3I,I had 29-33*C on the CPU!(I still have a video of that)
Reply 8 of 24, by PcBytes
Back with 2 more BIOSes to work,and the latter is the one I think I'll leave as default,as I like it.
1.DFI Lanparty PRO875 - SST 49LF004A - POSTS but hangs with incorrect RAM test (only 1024K OK from 1GB)
2.Iwill P4SE Gold - PMC 49FL002T - POSTs fine,has the Y2K Iwill logo (anybody with a Iwill motherboard knows about it)and it even detects the onboard Intel LAN.
Right now,I'm unsure if I should upgrade to a Radeon 9600 or keep the 7000 in there and use the Basic theme.(I'm running a lite version of Windows 7,but it has the Aero theme included)
What do you think?
Reply 9 of 24, by Standard Def Steve
You should definitely upgrade to the 9600
-It's many times faster than the dog slow 7000.
-It's actually supported by Win7. Radeon 7000 has to use X DDM drivers ripped from Vista in order to give you basic functionality under Win7, which is far from ideal.
-It would help that PC live up to its "Universal Spacerocket" status a little better. 😀
But even with the 9600 I'd keep Aero disabled. Aero is best left to WDDM 1.1 capable cards; on those it looks pretty without detracting from performance.
"A little sign-in here, a touch of WiFi there..."
Reply 10 of 24, by PcBytes
Standard Def Steve wrote:
You should definitely upgrade to the 9600 -It's many times faster than the dog slow 7000. -It's actually supported by Win7. Rade […]
So,I'll go and scan my city for a 9600.
You're pretty much right,as my 7000 BSODs at shutdown saying TERMINAL_SERVER_DRIVER_MADE_INCORRECT_MEMORY_REFFERENCE.
Also,I'd say that this PC,other than the video card being old (it's all I have handy right now)it pretty much lives up to the name.I chose that name though mainly because of the motherboard's ability to use other boards' BIOSes(from Albatron,Supermicro,DFI,Iwill,ECS,AOpen etc.).I'm trying to make a big list of BIOSes that work (and tested by me)on the P4P800-VM.
On the other side,I replaced the small HSF it had (knowing Celeron D CPUs are Prescotts,I wonder how the Celeron D 2.66GHz installed survived with that small HSF)with a "homemade"one,made from:
-an old stock Pentium 4 Intel heatsink (minus the stock fan it had,basically just the metal brick)
-an S462 stock fan (with one broken blade)
-mounting brackets from an Socket 478 ASUS HSF
The result:a good heatsink that keeps temps into a normal range -75-80*C. (normal for a Prescott CPU)
Reply 11 of 24, by BSA Starfire
PcBytes wrote:
So,I'll go and scan my city for a 9600. You're pretty much right,as my 7000 BSODs at shutdown saying TERMINAL_SERVER_DRIVER_MADE […]
75-80c is NOT normal for a Prescott, especially not an 2.66 Celeron, I run a skt 478 Prescott P4 540(3.0ghz, 1 mb cache, 800fsb), it never breaks 60c with a decent cooler. Yours must be thermal throttling or the temp readings are wildly off.
Reply 12 of 24, by Half-Saint
What exactly is the purpose of testing that board with other BIOSes?
Reply 13 of 24, by PcBytes
Considering I use a homemade HSF,and I use toothpaste atm (I'm going to get some real paste today though)I find those temps normal.Anyways,it rarely goes over 74-75 though,and if it ever goes over 74-75 it stops at 80.
Well the purpose was to find an BIOS which works best while making a list with each BIOSes that work on this board.
Reply 14 of 24, by PcBytes
Well,I'm back,and I applied thermal paste.
Now,with the homemade HSF I get about 64*C.
I also applied thermal paste to the NB,because it was getting real hot.
Reply 15 of 24, by PcBytes
Finally,I got around recording one boot-up of the system.I also added 3 pictures of the motherboard,PSU and HDD.
Attached down is the video,packed in a .rar file.I've went through a lot of pain just to get it down to the forum's filesize limit.(limit is 5mb,file is 2.25mb)
Reply 16 of 24, by Living
you know there's something called youtube?
Reply 17 of 24, by PcBytes
Yes,I do know that there is Youtube,but I wanted to upload it here so I packed it in a rar file.
Reply 18 of 24, by PcBytes
2 quick,small updates:
1.I've bought a case for the system (case is named "Human")and installed everything in the case.Also added a LG DVD drive instead of the Xbox drive.
2.Fixed the BSOD on shutdown problem I had with the Radeon 7000,so now I can shutdown completely.
Pics of the rig tomorrow,but in the meanwhile,here's my desktop on this rig:
The attachment Celeron D 330 (478).png is no longer available
Reply 19 of 24, by PcBytes
Okay,here are 2 pics of the rig.The system doesn't have one panel because I bought the case that way.
Here they are:
file.php?mode=view&id=15058&sid=b8acd3f23564181e501fe262fbcf44df
file.php?mode=view&id=15059&sid=b8acd3f23564181e501fe262fbcf44df
